Question about Nokia 6233 Cellular Phone
Formatting Memory Card
Nasir, thanks for answering my earlier question. I assume formatting my memory card is similiar to formatting a PC drive. Is there any format that I should follow - NTFS or FAT 32 for example?
Thanks in advance.
  • MangoCut May 24, 2008
    Thanks for your help.
  • 282 Answers
You must format your mmc's as FAT.............not FAT32 or NTFS
Posted on May 23, 2008
I forget password of sandisk 2gb micro sd memory card
you can unlock your sd card by formatting*.
formatting memory card will delete all datas
formatting method*
use a softtwaer phone for formatting.. (example nokia 6120c, 5800etc )
insert your sd card into the softwaer phone.. select SETTINGS > DATA MGR > MEMORY > OPTIONS > FORMAT MEMORY CARD
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
Sd card format software
Start up a computer with Windows XP, Vista, or Windows 7. Insert the SD card into an external memory card reader or into the computer's built in card reader. If it the first time a SD card has been inserted into the computer, Windows will recognize the SD card and automatically install drivers to read the memory card.
Go to the computer view by clicking on the windows start menu icon in the bottom right corner of the computer. In Windows 7 and Vista click "Computer". In Windows XP click "My Computer"
Right click on the SD drive under the computer heading. A dialog box with different options for the drive will appear. Click on "Format" to bring up the formatting dialog box.
Select the type of formatting (also known as file system format). In Windows XP or Vista there are several choices including FAT, FAT 32, and NTFS. In Windows 7 there is an added choice called exFAT formatting. This is an improved FAT formatting type with improved meta data capabilities. Choose the formatting type, name if the drive if desired, check or uncheck the "quick format" option, and press the "Start" button. When the SD card format is complete Windows will provide a notification.
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 17, 2011 | Computers & Internet
8GB SD card says: MEMORY CARD REQUIRES FORMATTING After selecting continue SD card says: FORMATTING WILL DELETE EVERYTHING ON MEMORY CARD after selecting continue it says: FORMATTING... but then returns...
i guess you are using it thru a USB, try a differnt USB port if you have more than one USB port on your PC....else
try it on a different PC
a longer solution is to get a low level format software like "killdisk".....this is also a DOS based application....install it and use the in Win or thru a boot diks DOS application
revert back
Jan 06, 2011 | PNY 2GB microSD Memory Card
4gb sd card not format problam format uncomplet
I'm assuming you are having a problem formatting the memory card?
The soultion would be to connect it to a PC or laptop that has a card reader installed, then format the card via Windows.
If it is a micro SD card, you may need an adapter to convert it to a SD card.
Aug 11, 2010 | SanDisk 4GB microSD High Capacity Memory...
My 1GB micro SD memory card needs formatting. But, when I am formatting it fails. ?What should I do?
Try formatting it in another device such as another card reader with another PC or formatting it in a digital camera
If that doesnt work, its likely the card is dead
Jul 21, 2010 | SanDisk 1GB microSD Memory Card
I have a 2 g memory card which when full I uploaded to my PC and then deleated all photos from the memory card I tried to use this card again but the camera tells me the memory card is full also it tells...
Exactly the same problem occurred with my San Disk 1GB micro-SD Memory Card. And I solved this problem formatting my micro-SD Memory Card using a software which you can download by clicking here.
To format your micro-sd card:
- First plug in your micro-sd card into you PC.
- Run the installed "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your memory card).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
That's all my friend. This solved my problem and I hope this helps you too.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 11, 2010 | SanDisk 2GB microSD Memory Card
I inserted a PRO Duo card in a PRO reader (no DUO) and now the camera won't recognize it
It's possible the memory card just needs to be formatted again. Formatting will clear off all data on the card however.
In order to format the card you will need the proper adapter to connect it to a pc. Once it is detected by the pc you can go to the drive in "My Computer" in XP (or "Computer" in Vista), right-click, and select "Format". This is all assuming that you have it connected to a Windows pc.
Jul 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Installing line comes up after each restart.
did you tried to format your memory card via phone? if not, try it go to tools then select memory card, click option them select format memory card, then try to install some java applicatins. good lack
Jul 20, 2008 | Nokia N73 Cellular Phone
Memory Card!!!!!!!
format a memory card through DOS mode
GO on command prompt then go on drive of memory card e.g. remove device f
Mar 13, 2008 | Kingston flash memory card - 256 MB -...
Memory card formatted in error
Once the memory card is formatted, the files saved or pictures will be deleted and there is no way to retrieve the images.
I would advise that you transfer the pictures first to your PC before formatting the memory card.
Sep 25, 2007 | Cameras
Nokia 6233 Cellular Phone Logo
73 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
