Question about Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700
The unit has stuck on "Temperature below safe level". I live in Georgia. It is not cold nor have I ever seen this screen before. What do you suggest?
Herb
  • Anonymous Aug 09, 2008
    I have the same problem.. I have tryed reconnecting the hard Drive But the problem IS still there "Temperature below Safe Level " I can here a Clicking From the Hard Drive.. Once it started to a frozeen map.
  • Anonymous Aug 11, 2008
    I opened my unit to check the hard drive and the cable seems to be correctly connected to the circuit board and the hard drive. It will not boot properly unless the unit becomes warm to the touch. The small GRAY cable spoken about in the earlier post connects from "J6" (near the antenna connector) on the same circuit board where the hard drive connects. The other end of the small GRAY cable connects to the second circuit board mounted to the back of the case (next to the speaker) near the hole which the antenna connector passes (also near "U39" on the board.
Had the same problem. It was the ribbon end of the hard drive connection the slips into a slot on the board. I carefully positioned the cable in the slot (there are no guides) and gently pushed it in. Powered it up and, walla, it worked perfectly. Thanks for the tip.
Posted on Aug 18, 2008
Thank you, I did refit the hard drive connection and heard it snap. Unfortunately I seem to have disconnectoed a gray cable that goes from a J6 position to another board. Too tiny for these eyes to see let alone reconnect. Any idea what it is for?
Posted on Jul 25, 2008
I had a Roadmate 700 with the same problem as yours, and the solution was simple: the hard drive inside had come loose!
All I did was open up the unit (4 screws on the back and a small snap-together clip on the end), and plugged the hard drive back into the cable. The cable has 2 black posts that fit into the hard drive, so you can't misalign the pins. On mine, the hard drive label was facing UP.
Once the hard drive was plugged in, I powered up, and could hear the hard drive spin up (which I hadn't heard before). The unit booted from the "Magellan" screen right into the menu almost immediately!
Hope this helps someone!!
Posted on Jul 24, 2008
When i power up my roadmate 700 a message comes up that saysTemperature below safe level. mTake several minutes to warm up. but nothing happens even when its warm
Had the same problem with my MRM 700 back in 2005, only 2 months after I purchased it. They changed the connector, and it worked. BUT, few months later I had the same problem again. I haven't used it anymore since then (moved to another country), now I am trying to fix it but no warranty anymore..
Jan 28, 2010 | Magellan RoadMate 700 GPS Receiver
All navigation units are GPS Receivers - that is - they receive satellite signals. So, no there is no difference.
Apr 19, 2008 | Magellan RoadMate 700 GPS Receiver
Magellan roadmate 700 "powerup problem"
Apr 01, 2008 | Magellan RoadMate 700 GPS Receiver
Roadmate 700/760 freezing/locking up
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.
Feb 29, 2008 | Magellan RoadMate 700 GPS Receiver
Power wont come on
get a new unit like any magellan mastreo series 4000 or higher or roadmate 800 or higher,i had a 700 they start having alot of problems after i did my research on here.i have the mastreo 4000 and the roadmate 800 both work great.
Feb 23, 2008 | Magellan RoadMate 700 GPS Receiver
The most obvious question is, have you accidentally turned down the volume to a level where it can't be heard. There is a volume wheel on the unit. Also, there is a way that the sound can disappear if the unit gets "locked up". But that shouldn't be a persistent problem. Removing the power cord and reinserting it should clear that problem.
Dec 09, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 GPS
If everything else is working fine, specifically the touch screen, then it's probably your speaker. open unit and check your speaker for anything stuck to the back of the magnet (on the speaker). make sure the cable going from your speaker to the keypad PCB (board) is pushed in all the way. you may want to even pull it out and re-connect it. make sure the unit is off while you do this and try to ground yourself with something. good luck and let me know how it turns out.
Mar 04, 2007 | Magellan RoadMate 700 GPS Receiver
I've fixed that error by swapping out the PCB board (or the keypad board). Which you can't very easily do that.. unless of course you have a boneyard of these lying around. Additionally, it could be the Hard Drive, this error hasn't been narrowed down to any one specific cause to my knowledge. I'll take it off your hands if your going to buy another one though. Respectfully, -Dan
Oct 24, 2006 | Magellan RoadMate 700 GPS Receiver
Temperature below safe level warning when starting GPS
Ahh yes the ever so elusive temp. below safe level error. lol. (sorry) Attached to the radio board are 3 wires connecting to the top of your lcd. This is where the temp is read from. I know telling you this doesn't help, just info. This problem has been fixed from swapping out radio boards (the board that's behind your keypad), additionally swapping out hard drives. I'm not sure if the unit will detect the USB but, if you can, try re-loading whichever version you have ie. 4.32/5.14. As far as end user fixes, I don't exactly have one unless you can find a scrap unit that someone doesn't want b/c it's malfunctioned as well. Good luck and I wish I could of been more help. -Dan
Sep 24, 2006 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
112 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
