Question about Acomdata (HD160UE5-72) (HD160UE572) 160 GB Hard Drive
Computer does not recognize the external harddrive
When I turn the drive on, the blue power light comes on but computer does not recognize it. The idicator does not pulse with a different color to indicate activity. Thanks.
  • dhc0 Sep 02, 2008
    Windows recognizes the hard drive as existing when I try to update the driver, but does not recognized it in the control panel as attached hardware. Detaching the hardware makes not difference, not does uninstalling.
  • 40 Answers
Try installing the drivers on your computer for it from this website
http://list.driverguide.com/matches.php?h=932a9713352aa24ea0444960cf489ad2&ids[0]=1119263&ids[1]=1119260&ids[2]=1119267&cid=1256&model=HD160UE5-72 - E5 - 160GB
Posted on May 23, 2008
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
Hi, i'm having trouble getting my computer to recognize my hardrive, it was working fine this morning, but now all i get is a small red light instead of the normal larger rotating blue lights do you what...
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the harddrive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your harddrive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your harddrive to be detected automatically.
Hope this helps you out.
Nov 22, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Aug 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a 160GB signature mini external harddrive. It has been working fine for months but all of a sudden my laptop won't recognize when I plug it into the usb port. The red light comes on to show that it...
It sounds like your hard drive is dead. If you have tried it on a different computer and it did the same thing then your drive isn't booting up and is probably bad.
Aug 09, 2009 | SimpleTech Signature Mini 160GB External...
500g simpletech extrenal harddrive will not turn on
Sounds like a drive failure. If it under warranty then its time to trade it in.
Jul 29, 2009 | Western Digital 500GB My Book Pro-External...
Windows XP will not recognize my WD 250GB Harddrive
Just plug your USB HDD directly into your MBoard's USB port...
Feb 09, 2009 | Western Digital 250GB MyBook External USB...
External Harddrive not recognized.
perhaps this new computer has usb 2.0 while the old dell was of older standards.check whether the external hdd supports usb 2.0,,if it do so,,buy a usb 2.0 cable and start using it.best of luck
Jan 16, 2009 | Western Digital Caviar SE WD5000AAJB -...
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
My Computer doesn't recognize Ion 320 GB Harddrive
Well if its lighting up, then the drive is receiving power, or the enclosure atleast. Forget that case, extract the drive, and seek out something more reliable and more solid. Preferably an aluminum enclosure with no fan.
seek out Weibetech.
Oct 15, 2007 | IOGear ION (GHD335C160) 160 GB Hard Drive
Acomdata (HD160UE5-72) (HD160UE572) 160 GB Hard Drive Logo
281 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
terminalcon
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
