Question about GE Microwave Ovens
Ge micro wave/ model# jvm1440bh01 manu 01 2005. All lights and turntable works,does not get hot. After it runs for a few seconds it changes to a lower and louder pitch. Tried to change power level and message comes up "Power level can not be changed at this time"
  • 3,037 Answers
Sorry to say but your microwave is done. The magnetron most likely is done just like a lot of other GE microwaves. I don't recommend buying another one from them. It will be much cheaper to buy a new one than repair the one you have. Please let me know if you have any further questions or anything else
good luck on getting a new one
Posted on May 23, 2008
  • Benjamin Patri
    Benjamin Patri May 27, 2008
    Did you confirm what I said or just buy a new one, if so then please give me some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    thanks and Have a Great Day!
    Genius:
  • 2,035 Answers
If the cabinet is intact and the door closes properly there is
absolutely no personal danger. Aside from the brain (timer,
temperature controls, etc.) there are four major components in the
cooking mechanism. They are:
1) step-up transformer
2) diode
3) storage capacitor
4) magnetron
The step up transformer supplies about 3000 volts ac which is
rectified to dc by the diode and stored in the capacitor. The
magnetron converts the high voltage dc to radio frequency energy in
the 3000 Mhz range which induces many small currents in the moist, and
conductive, food which causes internal heating by resistance.
Failure modes usually involve #2 or #4.
If the diode fails there is no heat at all and somtimes a loud hum or
buzz.
If the magnetron fails, the heat is reduced, or absent, and again can
produce a loud hum.
Snapping results from the microwave energy exciting some conductive
particles that can be due to residues in the cooking cavity, or
breakdowns within the magnetron itself. If the cooking cavity is clean
and there are no loose metal objects within it, you problem is most
likely to be a failed magnetron.
These can be purchased new for about $50 but there are tons of usable
parts from discarded appliances. A local technician should be able to
replace this part with a used one for less than $50 total. They come
in about 3 or 4 variations (physical mounting screws, etc.) but can
often be altered to fit safely and effectively.
IF the its within warranty get it replaced, I personally recommend a tech to work on it.......
Good luck..................
Micro wave GE space maker 1800 is heating food well but with noise and turntable not moving,,what could be the problem?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jan 23, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Ge eterna m#em03000hbb01 micro wave runs for a few seconds,then all symbols in display light up,press clear,it resets then have to enter time,am or pm and date. will acircut board fix this?
Hi, we get microwaves all the time at my shop, look usually they cost more to fix than a new one. They usually have a limited life, I advise you to ask for a 'Quote" and go from there at least that way you know to repair or replace.
Apr 08, 2010 | GE Microwave Ovens
Model JVM1650WH02 will shut off about 2 seconds or less into cook time. everything else works such as light and clock and sometimes the wave will cook.
magnetron is leaking internally, do not use until magnetron is replaced. the mag creates interference with the control board and resets it
Feb 05, 2010 | GE JVM1650 1000 Watts Microwave Oven
No heating, turntable does not turn, but clock & lights work.
Check to make sure the plastic on the shelve holders or tuntable guide did not wear and expose metal. If these holders or brackets are wore and exposed metal it shorted out your micro wave. They need to be replaced and a fuse needs to be replaced inside the control panel,
Sep 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Hotpoint Counter Saver Microwave not working
Please do not try to service. its dangerous to play with the internal parts of a Micro Wave. Most counter tops are pretty inexpensive buy a new one if the warranty is out.
Sincerely Steve
May 29, 2009 | Hotpoint RVM1435 Microwave Oven
My micro wave will not heat products. All other systems are functional.
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Aug 08, 2008 | GE Microwave Ovens
I have a JVM1603BJ03 space saver micro wave. The turn table cracked in two, the plastic support device to turn the glass table has desenigrated into several small pieces. It appears the micro wave is...
Do you cook a lot of popcorn?
Do you place your food items in the center of the turntable as opposed to placing them off-center?
Both can cause repeated heating of the same spot on the turntable, which can stress it and allow it to crack.
You can buy replacement parts here.
I suggest that when you cook popcorn, place a paper plate or two upside-down under the bag and always place your food items off-center on the turntable tray.
Once you have the new parts, I would suggest at least a quick heat test. That is to heat one cup of water on high and it should boil in about 2 to 2-1/2 minutes.
If you would like to perform a more standard heat test, please see my Ask Mr. Microwave page.
If your magnetron is indeed running too hot, then it is probably dying. Sometimes - like a star - they can burn hotter right before they die.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 04, 2008 | GE Microwave Ovens
Noisey turntable
try pulling on the plastic drive and inspect it you just pull up on it to remove it
Jan 30, 2008 | GE JVM1440 Microwave Oven
Microwave Ovens Logo
123 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
