Question about Pioneer DEH-P3600 CD Player
No power got it installed and ready to go, but will not power up. all wires are matched correctly. fuses in both the deck and the car are good. cant figure it out...
    Genius:
  • Pioneer Master
  • 1,550 Answers
Maybe the audio IC amplifier are damaged.
Posted on May 23, 2008
Car deck memory issue
Is the fuse blown on the memory wire from the decks wiring harness. Also, makes sure memory wire and accessory wire are not flip flop.
May 24, 2012 | JVC Car Audio & Video
2003 hyundai tiburon dual din JVC touch screen deck installation issues
Hello, Chose another powersource for your device. It is possible that you are tied into a circuit breaker that is constantly resettting. Maybe use an MP3 player for the trip and work on it when you get back.
Dec 09, 2011 | 2003 Hyundai Tiburon
I have power but no sound
check ur wiring ur colors must match make sure all wires in the speakers are connect right and make sure the wiring from the deck to the amp if ur using an amp for highs are connected from deck to the amp power is good but both is better lol try that and get back to me i installed my own pioneer deck and 650 amp with 2 kenwood twelves works great
May 16, 2011 | Pioneer Car Audio & Video
The radio in my 1998 dodge neon doesn't work. Can you please tell me the possible solutions to solving this problem?
check the fuses, there may be one in the deck itself, if those are all good then make sure there is power going to the deck and that all the wires are hooked up correctly "they will be color coated", if it still doesnt work then you will need to buy another deck...do not throw away your old wiring harness it is nessesarry to install the new stereo
Oct 26, 2010 | 1998 Dodge Neon
I need to connect my remote wire to a accessory wire but i dont know which one is the accessory wire. I dont have that light tester thing so I cant try it out. I heard you can just tap it with some fuse...
The accessory wire that you are looking for is the one that tells the head unit to turn on when you turn the key in car. If you have an aftermarket deck then the deck has it's own for the amp usually it is blue and in your case may not be connected to anything. If you don't have an aftermarket deck you will need to find a wiring diagram for the car radio harrness and it will be labeled. You dont want to use any random wire because if that wire always has power your amp will stay on and kill battery. You can wire a switch if you choose this method to prevent that from happening. You may also try running a wire from main power of amp to a small fuse (remote uses less than 2A) then to a switch and then back to remote screw of amp.
This website has wiring diagrams but colors dont always match. http://www.the12volt.com/ Good Luck
Mar 26, 2010 | Kicker ZX10001 Car Audio Amplifier
NO POWER TO MY DECK
wire it to the live wire most older cars don't have 6 wire config while nearly all new stereos do connect all other wires as they were on the loome but wire the ignition wire to your cars live bypassing the ignition
Jun 01, 2009 | Pioneer DEH-2300 CD Player
Installing an aftermarket stereo, spliced the wires and have everything connected including the remote wire to the factory amp wire but still no sound.
There is no remote wire on these newer trucks....03 and up....u have to buy the harness....although i didnt....i have an 03 gmc sierra and just pulled the schematic and matched the wires. And there is no programming to do on an aftermarket stereo.....I work for GMC and we cant program aftermarket stereos......if u buy the right harness ...and its over $100 then everything should work just fine.....and this does not disarm ur alarm system either....mine still works fine....hope this helps
May 08, 2009 | 2003 GMC Sierra
Aftermarket Stereo connection
hi there
if you matched all the wires from the harness to the kenwood deck and its not working don't worry you just missed the last step........(all wires attached that a colour coded connected)
simply turn your car on.........now on the front of the kenwood deck there is a SOURCE button with all units it could be a (S, SRC, Power) hold the source button down till your kenwood unit powers up ..........if your unit still doesn't work check the fuse on back of kenwood unit should be a 10a fuse (blue) if the fuse is fine put the unit back in dash..........now check the fuse panel on driver side dash with the door open you will see this panel pull it off (some describe the fuse panel as looking like an air vent but its not its a handle to open) now on the panel that you just pulled off there is a fuse diagram on the inside look at it find radio fuse it will be a (blue fuse) located in the top row of fuses check it if blown replace and unit should work.............if this doesn't solve the issue than its a (sneaky) fuse not to many people know about if you pop the hood of your car there is a black plastic panel located just below the battery pins and just above the driver head light (usually black box with yellow writing on it......in this there are mini fuses check all of them do not touch the black relays in there just the small tiny fuses the fuse you will look at should be yellow 20a (this fuse is closest to engine and comes after the abs relay if you look inside the lid you took off it will have fuse locations cant remember which one it is for sure but check them..........now see if your kenwood unit powers up if not the last option is to ground to the black wire from back of kenwood unit to metal frame.............this last part is also done if your unit does power on but your car lights don't work if this happens ground the kenwood unit to the frame of car and open up fuse panel on driver side dash replace the blown fuse for lights or radio (make sure the kenwood unit is grounded to the frame before replacing the fuse in dash panel............if this doesnt help you than i would assume the kenwood deck needs to be repaired by kenwood.......
good luck
hope i was able to help and sorry this list is so long
Feb 26, 2009 | Car Audio & Video
How to install an alpine cda 9851
you go to a stereo shop..(walmart autozone etc should also do) buy a mounting kit and a wire harness adapter. The wire colors on the adapter match the wire colors of most aftermarket decks. MAtch the wire colors and connect...make sure to tape wires well as if they touch you rick damage to your deck.. install the mount kit plug in your cd player and slide it in and you are good to go..
Aug 21, 2007 | Alpine CDA-9851 CD Player
Pioneer DEH-P3600 CD Player Logo
56 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
