Question about Canon PowerShot A95 Digital Camera
Problem with A95
Mycamera was working very good before and now when i put on my camera,i think some window in the objectif is blocked andi can't take anymore pictures.
please help....
  • 2,016 Answers
Check this link. Although the specifics on this service notice are for US customers, the service notice is effective worldwide. If you're not in the US, you will need to contact the Canon service for your area.
Posted on May 27, 2008
Overcharged batteries used in A95. I put new Li ion batteries in my canon A95. Camera would not work after I did this. I took the batteries and tried checking them in a flashlight. When I turned the f
Lin, I'm afraid you are right. The camera should work on 4 AA Alkaline or NiMH rechargeable batteries. They give about 1,5 V maximal. The Li iOn batteries, almost deliver 2 V each. 4 x 1,5 (6) or 4 x 2 (8) gives a difference of 2 V. that is almost 33% to much.
But before you panic, Please first check if the contacts in the camera are clean and shiny. You can clean them (if necessary) with a dry cloth or cotton swab. Don't use anything sharp in or close to a camera.
Then insert new alkaline or NiMH barrettes, as shown in the manual and switch it on.
If it still does not work, contact a Canon certified repair centre and tell them what you did with the batteries and ask them if the camera is worth repairing.
Success
Nov 03, 2014 | Canon PowerShot A95 Digital Camera
The flas has stopped working on mycamera. It is
did you find out how to get it on because i cant and need help
Nov 19, 2009 | Sony Cybershot DSC-T200 Digital Camera
Unauthorized access blocked open process token
If you use another anti virus/spy program like Norton Antivirus which i suspect you are as you are using Norton Internet Security then you may not need Windows Defender running at all. If you think that Windows Defender is the culprit stopping your Canon application from running then why don't you stop Defender from running.
Open the Windows Defender program, click on Tools->Options, select Administrator Options, and uncheck the "Use Windows Defender box". Confirm that you do indeed want to do this, click Close.
Restart your computer and try running the Canon application to see if it has helped.
If it has then all's well, if you want to run Windows Defender again just follow the above steps and re-check the "Use Windows Defender" box again.
If this does not work please post back.
Good luck.
Sep 15, 2009 | Symantec Norton Internet Security 2009...
E18 error w/sound effects!
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 18, 2009 | Canon PowerShot A95 Digital Camera
Unrecognizable pictures with little color and horizontal lines
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jun 09, 2009 | Canon PowerShot A95 Digital Camera
My polarid izone 300 cannot on
ok the same thing is with mycamera so i took itapart while gight watb i did so i can put it toeghter
May 22, 2009 | Polaroid iZone 300 Digital Camera
I suddenly have white horizontal lines in the picture.
If it is Canon A95 camera then it has problem of bad ccd Image and needs to be replaced that part.
Canon will repair A95 for bad ccd Imager problem free of cost.
Please click Canon ccd Imager advisory for details.
Feb 10, 2009 | Canon PowerShot A95 Digital Camera
My Windows Vista isn't detecting my canon powershot A95.
hello before you do anything why dont you put in the camera,s cd to install drives,configuracion,folders,etc so you pc recoignize your camera......and if still in problems im sure is in your computer saludos
Dec 14, 2008 | Canon PowerShot A95 Digital Camera
Its how in the display format error.
Try this:
- Turn off your camera and take the batteries out
- Then take the memory card out
- Leave the batteries out for around 10 minutes
- Then put the memory card back in
- Then put the batteries back in and turn the camera on
- Try to see the pic/watch movie again
If this didn't work, check the memory card with a card reader...if it still gives an error then the card might have malfunctioned or needs a reformat.
Dec 14, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Canon PowerShot A95 Digital Camera Logo
44 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
