Question about Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 46 in. ic problem
The following are the issues I'm currently experiencing with my TV.
There is a concave image(middle part of the picture bending in and the outer ends bending out)
The red-blue-green colors were separated so it looked like 3 images at once.
I understand that you've recomanded replacing both the convergence ic when experiencing this problem and refer a webpage to purchase the parts from. Do you think this will solve the blury image and is it something that I could do myself or should I simply take it to a tech and have it repaired there.
  • Sony Master
  • 8,617 Answers
If you can solder it should be an easy fix for about 50.00 You need two Convergence ICs STK392-560 the link I am posting has replacement ICs and provide free tech support by instant messageing as well as instalation instructions with pics on how to change the ICs. A repair shop will charge between 4 and 6 hundred to do the job which is about an hour. I would also suggest getting about 6 of the 4.7ohm 1/2watt resistors also as sony will sometimes blow a couple with the ICs but the repair tech will help you find the open one if there are any. Heres the link to the site.
http://servicemanuals.vstore.ca/
Posted on May 23, 2008
Image curve
Image curve, it seems tv got problem with convergence output ICs failure.
Do you get off color picture or like 3 pictures in tv screen?
Is it Sony KP-57HW40 rear projection tv?
Let me know above info to provide you helpful info to solve this issue.
Thanks.
Jan 17, 2011 | Sony KP-57HW40 57" Rear Projection...
Picture looks concave. Words, people, everything
You have a convergence malfunction.......the convergence ic's and the protecter picp fuses in the power are will need to be replaced by a qualified perso. A reputable shop may charge around $300 to repair. If you have technical ability,I can guide you further to repair yourself as well
Jun 06, 2010 | Sony KP-53HS30 53" Rear Projection...
I have Sony KP-46WT500 Projection TV. For some time it appears convergence went bad. I see multiple images, especially at edges and corners. As many as 3 images Red, Blue and Green. I am an Electronics...
It would be great to assist you in Sony convergence issue.
As you said, for some time TV shows bad convergence in picture that shows its matter of lose/ dry solder joints in D board, specially on convergence out ICs pins that need to be re-solder.
There are 2 big black ICs mounted on aluminum heat sink on D Board of TV, below image shows D Board location in TV.
Resolder pins of these 2 ICs and also check any other dry/ cold solder joints in circuit board. I do not think of IC replacement as problem occurs some time.
Let me know if you have additional question.
Thanks.
Dec 20, 2009 | Sony KP-46WT500 46" Rear Projection...
Have Sony KP-57ws500 rear projection i had the bulbs replaced 3 years ago now itseams as if everyting is out of focus.images outlined in green and red.
It sounds TV got convergence out ICs failure problem and causing 3D image or outlined picture.
There are 2 convergence out ICs mounted on D board in TV that need to be replaced.
Let me know if you need part number of ICs if you want to replace by yourself or call local Tv tech to fix it.
Thanks.
Dec 04, 2009 | Sony KP-57WS500 57" Rear Projection...
Lots of Blue shadows off to side. concaved picture almost
HI, this is a failed convergence chip that is located on the convergence board. it will need to be replace ASAP. you can just replace the chip or , you can order a new board.
Replacing the chip can be a rough job if you don't have tech experience. if you are a fluid tech and you can solder and know your way around a circuit board, just replacing the chip will cost less. if you are not an experienced TV tech, i recommend a service call to the nearest TV tech to replace the convergence board.
May 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Power surge may have blown tv- Sony KP-46WT500- worth fixing?
Take a look at my post on Convergence IC replacement..Thank you GURU JAY
Feb 18, 2008 | Sony KP-46WT500 46" Rear Projection...
Convergence?
Circuit board with STK convergence IC's must come out .....
Replace both IC's, reassemble...test........................
IC's mounted on large heatsinks.............T.
Nov 28, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS510 Convergence issue?
Replace convergence IC's....STK392-560 X 2 + check pico
fuses under IC heatsinks.....................T.
Nov 12, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-57WS500
the unit needs the convergence ic's replaced and probably a couple of safety resistors.average repaire are about 300 from a tv shop
Mar 04, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
