Question about Gateway FPD2275W LCD Monitor
Inquiry if i on my computer monitor it will on but in a few second it will off immediately.
  • 1 more comment
  • Anonymous May 27, 2008
    monitor shuts off every few minutes. Have reset the screen saver display rebooted system unpluged monitor. Help
  • vicki97 Jul 15, 2008
    My monitor will only work for a short time and it shuts down. I will not even have a light showing that there is power to it. I would have to reboot my system and then it would work for only a short time then it does the same thing. I took my monitor to work and switch it with my monitor and it did the same thng. I do not believe it is a video card.
    I just bought the Envision monitor in November 2007.
  • pmulroy Jul 16, 2008
    My newly purchased/installed monitor 'blacks-out' about every 30 minutes. Your advice will be appreciated!
    Sergeant:
  • 458 Answers
Did you check the sleep mode or power off mode? What do you do to make it come back on? Sounds like it might be getting too hot and/or going bad. Try it on another machine and see what it does. Also try another video card because the video card could be going bad.
Posted on May 29, 2008
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
Primer;
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
OR,
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | Computers & Internet
How do I unlock the monitor, given that I have applied all the usual button pushing solutions bar 1?
If you see a picture but then it fades out after a few seconds then the issue is with the backlight power supply in your monitor, This could be a single component failure or more serious.
Mar 07, 2012 | Samsung SyncMaster P2250 22 inch LCD...
My hanns g hg216d monitor goes to a black screen after a few seconds when I turn it on. The blue light remains on but the monitor is black. Tested with my computer and playstation 3 so it is definitely the...
This has NOTHING to do with the OS or the computer. This monitor has an HDMI connection and you can connect it to anything (cable TV, DVD Player, game console, etc.) and it still will go to a black screen after just a few seconds from powerin on.
Aug 14, 2011 | Computers & Internet
Broken screen, external monitor via VGA won't
Press "Fn+F7" once, wait a few seconds, and press it again, to "cycle" through all the possibilities (LCD-only, VGA-only, both).
Try the monitor with some other computer (desktop or laptop) to see if the monitor works at all.
Restart your computer -- does the initial "splash" screen (showing CPU speed and RAM-test) show? Does the "Windows" screen (with the crawling worm) show on the external monitor?
Nov 16, 2009 | Lenovo 3000 N500 Notebook
Switch on-display appears,1/2 second disappears immediately.Have checked all capacitors on main pcb-all seem OK
Can you take a few pictures of the boards inside your monitor and email them to me at:
tech@ccl-la.com I will cross reference your power board and try to give you some help with it.
Buddy
Corporate Computer
www.ccl-la.com
Aug 19, 2009 | Computers & Internet
My Benq screen shuts down 10 seconds after switchung on
it may be overheat or check the cables it will properly connect or not(may be loose connection or damaged).
click this link for more info
Feb 22, 2009 | BenQ FP731 17" LCD Monitor
Desktop icon shadow in acer monitor as 1024*768 resolution
go into your graphics card config and change the brightness levels
Feb 03, 2008 | Gateway FPD2275W LCD Monitor
Acer Monitor
You're going to have to provide more info than that.
What were you doing when it happened? What are you typically doing when it happens? Have you checked your cables? Power connection?
As it stands, your inquiry will not receive much of a useful solution for you unless you let us know these things.
And don't rate me poorly for letting you know this. I'm here to help you. You have to HELP US help you.
Cyryl
Dec 10, 2007 | Acer AL1916B 19" LCD Monitor
Problem with the monitor
Have you tried another monitor on the PC? If the cable and connector pins are okay, I would suspect a problemn with the video / signal board inside the monitor.
Jan 21, 2007 | Sharp LL T17A4-B 17" Flat Panel LCD...
Gateway FPD2275W LCD Monitor Logo
21 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
