My television won't turn on.
My remote power button lights up when I push it, new batteries. The tv will not come on. I try to turn it on manually by the button on the side of the tv itself and it will not work either. The power button at the bottom of the tv is also on.
  • rachel678 Aug 29, 2008
    I tried to connect a new dvr system to the tv and now the tv wont turn on at all. I just want to cry... why wont it turn on????????
I unplugged the television for a few seconds, plugged it back up and woolahh, it was fixed. Thanks for all the tecknical support. Way to go guys.
Posted on May 24, 2008
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
Jun 05, 2012 | Mitsubishi WS-55909 55" Rear Projection...
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
The power and lamp light keep flashing, and the T.V itself wont turn off unless unplugged,
The tv projection lamp life are over.Ur tv require a new projection lamp replacement.U used a remote,tries to turn the tv off?Might have dead battery in ur remote?Tries to push the manual button on the tv on and off see if that work.Than it is the remote.
Nov 23, 2010 | JVC HD52G887 52" Television
I have a remote that i have had for a while and it stopped working. I changed the batteries but it still doesn't work. I have the codes for it but i missed placed the instructions on how to set the code....
turn on manually your set (tv), push the code button on your remote control until led light, release the button, the led still ligth. push the tv button one pulse, push the power button several times until tv turn off. when this happen push enter button... try turn on the tv with remote control.
Mar 20, 2010 | RCA Universal Remote Control
Turning on the monitor
Could the batteries in the remote be dying. Did you try changing them?
May 31, 2009 | Soyo DYLT032D 32 in. LCD Television
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Dec 31, 2008 | Disney 13" TV
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
TV will not turn off with remote or manual have to unplugged
I suspect the unit might need service. If it were only the remote, new batteries would, of course, be in order. But that part about the manual power button being ineffective suggests something else is affecting the set. Sorry.
Sep 27, 2017 | Hitachi 46GX01B 46" Rear Projection...
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Remote control
Does your remote have a button called TV. Press this first and then hit the power button and the TV should turn on. Remotes these days control multiple devices like DVD players and VCRs and you need to ensure that you have selected the right mode. Hope this solves your problem.
Aug 20, 2007 | Soyo GVTL3727AB Television
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
