Question about Gateway 7330GZ Notebook
My recovery CD (gateway 7330gz PC) are no working
I Am triying a full system restore (destructive) using gateway system recovery windows XP hard drive. The disk seem to work well. The problem is that when windows XP setup begins. The computer freeze haft way throught the installation devices.
  • 5 more comments
  • Anonymous Jun 20, 2008
    help us please
  • Anonymous Jun 29, 2008
    I have the exact same problem. I did make a little progress... I took out the HD and put it into an external enclosure, ran disk cleanup, and defrag. Put it back into the Gateway, and it made it further than it did in previous attempts. But, it still is freezing and won't come back to life. I'm now looking for a new HD to stick in and try....
  • thelilpoint Jul 31, 2008
    I have this same notebook and i have the actually solution guys. No need to thank me but ok so the problem is xp won't install because it hangs on installing devices about the halfway bar. The solution is to once the notebook boots up, press F2. Once you have done this, a menu of some sort pops up and scroll to the advanced column by pressing the right arrow key. There are a series of options in which enabling and disabling is an option. Well i simply disabled most of the middle options except maybe networking. Then i installed xp and with no problem. After i enabled the options once again. The only problem you may face is a sound card issue but not to fear. Go to gateway and look up this notebook model for the correct driver and Bam! you are done. I am not computer genius or anything i just tried hella **** to get this done.
  • courtlegend Dec 09, 2008
    I have a similar problem it seems...
    My laptop has been down for a while, and I reformatted my C: drive a while ago, all my stuff is on a partitioned D: drive, and then when i tried to reinstall none of my windows xp cds would work (i guess my dvd drive is broken?) but when I put in the recovery cd i can hear it loading...
    so it brings me to this..
    my screen won't go past this problem, when i load this comes up
    BROADCOM UNDI PXE 2.1 (BUILD 082) V2.0.4
    and then it does something for about 10 seconds then asks me reboot with a boot drive
    help?
    oh ya, and it after the 10 seconds it says MEDIA TEST FAILURE... ???????
  • bknoyes Apr 10, 2009
    I have the same exact model and had to do the same thing 3 weeks ago and the same thing happend. It froze up about half way through the proscess. The only solution for me was to do a full OS install using a reatail windows XP professional that i already had from one of my older desktops. It installed perfictly and all I had to do was (using my other desktop computer) download all the system software and drivers from the gateway site and that was it. I also had to call and activate the os but otherwise it actually works better and runs faster
  • Bob Puissant
    Bob Puissant Apr 30, 2009
    once i start the recovery cds it says no hard disk found. So now what do i do???
I have the same problem with my Gateway 7330gz. My laptop got infected with spywares and it was so annoyed that I have to think about recover the system. So I did it with Gateway Recovery software. I chose the recovery option (press F11 when boot up)from hard drive since my dvd drive was broken. It went well but when it boots up again and Windows XP says detecting and installing the drivers and such, it was frozen haft way through. I turned off power many times to reboot but it kept freezing at that point. I search Internet for help and seen this post. Wonderful! I press F2 to go to BIOS setup screen, use right arrow key to move to Advance menu option. There I use down arrow key to select SpeedStep, hit (-) key to disable it. Then F10 to save and exit, hit enter for OK button. The system boots again but this time it was no longer freezing, the setup process went through ok and continues...I am so happy and type this message so it might help others with the same issue. Thanks
Posted on Nov 28, 2008
I also had the same problem. I talked to Gateway Tech. Just after you turn on laptop push F2, this will put you into the BIOS. Push the Right Arrow key to Advance. Click on that, go down to the INTEL Speed. Use the +or - key to disable it. Push F10 and start the recovery CD. This will work. After redoing the HD remember to go back and enable the INTEL speed.
Posted on Aug 26, 2008
You need to disable the Hyper threading tech in the bios before you restore.i have that pc an thats what gateway told me an it worked.
Posted on Aug 06, 2009
I had the same problem. After receiving not 1 but 2 CD`s from Gateway my system would still freeze up before finalization. I proceeded to run a full restore and when prompted to remove the cd I than installed a complete OS disk believe it or not from an older DELL desktop.I put the disk in the cd rom before restarting. I had to contact Microsoft to varify my OS and than had to run all Microsoft updates now all is well. Hope this helps you...Joe
Posted on May 15, 2009
I think I've been having the same problem as well. Your computer might want you to place Recovery disks inside it.
Posted on Jul 12, 2008
Im having the same problem any help someone could give the both of us would be awsome
Posted on Jun 20, 2008
    Scholar:
  • 81 Answers
I had that same problem with a laptop before, and it turned out that the motherboard went bad on it. Hopefully not, but it may be your motherboard is bad as well.
Posted on May 30, 2008
Hooking up a Internal Hard drive
You probably need to give more details. If it's a replacement drive, did you reinstall Windows from a CD? Did you copy from the original hd? It's simple enough to remove the two cables from the original drive, physically remove and replace the drive, and hook up the new drive. But then you'd need to boot to a Windows CD in the CD/DVD player to format and install Windows, if that's what you're attempting to do.
There's possibly a recovery partition on the old drive )or a recovery CD). If so, you'd connect the new drive to a second power cable, and data cable (which might not be included in the tower) :
(from http://support.gateway.com/s/Manuals/Desktops/8510406.pdf)
To restore system software from the Recovery discs:
1 Insert the Recovery disc #1 into the CD or DVD drive.
2 Restart the computer, then press and hold
R when prompted to display the restore process options. The
Options menu appears.
3 Select a restore process option:
- Press R to boot from the hard drive recovery partition
or CD. If no recovery partition is found, go to Step 4.
- Press F to format the hard drive and perform a full system
recovery, then go to Step 5.
4 Click a system restore option. For more information, see
"Restoration options" on page 5.
- Non-Destructive System Restore (Recommended)
- Full System Restore (Destructive)
- Full System Restore (with Backup) (Advanced Option)
5 Follow the on-screen instructions to complete the system
software restoration process.
Oct 29, 2013 | eMachines ET183105 PC Desktop
How to get back to factory settings
Have you created your Application/driver cd from start, system recovery?
To recover your system from the hard drive:
1 Remove all CDs and DVDs from the disc drives, disconnect all USB devices
except the keyboard and mouse, then disconnect your Internet cable. If you can still run Windows, click Start, All Programs, System Recovery, System Recovery, then click Yes. Your computer restarts, then the System Recovery program starts.- OR -Turn on or restart your computer and press F11 while your computer is starting.3 Insert the Operating System Recovery CD/DVD when prompted. The System Recovery program starts.4 Click a system recovery option:??  Full System Restore (Destructive) reformats the hard drive and restores the system software as it was when you purchased your computer. This process deletes your data files. CautionThe Full System Restore option deletes allfiles on your hard drive except the restorefiles. Make sure that you back up allpersonal data files before continuing thisprocess.??  Full System Restore (with Backup) (recommended) moves the contents of the hard drive to the C:\My Backup folder and installs a new copy of Windows XP. This option saves your existing data files, but all programs must be reinstalled and the program settings reconfigured. You need at least 4 GB of hard drive space to use this restore option.5 Click Next. The System Restore - Format and Recover dialog box opens.6 Click Yes. Files are restored to your hard drive. When file recovery has finished, the System Restore dialog box opens. ImportantAfter you restore your system, it willappear with the same files and programsit had when it shipped from the factory.You still need to download Windowsupdates and antivirus updates to bringyour computer's software up to date.7 Click Restart. Your computer restarts, and Windows finishes its setup and installation.8 Reconnect your Internet cable and all USB peripheral devices. You are done.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 21, 2011 | eMachines ET183105 PC Desktop
Can I do a factory restore on my laptop without the CD?
Hi annick_s,
You can do a factory restore without using your CD as long as you haven't deleted the Recovery partition. Follow the steps below to do a factory restore;
1) Turn on the computer.
2) When the initial blue HP screen appears, press the F10> key repeatedly until a recovery menu appears.
3) When the Recovery screen appears, click Next, and then click Yes to perform a normal, non-destructive recovery. To perform a destructive recovery, click Advanced, and then click Yes.
CAUTION: A destructive recovery will format the hard drive. This will delete all the information on the hard drive and reinstall Windows XP and the original software that came with the computer.
4) After the System Recovery is complete, the computer restarts and continues into Windows setup. Complete the setup screens and wait until the computer finishes the setup.
If this information was helpful, please rate it.
Thank you for using fixya,
Arun Zac
Dec 05, 2010 | Compaq Presario Notebook
How do I access the hidden partition to reinstall operating system?
Turn on or restart your notebook, then press F11 while your notebook is
starting.
notebook. This process deletes your data files.
Full System Restore with Backup (recommended) moves the
restore option.
7 Click Restart. Your notebook restarts, and Windows finishes its setup and
installation.
Important
your notebook’s software up to date.
done.
Apr 03, 2010 | Gateway MX6214 Notebook
Can someone provide me online recovery disk of gateway 7330gz
You must set the boot sequence of the system to cd/dvd rom first which will enable the system to look for booting files in the disc in the first instance.
In your case your system is booting direct from hard disk. Boot sequence can be changed ib the bios setup of your system.
In some laptop models the restore files can be accessed by pressing function keys while system starting.
Mar 12, 2009 | Gateway 7330GZ Notebook
Gateway 7330GZ Not Booting Properly
Probably a virus, or your windows folder got corrupted. Try to use Knoppix (A linux distrobution that boots from a CD) to get all your data onto a pen drive or external hard drive. Download the Knoppix ISO at Knoppix.com and burn it onto a CD or DVD using MagicISO (magiciso.com). Insert the CD, and you should see the boot screen. Open the file manager, and copy all the files you want to keep from your hard drive to a pen drive or external hard drive. Then, reinstall Windows using a recovery CD (one might have come with your computer). Copy the files back, and PRESTO!
Feb 04, 2009 | Gateway 7330GZ Notebook
How can I make my machine do a destructive system recovery?
Just use the XP home disk and any drivers that you need either get the from Gateways website or download everest (lavalys.com) and get them thru that...
let me know...
Matt
Jan 21, 2009 | Gateway GT5056 PC Desktop
System Restore (Destructive) GM5084 Gateway Media Center w/ XP
what operating system disk do you have? xp, xp pro, vista?
Dec 26, 2008 | Gateway GM5084 PC Desktop
Can't reformat hard drive
If recovery is not possible by using recovery cd; you have to depend on a full version XP cd -- either for repair or new installation.
Dec 17, 2008 | Gateway GT5014 PC Desktop
Gateway laptop
gateways have the recovery built on the hard drive. just hit f11 on starting up the laptop( before the gateway screen) and it will reformat it back to out of bx state.
May 05, 2008 | Gateway 7330GZ Notebook
Gateway 7330GZ Notebook Logo
2,688 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
