Daewoo washing machine dwf-75ts
The machine won't spin and have an error message of a flashing LE together with a long beep sound
  • 2 more comments
  • Wisherwasher Jun 09, 2008
    Daewoo DWF-75TS -- same problem. Will go through wash and rinse cycles but will refuse to spin, and all we get is a long beep and "LE" on the display.
  • kg08 Nov 27, 2008
    LE error code and washer won't spin. Tried to unplug for 10 minutes and that did not solve the problem.
  • Anonymous Dec 27, 2008
    Hi, i have the problem of LE, then i followed to short circuit it. It run just ok. well, ofcourse i have to find the replacement for this stupid switch. What made it unoperational? its just irritating. Evry time i have to wash the LE error comes. So I decided to meddle with the circuits with a careful analization of searching the stupid switchm then voila! its back to work....
    thanks for the tip....
  • Anonymous Jan 02, 2009
    Where on earth is that switch? I can't see any...
Found the manual for a similar model. LE error code indicates a "Lid Open" error. Most likely the little switch that is tripped when you open the lid has failed due to corrosion or some other reason. If you can find an equivalent switch then replacing it should do the trick. Otherwise, you can simply short the connection so the machine thinks that the lid is always closed. WARNING: This effectively overrides the open lid detection system and poses the risk of having the unit run a spin cycle even with the lid open! find a replacement switch if you can. good luck! just shorted mine out temporarily and it works -- until i can find the right switch.
Posted on Jun 10, 2008
What is the exact belt size of Daewoo Fuzzy Logic washing machine 7.5 kg dwf-75ts? Where can I order this?
Hi,if you still have the old belt,take it to the shop and ask them to give you a replacement.
all the best.
Apr 28, 2015 | Daewoo Washing Machines
I have daewoo dwf 200 le and it not taking the water from the pipe outlet what to do to fix the problem
Assuming you have mains water running to the inlet tap and the tap i is open, the most likely cause is inlet hose connector filter is blocked or the inlet valve inside the washer is faulty.
Hopefully you are able to select the wash program and start the wash cycle. Otherwise the problem could not be in the water inlet or elsewhere.
Refer page 21 on this manual and also check the part number and location of the inlet valve.
http://www.daewoo.cl/sta/manuales-tecnicos/DWF-312W%20Manual%20Tecnico.pdf
Aug 17, 2014 | Daewoo Washing Machines
My Daewoo DWF 806 MP doesnt dry/spin after washing and rinsing and shows LE error. When drying starts some sound comes and then LE error apperas
my Daedwoo DWF-806 MP machine when i swith on shows figure 49 and not figure 0, and it also making noise like Buzz in between when the machine is ON. Can anybody help me to resolve this defect
thanks
Nov 01, 2013 | Daewoo Washing Machines
My washwe daewoo dwf-1150wp present problem by making it function on starts to sound a beep and the display shows error 9 and makes no function
Pressure sensor error
The washing machine has detected an error with the pressure switch or level sensor
  • Check wiring to level sensor
  • Check level sensor
cheers-Denny
Oct 18, 2013 | Washing Machines
Error message " LE "
Click the link below to troubleshoot the LE error on your daewoo washing machine:--- http://technoanswers.blogspot.com/2011/06/le-error-on-daewoo-washing-machine.html ----------- This should help.Thanks.Helpmech.
Jun 01, 2011 | Daewoo Washing Machines
LE CODE WHAT MEANS. DAEWOO WASHING MACHINES MODEL: DWF-772W
LE error code refers to the door mechanism. Usually there is a locking switch that senses when the door is closed, allowing the wash cycle to start. If your door is closed and you are still getting the LE error, it is probably this switch that is faulty.
Apr 20, 2011 | Washing Machines
My daewoo washin machine shows error code LE & it wont work actually whats the problem ? tq
my daewoo washing machine has error code LE
after every wash , it cannot rinse and spin then show
beep sound and show code LE. Thank you
Oct 06, 2010 | Daewoo Washing Machines
What is LE error for Washing Machine Daewoo DWF 772W model? how to solve it?
In other Daewoo models LE error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probable that your model reports the same codes.
It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor.
It is often clogs with soap and other particles.
Good Luck!
Jun 16, 2009 | Washing Machines
Washing Machines Logo
907 people viewed this question
Top Washing Machines Experts
