Question about Cornerstone FIC AM37-L Socket A XP Motherboard W/ AUDIO, VIDEO, LAN (REFURBISHED) (FICAM37SOCKETAXPMOTHERB)
Power for HP554e
I do not beleve I am connecting the power cord from the front buton to correct location on my AM37 moterboard. How to I find the correct location to place it? I know I should done a better job of labeling the connectors, but I am an idiot. Now I am depending on someone else for assistance. Thanks in advance for any hep.
  • 55 Answers
I will try to help you. Locate a 10-pin connector below your backup battery. This connector has only 9 pins. It has four pins on the top and 5 pins on the bottom. Connect connector from your power button to the top row pins 6 and 8. Look at the diagram below I marked connection points with the “+” sign.
2 4 6 8
0 0 + +
0 0 0 0 0
1 3 5 7 9
Just for your references. Pins 2-4 for Power LED, 1-3 for Hard Drive LED, 5-7 for Reset Button.
Regards
Posted on May 23, 2008
Start button would not respond plug disconected unsure were it goes e machine c 1940
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
You want a Front Panel header pinout.
(See? Know you can go around, and brag to your friends!
"So,......mrcat_grave,.........do you know what a Front panel header is? What about a Front Panel header pinout? How about you Sally?"
Lol! )
Hmmm, I do not find an eMachines C1940 desktop computer.
Could this be an eMachines C1904, or S1940 desktop computer?
If so they both use an FIC AM37 motherboard,
(First International Computer, { Inc } AM37 is the model number of the motherboard)
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=bph07941&lc=en
(Scroll down for Motherboard Layout illustration, and Motherboard Photo )
Provided I am on the right track;
Motherboard installed in computer case:
Processor to the Top, Ram Memory slots to the Right, white long PCI slots to the Bottom;
The Front Panel header is at the Bottom/Right corner.
It is rectangular in shape, and situated Vertically.
Two columns of contact pins.
There are 4 pins on the Left side, 5 pins on the Right side.
(Do NOT get it mixed up with the IR header above it. 6 pins)
The pins are numbered EVEN on the Left side.
The pins are numbered ODD on the Right side.
Starting on the BOTTOM of the Left side, going towards the Top;
Pins 2, 4, 6, and 8. There is NO pin 10.
Starting on the Bottom of the Right side, going towards the Top;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
[LED = Light Emitting Diode ]
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C.
Not Connected. Probably a 5 Volt power source, used by the factory to test with.
D) Pins 2 and 4 are for the Power On LED. (Light)
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
Zip file PDF motherboard manual, for the FIC AM37 motherboard.
There is a version 1, and a version 2.
FIC AM37 v1, and FIC AM37 v2.
Doesn't matter which one you choose, as far as the Front Panel header pinout info is concerned.
You may however need info that is in the version 1, or is in the version 2.
You can download both.
Zip file. A compressed file used to send large amounts of information, more easily.
It needs to be decompressed, or 'unzipped'.
You have Winzip on your computer. It is an 'unzip' program.
If it is out of trial time, or not usable, suggest you download, and install the free 7-Zip.
Let's use the AM37 v1 manual as an example;
After you click on AM37 v1, a small window will come up on the right-
Opening am37_v1_manual.zip
Make SURE there is a Green dot, in the small circle to the left of Save File.
If not; click in the empty circle to the left of Save File.
Now go below in the small window, and click on OK.
A small window will come up on the left.
Allow the file to fully download in this small Download Window.
Then DOUBLE-click right on the file name.
In the next window go to the far left, and click on - Extract all files
At the bottom of the next 3 small windows, click on -
Next, Next, and Finish.
In the last window DOUBLE-click right on the file name.
(It is next to the red Adobe PDF icon)
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 17, 2012 | E-Machines Computers & Internet
08:11 error in hp designjet t1100
System Error: 08:YZ
Problem Description: Problem with the Front Panel.
Corrective Action: Try the following:
  • Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
  • Check that the Front Panel interface cable is not damaged and is correctly connected between the Main PCA and the Front Panel.
  • Check that the memory module in the Formatter is installed correctly.
  • Check that the connections between the Formatter, the Formatter and the Formatter are not damaged and are correctly connected.
  • Check that the Printer has the latest Firmware version. If not, update the Firmware to the latest version.
  • If the System Error continues, replace the Main PCA
  • If the System Error continues, replace the Formatter
  • If the System Error continues, replace the Front Panel
Jul 27, 2011 | HP Designjet T1100ps Printer
Orange light flashing in powercell pack.console not turning on. tried different powercell pack still not working .used power surge adapter
Hi,To troubleshoot this problem, try the following steps:
Examine the power indicator light that is located in the center of the Ring Of Light on your Xbox 360 console. If there is no power to your console, the indicator light is off and the fans are off.
* Press the power button. The power button and the power indicator light are located in the center of the Ring of Light on the front of your Xbox 360 console. If your Xbox is functioning correctly, the power will turn on.
* Press the eject button on your console disc drive. If your console turns on when you do this but does not start when you use the power button, there may be a problem with the power button or the console faceplate may not be attached correctly. Contact Xbox Customer Support for more help.
If the above step does not resolve the problem, examine the power cord where it connects to your console and to the power outlet. Disconnect and then reconnect the power cord at each end to make sure that you firmly connect the cord.
If this does not resolve the problem, see whether the power cord is plugged in to any device other than a typical power outlet. For example, the power cord may be attached to an extension cord. If this is the case, remove this device and then plug the power supply directly into a power outlet.
If the problem is not a connection problem, examine the light on the Xbox 360 Power Supply.
* A green light indicates that the power supply is functioning correctly. If the light is not green, contact Xbox Customer Support for more help.If these steps do not resolve the problem, your console needs service.
Thank you!
May 11, 2010 | Microsoft Xbox 360 Console
Does an emachine w2047 motherboard have a 4 pin
Hi
Thank you for your query
Your motherboard is a AM37, this does not have a 4 pin connector so therfore you do not need to connect it of the power supply
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 17, 2010 | Computers & Internet
Ipod touch 16gb, passcode forgotten screen reads disabled.
well you can conpleatly restore it by no luging it in and holding the power buton for 3 seconds then with out leting go of the power buton hold the home buton for 10 seconds then let go of the power buton and just hold the home buton for a further 30 seconds.....
after you have done this plug it in to your computer with iTunes allready running and a icon should say unresponcive ipod or somethin along those lines just click RESTORE
hope this helps
dale gough
Jul 21, 2009 | Apple iPod touch
Fic am37 manual
I found exactly what I was looking for at this link, ftp://ftp.fic.com.tw/motherboard/manual/socketa/am37
Sep 03, 2007 | FIC AM 37 Motherboard
Travelmate will not boot up
Not booting
Laptops:
1. Unplug Ac power cord and take out the battery
2. Press and hold power buton for 25 secs (yes without cord and battery)
Desktops:
Feb 08, 2007 | Acer TravelMate C112TCi-SP2 Tablet PC
Cornerstone FIC AM37-L Socket A XP Motherboard W/ AUDIO, VIDEO, LAN (REFURBISHED) (FICAM37SOCKETAXPMOTHERB) Logo
150 people viewed this question
Top Cornerstone Computers & Internet Experts
SHIVAJI YADAV
SHIVAJI YADAV
 steve
steve
Prariehog
Prariehog
Are you a Cornerstone Computer and Internet Expert? Answer questions, earn points and help others
