Can the sSpec number affect the compatibility with my motherboard or not?
I recently purchased the Intel Pentium 670 processor for my D915PGN motherboard. On the Intel site it says the board is only compatible with this processor with an sSpec SL7Z3.
The one I purchased is sSpec SL8PY.
I would like to know, will the sSpec number affect the compatibility with my D915PGN board or not?
Jessic L.
  • Computers & ... Master
  • 5,660 Answers
While both processors operate at a Frequency Rate of 3.8GHz, (3800MHz), and have a FSB of 800MHz,
the SL8PY uses the R0 stepping, (R-Zero), and the SL7Z3 uses the N0 stepping. (N-Zero)
[FSB = Front Side Bus]
Apparently the Northbridge of the motherboard chipset, won't support the R0 stepping.
[Northbridge for Intel is called the MCH, or IMC.
Memory Controller Hub, and Integrated Memory Controller, respectively]
The 'Motherboard Chipset' is the Northbridge/Southbridge chipset.
'Chipset' is a slang term for IC. Integrated Circuit.
Stepping is a design change to the same model of processor. There may be a few stepping changes, or many. (A0, B0, C0, Do, A1, A2, A3, B1, B2, B3, and so on) Just depends on what the engineers come up with, before the next model comes out.
Yes, I also checked Intel Support for the Intel D915PGN motherboard, and supported processors. I did not see a BIOS update for using a SL8PY processor either, in the Downloads section.
Posted on Sep 02, 2009
  • 49 Answers
I think it should work. Make sure you update your bios. I dont see why it wouldn work. I have an intel 640 processor and I loved it. I recently got a dual core but it should work in any recent(past 3 years) 775 chipset mobo.
Posted on Jun 08, 2008
Required Intel SL9CB Pentium, 3 GHz compatible motherboard
Pentium 4 HT, Model 531. sSpec number SL9CB.
OK. So far I know you need a motherboard that has an LGA 775 processor socket; needs to support Intel processors that are Single-Core, and with an 800MegaHertz Front Side Bus.
(800MHz FSB)
Ram Memory? Dunno. K
Do know the rule of thumb is, that the Ram Memory typically operates at Half of the processor's FSB.
Therefore can only assume the ram memory is DDR Sdram, and operates at 400MHz. (PC-3200)
You haven't stated the motherboard chipset that was used, OR what computer manufacturer, and model number; this mobo came out of.
Also didn't state if you are using a graphics card, and what kind it is.
(PCI, AGP, or PCI Express)
This isn't a 'guess-ti-mate'. Exact specifications are required in order to replace the motherboard.
Otherwise you may not be able to reuse the Ram Memory, or graphics card. (IF used)
Awaiting needed information. Post back in a Comment.
Oct 30, 2012 | Intel SL9CB Pentium, 3 GHz
My mobo compatible w this cpu?
CPU Support List,
Intel Pentium D model 830, Smithfield Core, sSpec Number SL8CN,
From all indications -> YES
[-> FOLLOW Anti-Static Precautions. A Processor is the most susceptible hardware component to Static shock.
Use good Thermal Paste,
Oct 09, 2012 | Computers & Internet
What is the meaning of the "sSpec Number" in specs of Intel Pentium D processors?
Hi ,Either SL94P (B1) or SL95V (C1) is compatible to your motherboard .
Thank you and goodluck.
Nov 29, 2011 | Computers & Internet
What processor can use to upgrade my Pentium 4 2GHz in my HP M1270
HP Media Center M1270n desktop PC?
Here are the Product Specifications,
Here is the Motherboard Specifications,
The Asus PTGD1-LA motherboard, is a Proprietary motherboard, made Especially for HP.
HP's name is PufferM-UL8E
You won't find it on the Asus Support website.
Fortunately, HP listed basic information for CPU (Processor) Support.
When you look to the right of the CPU/Processor heading, you can see it states -
A) Socket LGA 775 (Processor socket)
Looks like this,
Processors that fit this processor socket, have the socket holes.
775 of them.
The LGA 775 processor socket, has the pins that go up into the socket holes of the Processor.
775 of them.
[The Socket 478 processor socket, that was before the Land Grid Array 775 processor socket, has the socket holes (478), and the processors that fit this processor socket, has the pins. {478 of them]
B) Supports processors with up to a 3.8GigaHertz frequency rate.
['Speed' is a slang term for Frequency Rate.
Giga = Approximately 1 Billion
Hertz stands for Cycles per Second.
3.8 Billion Cycles per Second.
Can also be stated as 3800 MegaHertz.
Mega = approximately 1 Million ]
C) Can support Intel Pentium 4 processors with HT.
Hyperthreading Technology.
D) Looking to the right of the Front-side bus (FSB) heading, you will see it states -
This means the Asus PTGD1-LA motherboard will support Pentium 4 processors with,
1) HT
2) UP TO a 3.8GHz frequency rate
3) Up to a FSB frequency rate of 800Megahertz.
4) Use an LGA 775 processor socket.
Now let's look at one example, of a chart of Pentium 4's with HT, that fits these specifications,
See the heading - Prescott (90nm)?
This means the processors in this chart, are based on the Prescott Core, and the 90nm architecture.
(nm stands for NanoMeter. Approximately 1 Billionth of a meter)
Looking at the headings in the chart, you will see Model Number, sSpec Number, Frequency, L2-cache, Front-Side Bus, Multiplier, Voltage, TDP, Socket, Release Date, Part Number/s, and Release Price.
At this point I would only concern myself with the,
Model Number, (If applicable),
sSpec Number,
FSB, (Front Side Bus),
and Part Number(s)
1) Model Number:
The older Intel Pentium 4 HT processors did not have a Model Number.
Intel didn't start using a Model Number until later.
Model Number examples start with 517, 520, 520J, and so on.
Look for the sSpec Number, and the Part Number, for the older Pentium 4 HT's. They're printed on the top of the processor's case, and should be listed by the seller.
2) sSpec Number:
Intel brought this out.
Their way of marking a processor.
Another identifier for you to use.
3) Frequency:
The Maximum frequency rate, ('Speed'), that the Processor is supposed to be able to operate at.
4) L2-cache:
The small memory area for the Processor. The Processor accesses this small memory area first, because it operates at the same frequency rate as the Processor.
You can't change it, and 2MB of L2-cache, is the largest size for an Intel Pentium 4 with HT.
Just thought I would include this information.
(Ram Memory is next. Typically, Ram Memory operates at half of the FSB frequency rate. The Harddrive is next)
5) Front-Side Bus (FSB):
The frequency rate that the Processor transfers data (Information) to the Northbridge chip, and back from the Northbridge chip.
More on the Northbridge chip in a moment.
6) Voltage:
Pretty self-explanatory. The Voltage range the Processor will use.
You need the Voltage range of 1.25/1.4 Volts.
(1.25 Volts to 1.4 Volts)
Any Processor (That is Intel Pentium 4 HT, Socket LGA 775), that uses Voltage in this range will work.
7) Socket:
The type of processor socket that the Processor will fit in.
Has to be LGA 775.
8) Part Number(s)
Self-explanatory again.
The Part Number, that is stamped on top of the Processor's top case.
Part Number(s) is listed, because there may be more than one Processor in the Model Series, that fits the same specifications.
If there is no Model Number, refer to the sSpec Number, or Part Number.
The largest frequency rate (Speed) of Processor you can use, is a Pentium 4 HT that operates at 3.8GHz. (And fits in an LGA 775 processor socket)
Barring that a Pentium 4 at 3.8GHz cannot be found, you will know what Processors you Can use.
Scroll across the headings with your eyes, and start under the Frequency heading.
Find the frequency rate ('Speed') you wish to try.
Go across to the Front Side Bus heading. You should look for a processor listed that has an 800MHz listing.
Look at the Voltage.
All of the Intel Pentium 4 HT processors that fit in an LGA socket, use an 800MHz FSB, and are in THIS particular chart, fall within the same Voltage range.
Keep the Voltage range in your mind, as you look at the other charts below this one.
You know you need a processor that fits in an LGA 775 socket.
Look at the chart below this Prescott Core (90nm) example.
Prescott 2M Core (90nm)
Use the above criteria above in this chart.
I wouldn't recommend any Pentium 4 HT's, in the Cedar Mill (65nm) chart.
It isn't that the architecture is smaller (65nm), but that the BIOS program,and version on your motherboard, may not be able to handle these processors listed.
I also do not see a BIOS update for one, and for two, if you make a mistake when performing a BIOS update, your motherboard becomes an expensive Frisbee, or doorstop.
You also do not want any of the processors listed under the Pentium 4 Extreme Edition heading.
(Mobile Processors are for laptops Laptops are M-O-B-I-L-E)
Northbridge chip.
1) The Northbridge chip, and the Southbridge chip make up the motherboard chipset.
(Does not apply to the new motherboards that support the Intel i3, i5, and i7 Core processors)
2) Chip and Chipset are slang terms for I.C.
Integrated Circuit.
The Northbridge chip handles the faster processes of the computer.
Processor, Ram Memory, and High speed graphics.
(AGP or PCI Express. Not a graphics card in a PCI slot, nor Integrated Graphics on the motherboard. These are slower processes of the computer)
(CPU = Processor
Memory Slots = Ram Memory slots)
Looking at the diagram, you can see the slower processes handled by the Southbridge chip.
Looking back at the Motherboard Specifications, look across from the Chipset heading.
Northbridge: i915P graphics and memory controller hub
Southbridge: ICH6 Intel I/O Controller Hub 6
Uses an Intel 915P Northbridge chip, and an Intel ICH6 Southbridge chip.
Jun 27, 2010 | HP Media Center m1270n (PP132AA#ABA) PC...
Want to upgraded Pentium 4 2.8 GHz to Pentium 4 3.2E GHz
Yes, it will work just fine, as you can see for yourself - on the mb's link is the third processor from the second group (Prescott).
Jun 03, 2010 | MSI PM8M-V Motherboard
Hi dear can this motherboard suport intel pIII
Here are the specs. to this motherboard Product Details Intel 810E Chipset, Socket 370, Compatible Processors: Intel Pentium III Specifications Key Features Chipset Intel 810E Compatible Processors Intel Pentium III Processor Max supported CPUs qty 1 Socket Type Socket 370 Memory Number of Memory Slots 2 x DIMMs Audio / Video Video Out Ports 15 Pin D-Sub VGA port x 1 Other Features Package Qty 1 Chassis Type Desktopso to your queston... Yes it supports Intel PIII have fun >.<
Feb 25, 2010 | Dell (002TR) Motherboard
Compatible upgrade processor for intel pentium
The E5200 would be a nice upgrade. It retails on for 65-69.00 and usually has free shipping. And if you have a compatible motherboard and purchase a nice heatsink, it overclocks very nicely.
Aug 07, 2009 | Intel Pentium Dual Core E2140 / 1.6 GHz...
I have IBM p6 motherboard with processor Intel 1.8ghz/256/400/1.75v Processor had demaged. I replaced with Intel 1.8ghz/512/400/1.525v When I starts the system it gave error "0167 no processor bios...
I suggest this is not going to work.
1.Your motherboard is supplying 1.75 DC volts of electricity to the processor socket.
You have installed either a SSpec number SL68Q, or SL62P,
Intel Pentium 4 processor. (The sSpec number is on the top of the processor case)
These Intel Pentium 4 processors use 1.425 to 1.525 DC volts of electricity. If you haven't already, you are going to burn this processor up.
Also, the Intel Pentium 4 that you had before, is based on the Willamette Core. (180nm) These earlier Pentium 4's did not have HT.
The Intel Pentium 4 you have in it now, is based on the Northwood Core. (130nm) These Pentium 4's come with HT.
Even if you could go into your BIOS Setup utility, and change the CPU voltage, and lower it, the HT in the processor you have now, wouldn't work on this motherboard.
(CPU stands for Central Processing Unit. Another name is Microprocessor, or simply -> Processor)
You won't be able to lower the voltage in BIOS Setup, for this processor. IF you did, then you would change the Front Bus Speed, and the ram memory wouldn't work.
Obtain an Intel Pentium 4 processor, that uses the Socket 478 processor socket, has a 400MHz FSB, and is based on the Willamette Core.
Here is a list of Willamette Core, Intel Pentium 4 Microprocessors, that will work,
Apr 13, 2009 | IBM (25P3294) Motherboard
Procesoor problem...
You can go to Intel's website under support. Follow through an pick product type until you run into processor spec finder. If you look at the cpu, you'll see letters and numbers starting with SLxxx. An sSpec Number can be thought of as a specific sku, or version of a processor with its own set of characteristics such as Core Speed, Core Voltage, L2 Cache Size, etc. Every Intel cpu has it's own unique sSpec number. I hope that helps.
Jul 11, 2008 | Intel Motherboard
Computers & Internet Logo
385 people viewed this question
David Payne
David Payne
