Once you have the new drum unit, and are ready to install, just open the front door. Slide out the toner cartridge/drum unit combination assembly. Press the release tabs on either side of the toner cartridge and lift it up and out of the drum unit. Set it aside. Unpack the new drum unit and go over the installation instructions if you have them. Basically you are just removing all of the packing materials for the drum unit. Once that is done you need to install the old toner cartridge into the new drum unit. It just slides in and locks down. Then install the whole assembly back into the printer.
Leave the front door open, and press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
This should complete the installation process. Just run a test copy to verify all is well.
Good Luck and Thank You for using Fixya.
