Question about Canon Office Equipment & Supplies
I am just installing a new Canon MX7600. It says to not connect the USB cord but I did connect it and forgot to disconnect it before proceeding. When I started the machine I got an error message (5010). I turned it off and waited 5 minutes and restarted but got the same message. The book says to call a service rep if this happens. Any suggestions? Have I screwed this thing up?
  • johncoy May 23, 2008
    Thanks...but...
    How do you uninstall the printer driver. I haven't installed anything. I just attached the phone line and the power cord...and accidentally I connected the USB.
    I need to go away from my computer for about 1/2 hr. now but I will look for your response when I get back.
    Genius:
  • 2,035 Answers
Just uninstall the drivers and then reinstall it , if you problems you can contact the tech as this is new product,.
Posted on May 23, 2008
  • Anand Kumar
    Anand Kumar May 23, 2008
    If your not able to install the printer you need to call the tech support as your printer maybe dead or defective .You need to get a replacement printer for your printer ....................As this printer is new..............
    • Toll-free live technical support** Monday through Friday 10:00 AM ET to 10:00 PM ET (excluding holidays) at 1-800-828-4040
    • The location of the ASF nearest you for carry-in service at 1-800-828-4040
    • Toll-free TDD Support Line for the Hearing Impaired Monday - Saturday (excluding holidays) at 1-866-251-3752
    • Technical Support for Customers in Canada at 1-800-OK-CANON
    PS Dont forget a fixya rating!
    good luck.........................
  • Anand Kumar
    Okay you never installed any drivers then its the printer defective you need to get it replaced .....................
    Sergeant:
    Champion:
  • 277 Answers
Disconnect first the usb connection and uninstall printer driver... then restart your unit...
and install it again the printer driver.. when the message appear the printer is not connected its time to connect your usb cable power on the printer.
  • 135 Answers
Completely uninstall all the software you have installed and start the process over from the start.
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
It sounds like the printer has partially installed the drivers but because you left the device plugged in, instead of unplugged, it has failed to setup the printer on the computer.
I recommend uninstalling the printer from 'Control Panel' on the Start Menu in Windows. You can uninstall the software from the Add/Remove area of the control panel.
When this has uninstalled completely, unplug the printer USB cable. Shutdown the computer and wait a few moments.
Then , with the USB cable still unplugged, power up the computer and re-insert the printer setup disc.
This will prompt you to install the printer again, then plug in the USB cable when prompted.
Hope this helps.
  • Ryan Harron
    Ryan Harron May 23, 2008
    Hello again.
    On futher investigation, it seems some models of this printer are having problems with the scanner portion of the multi function device.
    I would contact canon on :
    Canon USA offers a full range of customer technical support* options:
Mx7600 error code 5c20 Problem
hi..............
Please remove all cartridges and print head. Using a moist cloth clean the golden contacts on Print head as well as printer. DO NOT touch nozzle of cartridge. Dont insert the cartridge yet.
Please do this :
1. Remove the power cable from printer. Remove the USB cable that connects printer to computer (remove it from printer as well as computer's usb port)
2. Press the printer power button and keep pressed for 3 minutes then release
3. Now plug in the power cable and usb cable (connect printer to computer) and power on the printer.
Then plug in the Print head and cartridges.
Now see if its working fine.
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | Canon MX7600 Office All-In-One Printer
How to change the ink on my Canon MX7600 printer
Turn the printer on.
Lift the printer cover until it locks in place.
The empty cartridge will be flashing.
Remove the cartridge by pushing the front clip and lifting it out of the carrier.
Remove the wrapping from the new cartridge and the orange protective cap from the cartridge
Insert the cartridge and press it down until it snaps in place.
Close the cover.
Run the nozzle cleaning utility and the alignment utility.
If you need a manual you can download the manual from
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=16506
Please rate this solution. Thanks.
Dec 17, 2009 | Canon PIXMA MX7600 Multifunction inkjet
Problem with installation
First Disconnect your printer
Reboot the computer
Start the installation from CD
Connect the printer when you see the screen to connect the printer
Once you connect the printer correctly to the USB it will proceed with the installation
Oct 07, 2009 | Brother Multi-Function Center MFC-240C...
Cannot clear "carriage jam"
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Jan 24, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Carriage jam
Nov 11, 2008 | HP Photosmart C4280 Aio Printer
Iphone is disabled connect to itunes and when i connect to itunes it says "cannot connect since it is locked with a passcode. unlock the phone. what can i do?
To get iphone to connect to itunes disconnect it from USB cord, press on/off button until you see slide to turn off, slide to turn iphone off. After iphone is off press and hold home button and reconnect to USB cord (do not release home button) continue holding button until you see itunes has detected an iphone in recovery mode then release home button. Proceed with restore.
Aug 10, 2008 | Apple iPhone Smartphone
Carriage jam/officejet G85xi
Jun 07, 2008 | Apple HP Officejet G85xi InkJet Printer
Lexmark 6350
Jun 01, 2008 | Lexmark P6350 All-In-One InkJet Printer
35 people viewed this question
old marine
old marine
