Question about LG Televison & Video
Dvd lg the image is black and white and sometimes its rolling
  • 8,596 Answers
I would need the exact model number to be sure, but there are 3 possibilities:
1) there are red, white and yellow (composite) cables plugged into a slot designed for red, green, and blue (component or YPbPr) cables
2) you have an S-Video cable AND another type of cable plugged into unit at same time
3)the progressive scan has been either activated or deactivated - read your manual to find out how to turn it off [warning: if I am wrong, then turning on the p-scan may cause you to lose picture which is difficult to reverse on some DVD models - I would definitely look into the other possibilities first]
Posted on May 23, 2008
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
What would cause my dvd player to roll horizonally and be in black and white?
One cause would be the PAL/NTSC would be selected, go to settings and change to auto or swap whichever is selected!
Feb 22, 2015 | Televison & Video
My lg dvd player doesn't show images (except the black and white diplay on the screen) but i can hear the sound playing, the kids might have changed some thing in the setup. please help if there a
Hello
You haven't given the exact model number ot your LG DVD, so I can only give you a general solution to this problem.
Get into its meny, surf through, come to SYSTEM adjust window, change the system. If a NTSC system recorded disc played with PAL system adjustment with DVD, there will be only black/white pciture, and vice versa.
Adjust it to the color system thathave been adopted your country. this must solve the problem. OK.
Jan 31, 2012 | LG Televison & Video
My LG TV has suddenly become darker all across the bottom of the screen (10cm strip) it still has colour but is darker. In left hand corner it is considerably darker and depending on what you are watching...
Hi; your TV has burn screen or traces.it comes from one image left on the screen for too long, it can get burned into the screen, making it visible at all times. You can actually eliminate most screen burns with the use of a PC computer and a black and white screen saver. This trick eliminates screen burn after a period of several minutes because the black and white screens flash quickly, removing all traces of color from the screen. This will eventually eliminate any burned images on the LCD screen. you can do it by creating a DVD picture slide with only black and white image. you can use a computer to make DVD picture slide first go to paint brush and draw only white then save as white.jpg. second burn it into nero or other dvd burner third play it to your DVD player connected to you LCD TV.it has to be played in full screen let the white image display on your HDTV for several hours or even overnight. It should remove any burned-in images or ghosts. hope this help...............
thanks....
Sep 13, 2011 | LG 32LD350 32 in. LCD TV
Moving from Ireland to Canada with Wii and DVD Player
Is it a new TV? I am not familiar with the Ireland/Canada signals. But it could be a PAL/NTSC conversion issue.
Jan 01, 2010 | Nintendo Wii Console
Components are in black and white instead of color
Wrong connection. Hook up the component output from DVD player or Wii to TV component input using component cable(red, green and blue plug)
Dec 29, 2009 | LG Televison & Video
When playing DVD, image sometimes dark incl. closed caption
1> sometimes supply of low voltage causes some disturbance in trasmitting video signals,it results in darker images while watching.
2> The DVD may have some scratchs or dust-spots or rough-coat on its recording surface ( reflecting LASER beam ) clean DVD and operate again.
3> your DVD player's SMPS (switched mode power supply ) circuitary fails to perform its function properly and giving irregular supply to video-audio card of the DVD player because of having some failure of electronics component housed on this circuitory.
4> switch the mode among 'PAL' , 'NTSC' , 'AUTO' and OTHER in playback mode options ,one by one taking  some minutes.
Now , your problem is solved , Enjoy,Bi.
Nov 29, 2009 | Sony Bravia KDL-32XBR9 32 in. LCD HDTV
DVD player - b+w rolling picture
it mey be change invideo out put has been changes i.e. ntse or pal mode to changes that mode on remote threr is p/n switch
Mar 03, 2009 | Televison & Video
Loss oF color
Bad chroma processor...accordianman
Nov 03, 2007 | LG V181 DVD Player/VCR
Televison & Video Logo
Computer Repairing
Computer Repairing
