Question about Seagate (ST380011A) 80 GB IDE Hard Drive
HDD problem after SeaTools
Hello! I have a problem with Seagate 80gb IDE ST380011A. My HDD was formatting when the power was accidentally cut off. After that, it showed that it cannot be formatted. I tried SeaTools, and it worked fine and I managed to use it and format. I then placed some files inside. However, when I rebooted the computer, the scandisk showed up and scanned for index errors (i think). When I successfully entered WinXP, I found out that it was then again on the same state! (unformatted, same as before I tried SeaTools) I tried SeaTools once again, and it fails on the Short DPS. I don't think that I should repair it first again because there are files that are inside. Help please? What's wrong with the HDD?
    Guru:
  • 859 Answers
I understand your dilemma. There isn't anything wrong with your hard drive. When you formatted with Sea Tools, did you choose NTFS as the formatting structure?
Here is what I would do before you call Seagate (who has an excellent warranty and reputation). Enter your XP Desktop, right click My Computer, select Manage, then Disk Mangement. Right click the bar graph representing your Seagate drive in question and let XP format it for you. Reboot.
Check it again in your rebooted Desktop. If it is still showing as unformatted you do indeed have an issue to contact Seagate with
Posted on May 23, 2008
    Scholar:
  • 143 Answers
Give this utility a whirl
http://www.pcworld.com/downloads/file/fid,23069-order,1-page,1-c,utilities/description.html#
This should help you get the data on the drive back to a safe location.
Once that is done, try to reformat again. It could be that when you lost power, the heads crashed. Of course, that is not a good thing.
  • Eric Smale
    Eric Smale May 23, 2008
    Also, please let me know if this software works okay for you. It did for me, but that is not to say that it will work for everyone. Again, please let me know.
Www com 500
there is no need for a driver. for PATA. drive!
If XP then SATA drives does. but yours is not a SATA.
you failed to state what hardware this is, desk top, lap top? what?
a server?"
and what OS, Windoz, , Linux ? and version.
my guess is you have a problem. but failed to state what.
we can diagnose any problems, but must know it.
Oct 01, 2013 | Seagate Barracuda Model ST380011A 80GB IDE...
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
How can I convert a Seagate Barracuda 7200.7 (Model st380011a) to an external drive with usb?
BUY A HDD ENCLOSURE (http://www.tigerdirect.com/applications/category/category_tlc.asp?CatId=2777&name=Hard%20Drive%20Enclosures)
Apr 09, 2012 | Seagate Barracuda Model ST380011A 80GB IDE...
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Hdd power problem
Hi!
Check your HDD with HDD monitor utility to see if it's ok. You can try this one:
http://www.techsupportalert.com/best-free-disk-health-monitoring-utility.htm
If your HDD has bad SMART or power controller or smth like that - then you definitely need to replace HDD.
Also issue may be caused by your PC power supply or motherboard power controller. If HDD monitor shows that your hard drive is "alive", then try to "hang" your HDD to another power cord from your PC power supply and try to connect to other IDE/SATA port on your motherboard.
Also I'd suggest you to try your HDD on any other PC.
Jul 02, 2010 | Seagate (9W2892-337) 80 GB Hard Drive
Seagate 750GB usb HDD asks to format,when opening by double click
The disk is either damaged or the USB interface is damaged.
1) You could try opening the external case and connect the disk to your computer directly (Using IDE/S-ATA cables)
2) Format the HD and use data recovery software/service.
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Bad sectors removal and formating Seagate 80 GB
I suggest puting your hdd on another computer, full format it again, and scan it for bad sectors.Also, searching for a program that repairs bad HDD sectors, the windows default erros scan could not be very helpful if there are many bad sectors.
Sep 02, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Hard drive settings
d5e7986.gif Jumper settings for Seagate ATA/IDE Internal drives <20gb & greater
For older/smaller drives visit www.seagate.com
Jul 13, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
HDD
I've seen a simular problem where the disk is empty but it says there is a reduced volume remaining, In my case i ran check disk (started on restart) on the drive and it found a ton of files that were lost and restored them, so this regained the lost space. If that doesn't work, try right clicking on it in my computer and formating it.
Feb 16, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Hard disk is not detecting
hi, you should try downloading this http://www.seagate.com/www/en-us/support/downloads/seatools/
and booting off the floppy disk it creates will tell you if theres a problem with the drive and will probably fix it for you..
Happy New Year
John
Nov 18, 2007 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate (ST380011A) 80 GB IDE Hard Drive Logo
115 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
