Question about Fisher and Paykel GWL11 Top Load Washer
GWL11 completely Dead------blows main fuse when rinse starts
I replaced the on-board fuse with a in-line fuse and holder 6 amp...fuse blows in 3 seconds when rinse cycle starts.
I suspect a bad motor.....any advice on this?
Washer is 3 years old.
  • Anonymous Mar 26, 2014
    model wa5471abwxaa01 serial yoj654bc201099k
  • 868 Answers
This is a poorly made machine with flaws that are never ending.My advice to you is save time and manly aggravation and get rid of this washer.
Posted on May 25, 2008
My 1998 Honda shadow keeps blowing the main 30 amp fuse as soon as you hook up the battery. Any suggestions
Hi, Steven you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Blowing MAIN 30A fuse
1985 1998 Honda Shadow VT1100 Service Manual Moto Data Project
Mar 19, 2016 | Honda Motorcycles
I have an Alpine MRV-70 amplifier that cuts off completely every now and again. Power is cut off altogether and no sound plays. Main Power line, fuse and fuse holders have been checked. Amp plays perfect...
You are overloadign the amp with your speakers. They may be the incorrect ohms or simply too large for the amp causing it to go into protection mode intermittently.
Oct 21, 2013 | Alpine Car Audio & Video
Number one fuse on my main board is deadl vizio gv47l hd tv 10 amp
If fuse is dead, there must be some reason for that. Some short circuit or so. Without rectifying the fault, if you replace it with an other fuse, the fuse you insert will also blow out, and might make more faults to occur. The rating of fuse will be marked on the printed circuit board itself, very near to the fuse.
Aug 19, 2012 | Vizio Televison & Video
Main 30 amp fuse keeps blowing when i plug the 4 wire fuse top back on after replacing 30 amp fuse. any suggestions
Hi, Anonymous before diagnosing your blown fuse issue, check the bottom of your seat, if it's metal and comes in close proximity to the positive battery post you need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) You are going to need a wiring diagram from your service manual, a test light, an ohmmeter and plenty of extra fuses.
If you turn on your ignition switch and immediately blow a fuse you have a hard/dead short and is usually easy to find. With a test light connected to the hot side of the blown fuse holder start stabbing the wire/s that leads away from the fuse holder and towards the ignition switch, you test light will illuminate validating the short. When the test light fails to illuminate you have passed the short and need to back up until the test light illuminates, then look in the immediate area for the short.
If you driving down the road for 30 minutes or 15 miles and blow a fuse you have soft/flying short and may take some time and patience to find.
If the main fuse/circuit breaker constantly blows/trips while riding you probably have a faulty battery terminal connection. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary. Any other fuses that constantly keep blowing while riding are usually caused by a loose or corroded ground wire in the circuit, which means you have to check, inspect, test each and everyone with an ohm meter set on a low ohm scale 100 ohms or less . Simply touch one lead to the ground source and the other lead to the battery negative terminal, a reading of zero indicates a clean solid ground. Any number reading or infinity indicates a poor ground and needs to be repaired. Poor or weak grounds require excessive additional amperage to complete the circuit which in turn blows the small amperage fuse.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
keep blowing the 30 amp fuse
main fuse keeps blowing
Honda Shadow VT1100 Owner Manual
Honda shadow vt1100 Owners Workshop Manual
Jul 14, 2017 | 2003 Honda VT 1100 C Shadow Spirit
Completely dead, receiving power. Is there a fuse?
You have an easy job to just trace the power cord to the unit, with the line disconnected and using a multimeter it is easy to trace the continuity of the wire to the unit where you can locate iff the line is cut off or the reason the circuit is open.
most often this can be due to the link fuse at this end or a possible break in the line. If these test fine then the power switch/controller unit is faulty.
Nov 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
The washer stops and beeps at the rinse cycle. Clothes are not off balance. If I bypass the rinse it did spin until this week. Now it does not even turn on. Is there something wrong with the cold water...
If it is not turning on at all now when you press the power button then the main computer board has blown..OR The pump has blown..some models the power must pass through the pump before it will power the main computer board,if the pump is dead then no power will pass through it to the control board.Just to confuse you a bit more,the pump may have been on it's way out & thats why it worked occassionally but now i fear the pump has taken out the the main board with it.There may have been a slight burning spell leading up to the machine stopping altogether,that would have been the pump cooking.New pump & computer board around $400 aus dollars,done by around $200-$250
May 22, 2010 | Fisher and Paykel GWL11 Top Load Washer
The drain/circulation pump quit on my fisher paykel gwl11
Checked the control board for a fuse.  Found two fuses on the printed circut board.  Checked both for continuity, one had none a 6.3 amp fuse sodered into the board.  went to a local electronics store and purchased a similar and replaced fuse.  Everything works fine now.
Jan 17, 2009 | Fisher and Paykel GWL11 Top Load Washer
Where are the fuses in a Sharp xg-nv3xb notevision3 projector
Main line fuse is on the board where the ac cord plugs.
The caps in the power supply usually leak and explode after 5 years, blowing the fuse. Solution is to replace the power supply and lamp ballast boards. Expensive repair.
Nov 09, 2008 | Sharp Notevision PG-A10X Multimedia...
Power Acoustic A3000DB mono amp problems
Broken legs on the rectifiers or an intermittently shorted common mode inductor would be the likely suspects. The common-mode inductor is just to the right of the capacitors in the photo. Install a single 15 amp fuse in ONE of the 4 fuse holders (other 3 fuse holders empty) and power up the amp. Twist the inductor to see if the amp draws excessive current (which would blow the fuse) or to see if it sparks.
Let me know if you have any other questions.
Oct 31, 2008 | Power Acoustik A3000DB Car Audio Amplifier
Fisher and Paykel GWL11 Top Load Washer Logo
440 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
