Question about Kenmore Elite 45986 Front Load Washer
F 14 kenmore elite he 4t quietpak9
F14 or f11 or dl thanks
I have the same problem
Posted on Sep 22, 2008
  • kuntil Sep 22, 2008
    f11 and dl
  • 725 Answers
You have a fauilty control .
Posted on May 27, 2008
My kenmore elite HE 4t washing machine will not start. error message dL. It has happen before but I was able to get it started and working for several weeks till now.
'dl' stands for Door Lock (Error). There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 23, 2011 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore Elite washer. I keep getting a F 14 code and a DL F code. What do I Do?
I understand that 'F14' for Kenmore (Whirlpool) machines decodes as 'EEPROM failure' (control unit) and 'DL' is Door Lock- a problem with either the door solenoid/lock or the 'door closed' sensor.
Sorry but I fear both F14 and DL require a service engineer's attention ;-0(
Good luck,
John C
Mar 21, 2011 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite smartwash quietPak9. I continue to get an F11 code and a dL code. What does this mean and can it be fixed?
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
F dl Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
¦ Door lock mechanism is broken or removed from door.
¦ Door switch/lock unit failure.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Your tech sheet is attached to the base panel.
Use that tech sheet as a guide for diagnostics.
Use this service manual to ID and exchange parts
Jan 21, 2011 | Kenmore Washing Machines
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
Kenmore elite he14. What is the f14 error?
EEPROM Error
The Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU.
If there is an error reading this data, it will cuse this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 18, 2010 | Kenmore Elite 45986 Front Load Washer
My screen in showing code "dl" and then "f", please help?
The "dl" code is "doorlock" indicating a problem with the door locking mechanism or switch
Apr 19, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite washer f11 f14 and dl codes
Replace the CCU it is your only choice. They do not make bandaids for washing machines. If you dont fix it you will just have a non working machine soon
Mar 31, 2009 | Kenmore Washing Machines
F11 CODE
you have bad communication ,,between the control board and themotor control board..,,check for a lose harness at booth ends
Dec 28, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
923 people viewed this question
Sal De
fordexpert
Robert Rankin
