Question about Microsoft Windows XP Home Edition
Installation stall with 39 minutes remaining
I've reformatted several times (complete, not quick) and now it doesn't even copy all the files to the windows installation folders...42 to be exact, but I click "skip" and it tries to install, as before, but it stops with 39 minutes to go, same as when it did copy "all" files.
I also tried installing on my other HDD in the same computer and the same result; happens with "different" installation disks, too.
Any help will be appreciated, a Microsoft wants to charge me!
Thanks, Gil
  • 2 more comments
  • gilhow May 23, 2008
    It's a generic (I put it together) AMD 64x2 2.1 Ghz, 2GB memory, 500 GB SATA HD, Gigabyte board (GA M55plus-S3G. It also has 160 GB ATA drive. I have onboard audio, video, but had a GeForce NVidia card in the PCI express slot, an USB 2.0 PCI card, TV card, ethernet card and guess that's it, BUT, I've taken them all out, disconnected my CD drive (leaving in the SATA DVD drive) disconnected my ATA HD, disconnected my USB printer and still nothing is installing past the 39 minutes left. I'm getting two error messages: 1. Isass.exe is missing 2. An invalid parameter was passed to a service or function (this now shows so fast, I can't read it; used to see it more clearly). Also, used to get: cannot find ntldr, but the new OS XPSp2 Home disk I bought today, seemed to fix that, as it hasn't reappeared. Also, I flashed the Bios. Thanks for your interest...I'm beginning to think it may be a form of the sassar virus???
    Gil
  • gilhow May 24, 2008
    Worldvet, thanks for the input. At this point, I'm progressing slowly...I have actually installed one copy of XPHome (a really old upgrade disk I had) on each drive; my 160 GB ATA and my 500 GB SATA. I just downloaded SP2 on the ATA drive. My SATA drive only shows 137 GB, of course, since it was an XP install without service packs. So far, I have not been able to get my OEM disk (with no MS support) to install past the 39 minute barrier, but will try again in a couple of days. You asked if I had virus protection turned off in the BIOS...it's not available in my bios, but I have seen that option in older boards. It wouldn't be a problem, anyway, as I've reformatted both HD's about a million times, so unless it's hiding, it shouldn't be the culprit. The one thing that helped the most seemed to be changing my new memory back to my older memory sticks. Also, I've taken every card out of my PCI slots, disabled everything "onboard" except for my keyboard and mouse (USB), disconnected printer, etc. At this point, I can't even be sure what has helped the most and plan to keep working on it until I can install XPHome SP2 as a fresh install on a newly formatted HD and have an active 500 GB available.
    Gil
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    When I read your post I went through dejavu and have been trying to recall the what and whys of how I resolved the situation when it occurred to me. I too built myself a dual core AMD x64 and installed Windows extended 64 edition and had two sata drives in a raid array but that wasn't the box that caused my dejavu. I work on a lot of machines over the course of any given year and its hard to recall which one. That's why I asked about the devices. Sound like you know what you're doing for the most part to me, by removing everything that windows installs as a device.
    I was thinking it might have been a lack of space on the temporary area of storage Windows uses to work from while installing.
    I would lastly ask if you have bios virus protection off or not but you probably know about that. Otherwise, I'd get a hold of a copy of Hiren's Boot CD and use one of the utilities to do an ACTUAL low level format in case it is a boot sector 0 virus. I had to do that recently with a laptop for a college kid.
    Sorry for your troubles.
    Worldvet
  • Glenn Rogers
    Is this a tower PC with peripheral devices installed in the PCI slots? Or, are they all onboard and enabled in the bios setup screens?
    Worldvet
Install Linux
Posted on Jun 27, 2008
    Guru:
  • 859 Answers
Sound like the memory then. As we all know its a process of elimination. That said, I've never been able to do a clean install with a USB keyboard and Mouse. I always reverted to a PS2 keyboard and Mouse as those drivers usually need to be installed separately was back from the Windows 95/98 days, but that doesn't mean you shouldn't be able to do so with XP.
Your OEM disk could be bad. All you need is the Product Key, so you could download an iso image and put it on a drive to install from there. All this you probably konw.
Anyway, you are doing everything as I would have done. You should join us here at Fix Ya and become an Expert. Its stimulating to help out with this board as it is extremely challenging, much harder than fielding a phone call.
Good Luck, but you'll do fine.
Worldvet
Posted on May 24, 2008
Why can't i sometime complete copying large files
There can be several causes for this. First less Harddisk space as compared to that required by files being transferred. Two, the mother DVD is corrupt or has a cyclic redundancy try a clean DVD. File format on your DVD may be incompatible or even contain a malware!
Jun 14, 2013 | Computers & Internet
Phone is locked
I took the battery off completely and waited about 5 minutes, then replaced it. Worked fine after that. If that doesn't work, try googling the makers and see if they've got any quick fixes for you.
Oct 24, 2012 | Nokia Classic 2330 Cell Phone
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
Hello! when i press the shutter button, it makes 3 beeps and doesnt take any video or photo even if there's enough place. what can i do?
I found out that my GoPro was saving data on the card that was not in any file. If you have lost data, when the camera runs for a while and the PIC file shows zero K, then when you delete the file, the random data stays. I got the first few minutes of a couple of sessions, then the camera shut down. Put your card in a card reader on the computer and right-click and check the card for usable space. You might find that it's full of random data not assigned to any file. Then you have to reformat the card to clear it. Just deleting any PIC files so it says 'no files found' doesn't mean the card is cleared.
If the card has space, you have some other problem, sorry. But I regularly reformat the cards just to make sure they are clear after deleting files. The GoPro doesn't care, it just thinks it's a new card and inserts it's file routine.
Aug 07, 2011 | GoPro Digital Hero 3 Digital Camera
I have a 1992 Chevy 1/2 ton 5.7 Litre 1500 series truck. The truck while idling suddenly stalled. I verified the fuel pump by taking the pump side off to the filter and verified fuel to the filter by...
Doesn't sound like you've considered spark. Sounds like you're losing spark somehow. You seem to know your way around a truck, so I don't have to explain every little thing. Just check all the ignition stuff, go through the distributor and coil and plugs and wires. If it's gettin fuel, its either a spark issue or air/vaccum issue. Hope this helps.
Jun 12, 2011 | 1992 Chevrolet K1500
My mp3 player doesn't want to play songs no matter what i do. i've placed songs in it, but it just keeps deleting them all the time. also, even if it does play, only fragments of the song are...
MP3 players can only play music files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
May 24, 2011 | Jwin MP3 Player
My new Eclipse Cld Mp3 player says it has no files, even when I've made sure files are on it. Why is this?
This same thing happened to me. Here is what to do.
**********Before you do this make sure that you have copies of everything that you have on your mp3 player somewhere else because they will be erased from the player.********
1. Plug your player into your pc
2. Go to the start menu and select "computer" or "my computer"
3. Look for your player. It may say "removable disk" or "eclipse" or something. VERIFY THAT IT IS INDEED YOUR ECLIPSE PLAYER. If you do not verify it then you may severely screw something up or could potentially lose important files.
4. Once you are POSITIVE that you have found your eclipse player, right click on it and select format.
5. Make sure that you have selected "FAT32" as the file system
6. Uncheck the box labeled "quick format"
7. Click the "start" button
8. Wait for the Formatting to complete. (it will take a long long time)
9. This is also important. Always us the "safely remove hardware" feature in windows before disconnecting your player. I think this is why the issue came up in the first place.
For me, It took 3 attempts at formatting for it to work. So if it doesn't work the first time, just do it again. You aren't harming anything as long as you've backed up your music.
Hope this helps.
Oct 31, 2010 | Audio Players & Recorders
Could not copy files, such as wmp.dll, during reinstallation
clean cd. try agen, repartition it agen may be the wrong size. reformat it agen. windows xp cd in. hit continue each time. you could try a new hard drive, and get a new windows xp from ebay.
I only use AVG at http://avg.download-go.com/ its free and has never let me down.
Mar 17, 2008 | Dell Microsoft Windows XP Home Edition
Microsoft Windows XP Home Edition Logo
2,027 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
