Question about Motorola Mobility RAZR V3
My buttons on my cell phone...
None of them work,including the side ones, except the power one. I have tried taking out the battery and sim card out.
  • jhoanna May 23, 2008
    It's the other way around for me. Everything is working except for the power on/off keypad. I also try to taking off the battery.
  • 57 Answers
Hi tina. Looks like the keypad of your phone is screwed. You will need to get a replacement keypad and it will be up and running again.Good luck!
Posted on May 23, 2008
My htc cannot start
  1. Make sure your battery is fully charged. Then remove battery, SIM card and any memory card you might have inserted. Clean all the metal (copper) contacts you find on the inside of the battery cover and SIM cover (if any) with methylated spirit on a cotton bud. Replace battery only and try restarting the phone. If successful, turn it off and replace SIM and try turning it on and off. If successful, do the same with the memory card. this can eliminate the problem. If none of the above is successful, you can try a factory hard reset however be mindful that all your data, apps and settings will be deleted and restored to factory state except the stuff you hace on your memory card and SIM, which will not be affected. I guess if you can not restart your phone anyway, there is not much else you can do, so you will only use what is not yours any more... :)
    here is what you need to do:
    Turn the power off. If your HTC Desire is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Press and release the Power button
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO.
If you selected YES, all data including third-party applications will be deleted from the HTC Desire. Once the wipe is complete, the phone will reboot to its factory fresh state.
Apr 30, 2014 | HTC Chacha Smartphone
Power button broken
Since it's broken, im probably sure you arent able to put the button back on or back its original place it was in? Maybe could take a small pin and press down on the power button and maybe it will come on. If none of that works, then try buying a new power button and installing it.
Dec 01, 2013 | HTC VERIZON DROID THUNDERBOLT ADR6400 ADR...
HELP!! my nokia 6500s wont allow me to get on the menu screen,, whenever it starts up,, it shows Push to talk,, and it wont go away,, ive restarted it several times,, it still shows push to talk,, push to...
Try doing this. Turn off the unit, remove the battery, press and hold the power button (while battery is out), then put the battery back and turn it back on. If that doesn't work, just repeat the steps including removing the Sim Card. Or turn on the unit without a Sim Card.
You can also try using reset codes but that would reset EveryThing back to default settings which might include losing the settings of your provider which is not recommended. But the initial step is safe to use.
Hope this helps.
Nov 16, 2010 | Nokia 6500 Slide Cellular Phone
My HTC Shadow goes to the white Tmobile Shadow screen and gats stuck and wont go any further. I can't turn it off using the keys I have to take out the battery to turn it off
the "soft buttons are right below the screen hold both down then turn on the phone this will make the phone ask if you want to reset to default so try removing the batt , mem card and sim card first as this it the last resort you will lose all changes made to the phone except mem card and sim card stored items worked on my shadow fine good luck peeps
Aug 21, 2009 | HTC Shadow Smartphone
I have a Motorola razr2 v9x i can not get any of the keys to work
Yeah, I got the exact problem too with my V9 and I eventually found out that it was about the small button located the right side of it (one of the smart button) it stucked inside and it keept all the other buttons away from working then I opened it and got it done.
Aug 20, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Motorola Razor V3xx has frozen keys except on/off button
Take the battery out and set it under a hot laptop for a half hour.
Jun 12, 2009 | Motorola Mobility RAZR V3
Water damage
get a new phone
May 12, 2008 | Cell Phones
Headset icon
Here's how I fixed the damn headset thang on my Nokia.
Take out the SIM card and start the phone *WITHOUT* the SIM card.
Wait until the phone's screen says, "insert SIM card."
Wait a minute, then re-insert the SIM card, and re-start the phone.
Voila, the horrid headset symbol is gone (I hope).
Do it a few times if it doesn't take the first time (although, it did on mine).
Hope this works for you, because hell, that headset setting is a real beyatch when you *don't* want it. ;)
Apr 05, 2008 | Nokia Consumer Headset
KRZR k1....
It sounds just like a keyboard lock and you need the code to unlock it. though it should be prompting you,
if you push * and # on the same time your keyboard locked. When you press it again, you unlock your keyboard
Your phone’s four-digit unlock code is
originally set to 1234
The six-digit security
code is originally set to 000000
If you forget your unlock code: At the
Enter Unlock Code prompt, try entering 1234 or the
last four digits of your phone number. If that
doesn’t work, press s and enter your
six-digit security code instead.
If you forget other codes: If you forget your
security code, SIM PIN code, PIN2 code, or
call barring password, contact your service
provider.
hope any of this helps .
Feb 02, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility RAZR V3 Logo
23 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
