Question about Technics SA-DX930 Receiver
Receiver overload problem
When playing music or watching a movie, after a couple minutes, the sound stops and the receiver says overload. Is this a cheap fix or will it be more expensive than just buying a new receiver???
  • 1 more comment
  • madmatt67 May 23, 2008
    Thank you for your help, I will check it out.
  • mitchong Aug 04, 2008
    I encounter this exact overload problem with my Panasonic A/V Control Receiver Model SA-XR50. Very annoying! Still do not know how to have it fixed.
  • writchie Sep 14, 2008
    I have the same problem ... try to crank up the volume a little bit, but the sound stops and the overload message comes on the receiver requiring a shutdown of the system. What a pain! I don't know what to do about this ... whether I should just replace the receiver, try to fix it, or maybe even wonder if it is a speaker problem. My left and right rear surround speakers are only 4 ohms, so I wonder if this is what is causing the overload. I actually still have the Technics manual, but there is only a brief mention of this overload error message in the manual and doesn't really offer any solutions. Technics receiver, technics speakers ... wish that I would have just stayed away from Technics in the first place. :-(
  • 4,234 Answers
The overload message is indicating that a problem was found and the system is shutting down the output section to prevent further damage. There are probably poor connections on the main board and failing capacitors in the front end. Expect a parts vcost in the $10 range. Add in the local labor rate for the total repair bill.
Dan
Posted on May 23, 2008
How to repair a overload receiver
Posted on Jun 25, 2009
2 Suggested Answers
Shaul Dag
  • 30 Answers
SOURCE: when playing music or watching a movie, after a
Check to see if the receiver is properly cooled.
Sha'ul
Posted on Jun 27, 2009
All of my speakers work when listening to music, but I noticed when watching a movie my left full speaker and surround sound speaker is not playing
There's only 2 things then that can cause this. First look at the simplest thing, and that would be your audio output connection. If you are playing music from the same playback device that you also watch a movie from; the problem indicates that there is something wrong with the left output that you are using for movie playback. Check that connection on both ends, that it is connected firmly and has no sign of damage and that it is also plugged into the proper input connection on the receiver. If that is not the case; i.e; you have made a single digital connection and are enabling that digital output then the problem is more complex and involves the processing of the digital signal either by the player, or by your receiver. In which case the problem could be isolated to which device is the culprit by connecting it to another device that can perform the same surround sound decoding functions. Making the repair however is not something I know how to do.
Jan 03, 2015 | Audio Players & Recorders
ONKYO Tx SR608 GOES TO "NO SIGNAL" WHEN PLAYING MUSIC DVDs. Not in movies though
that sounds strange. your receiver is not that smart to work out the differences between movie and music dvd. more info would be good.
Apr 09, 2014 | Onkyo Audio Players & Recorders
My pioneer overloads and cuts out
this unit draws alot of power if you have too many things plugged in on the same circuit then it will shutdown and reset itself. unplug reciever and plug straight into the wall
Nov 13, 2011 | Pioneer SX-315
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
I have an RX-V663 audio sounds flat
Let's deal with the turntable sound first - unless it's a self-preamplified model you would have to get an external phono-specific preamp to use with this receiver. Without one you'll get microscopically weak, tinny sound from the turntable. Google "RIAA curve" to see why.
As far as the CD sound through the Blu Ray player... for one thing it is flat, as in two-dimensional stereo. Compared to genuine surround from a movie it would be a letdown.
Can you better define 'flat'?
Feb 04, 2010 | Yamaha RX-V663 Receiver
Turns off after a few minutes
Sounds like a possible power short, especially if you have speaker cables connected to the receiver but not to speakers -- leaving the ends more likely to short (even via a single thin copper strand across a millimeter or two, when the voltage peaks). The receiver's message says "Check Spkr Cables," right? (They do mean the Speaker Cables!) Most receivers have a built-in power overload detection/protection shut-off circuit to save you from such mistakes.
Jul 18, 2009 | Yamaha HTR-5850 Receiver
Marantz Sr8500
Check the speakers impedance. it should be greater then 6ohm otherwise you overload the system. Also, if the speaker sytem is rated (in Watts) below the amplifier's power it overloads the amp at higher volumes.
Apr 12, 2008 | Marantz SR8500 Receiver
Denon AVR 2802 - Unit Turning Off
If DIGITAL sign blink, this mean DSP board is defective. It will cut the sound on the AMP section. DSp is maybe defective.
Jan 12, 2008 | Denon AVR-2802
Overload
try turning the unit off in standby mode then hold down the enter button and then the power button for about 10m seconds that should reset the unit depending on how new the unit is it sometimes has a digital saftey setting but i doubt that would cause it to do what you are saying
Oct 17, 2007 | Pioneer VSX-D411 Receiver
Technics SA-DX930 Receiver Logo
1,581 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
