I'm not getting any color pictures in my home theater system
Suudenly, the home theater system seems to have lost the ability to produce colored images. All CDs are showing black n white images. I don't know what to do!
  • 2 more comments
  • mgb0118 May 26, 2008
    I have spent a lot of money on compent cable and S cable. Instead of black and white high resolution picture, I now get navy blue and pink. If this cannot be fixed I will probably sell it. I have listened to all the Radio Shack experts and have spent nearly the cost of the entire unit on cables. Yellow is not hooked up..s and component and red/white to get sound..Please help.
  • russia0607 Jun 09, 2008
    I too am not getting any color in my home theater system. I have a Kawasaki HT1210 DVD Home Theater System. The color was working until today. I had to disconnect everything and reconnect and I wonder if I did something I shouldn't have. What is the progressive function listed? And where can I find it to see if it is activated? Thank you.
  • nana6262 Sep 15, 2008
    all dvd are in black and white
  • sherishmmns Oct 28, 2008
    I have the same problem can you tell me where to look to see if its in the hdmi setting, i am using rca cables. As far as i know we hooked it up the same way before we moved and it was working and since we moved it we have no color.
    Problem Solver:
  • 13 Answers
Well, assuming were talking about a dvd player with dvd's,you dont specify what type of cables you are using to conect it to your tv, it appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Thanks...
Posted on May 23, 2008
R5002 resistor value for JVC XV-THD60 Home Theater
Why don't you read the color code? Assuming it's got bands of color painted on it.
Nov 12, 2013 | JVC THD-60 System
After the dvd plays for like 10-15 minutes(when dvd player warms up?) all the colors on the screen turn to black, yellow and purple for the rest of the movie. What's wrong?
I gotta know more clearly about your question, i am going to explain in 'Guide Solutions'
Guide 1: Is it the color just cover the main grid? (Color cover like blocking the others, such as watching 70s TV shows, the colors blocked in black and white.)
Source 1: Audio input problems, your dvd audio input linked with three different 'rops', they are appeared to be push by pressure.
Solution 1: Determine more spaces to them!
Guide 2: Is it the color cover the photon grid? (Color cover at all pictures, each of them doesn't stand the other colors instead of replaced by unique color)
Source 2: Undefined
Solution 2: The TV setting menu seems to b set by specific colors, change it on your own using remote. OR this is a specific part that the DVD need to show the color in unique color (only one)
(No problems, keep watching)!
Jan 22, 2011 | Panasonic Home Theater System System
My Bose LS 48 is producing in black and white, not color
If you are using a composite output and you do not set the system up in the menu for composite, it will give you a B&W picture. Check your output settings.
Aug 24, 2009 | Bose Lifestyle 48 System
Black and white
Unplug the home theater for about 2 minutes, and see if the default color has been reset once you replug it.
Mar 23, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
TROUBLE SHOOTING JVC DVD PLAYER DOES NOT SHOW COLOR PICTURE
Press and hole Scan Mode button for 2 seconds, Y/C will show in front display, use > to change to RGB then press OK.
Feb 25, 2009 | JVC TH-S11 Theater System
Hello, I need replacement speaker terminals
Please let me know connectors color at back of unit to provide you info for speaker cables.
Nov 29, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
WHEN DVD IS PLAYED THE PICTURE IS BLACK AND WHITE
you was right it was a mix up of my connection`s thank you
Sep 27, 2008 | JVC TH-M505 System
RCA BIG SCREEN TV - COLOR PROBLEM
If your TV is rear-projection system, it got problem in convergence board, may be few bad-solder connections.
May 30, 2008 | Audio Players & Recorders
SC-HT730 Color problems
What kind of connection are you using? If you are using a component connection or a RGB connection this could be causing your problem check the leads and if so replace new leads.
Apr 06, 2008 | Panasonic SC-HT730 System
479 people viewed this question
 Grubhead
Grubhead
