Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
OVEN WONT WORK!! WE HAD A BRIEF POWER OUTAGE AND THEN WENT TO USE THE OVEN AND NOW IT WONT WARM. YOU CAN HEAR THE SPARK IGNITE BUT THE OVEN DOESNT GET AFTER THAT!! HELP!!
  • Anonymous Dec 06, 2008
    oven and broiler won't work and given an f 3 error
    Scholar:
  • 170 Answers
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition
Posted on Jul 20, 2008
Oven ignitor intermittent spark, oven wont light, emits gas.
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Mar 13, 2015 | Ovens
Gas wall oven wont come up to temp.
ELECTRIC OVENS:
Apr 07, 2014 | Frigidaire FGB24S5A Gas Single Oven
NATURAL GAS OVEN WONT COOK PROPERLY
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
ELECTRIC OVENS:
Apr 06, 2014 | Frigidaire Ovens
Frigidare gas oven wont ignite
ELECTRIC OVENS:
Feb 07, 2014 | Frigidaire Ovens
When Thermador oven is on and the simmer burner on low-low and the igniter sparks, the oven shuts off and the clock blinks (as if there were a power outage).
Check your earthing, all the way back to the earth stake too for safetys' sake!
Otherwise, try lighting the burner with a gas match instead of the peizeo ignition module >> check ignition module
Oct 16, 2013 | Thermador Ovens
Oven pilot went out due to power outage. I don't know where the pilot oven light is. where is the pilot light to light the oven?Ge XL44
pilot over lights do not require power to stay light or should it go out in a power outage! do you have to normally light pilot with a match? if not you have a glow coil and its a electronic ignition range and power will affect it. once power is restored you should just be able to turn on over and everything would be ok.if it is a pilot light you need to remove the bottom door stick arm in to back and you'll see the pilot assembly at back if you look up! hopethis helps...
Feb 06, 2010 | GE Ovens
We has power cut put power back on switched oven on it wont get warm
Make sure the oen has not gone into Auto cook mode. This sometimes happens after a power outage.
Try resetting the clock and if the is an Auto/Manual button press this also sometimes this does the trick.
Jan 01, 2010 | Neff Ovens
Ignition wont stop while oven is working
Egnition is a push button to a spark generator, If this is electric, the obvious answer would be turn off the electric. This should not affect the gas unless if is temp controled by electric. Usually the temp is set gy a gas regularor controlled with a knob and set before gas is ignited.
Feb 11, 2009 | DCS Large Appliances Built-In Ovens...
VulcN MODEL gc04C CONVECTION OVEN WON;T IGNITE ER-05 CODE
Like an electronic igniter for a gas grill? I believe you can pick up a replacement. Call Lowes or Homedepot. I know i have saw individual igniter's before my friends bought some for my friend and I when we were little to make potato cannons.
Jan 22, 2008 | Vulcan GCO2D Gas Single Oven
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
157 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
