Question about Sony KV-36FV26 TV
Sony horizontal output outage
I have a sony trinitron (kv=36fv26). The picture tube comes on, but there is no picture and no sound. The standby light flashes 5 times. In October, you diagnosed that as a bad horizontal output. Is there a way for the layman to fix that?
  • Anonymous Jan 27, 2009
    the same thing
5 Suggested Answers
mediarich
  • 188 Answers
SOURCE: Standby light flashes 2 or 5 times; lilac picture with horizontal lines; and instant offs
There is some electronic circuit problem with your TV. Best if you want to repair it you find a reputable TV repair shop. Sorry.
Posted on Sep 18, 2008
ikecur
  • 52 Answers
SOURCE: Sony trinitron KV-27FS100
probably, you have to call for a technician to check for it, the switch of the tv might have some dis alignment of cables
Posted on Oct 30, 2008
darjr
  • 378 Answers
SOURCE: Sony KV-27FS13 blinking standby 5 times..
try to resolder all ic leads and power supply component, moreover Horizontal section.
Posted on Jun 03, 2009
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
barbu51
  • 566 Answers
SOURCE: kv-32fs16, no picture or sound , red lights flash 4 times
Hi
In sony tv`s the 4 blink code(sony error codes)usually means that there is a vertical deflection problem.
It is often caused by a faulty vertical output i.c and/or related components. If you feel handy with a soldering iron let me know and i`ll help you with it.
Hope this help Merry Christmas
Posted on Dec 17, 2009
I have a Sony Trinitron KP-43T90, have sound but no picture it is a 2001.
Check its horizontal output section circuit for fault. Check the horizontal output transistor. If it found leaky, suspect horizontal output transformer.
Dec 21, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony FD Trinitron Wega (KV-32HS510). When I attempt to turn the tv on by pressing the power button on the remote or on the tv, the standby light comes on and I hear two clicks but tv don't...
The primary power supply is good,maybe the horizontal output transistor is deffective thats why there is no high voltage supply in the picture tube because theflyback have no supply voltage and oscilation.So check the harizontal output transistor and replace if deffective.
Sep 12, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My KV-36HS500 won't turn on it sounds like it wants to,but no picture,and standby light flashes 7 times,pauses and flashes 7 times again
The 7 blinks indicate that the horizontal deflection has stopped. This can be because the horizontal output transistor has shorted (common) or other defecive parts. If you are familiar with working inside of sets where potentially dangerous high voltages exist and can solder, let me know and additional details and instructions will be provided.
Dan
Mar 19, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony trinitron kv-36fv26 (2000) tv wont show picture
Trires unplug,replug about an hour later see if it reset it self.Not take to the shop the two power ICs help the power it dead.Need it replaced.
Jan 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
SONY TRINITRON KV-2167MT power not on
Please replace Horizontal Output Transistor in KV-2167MT and TV will start function.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
2000 Sony Trinatron #KV-36FV26
IF--- You have 3 video ics located on CRT broad # TDA6111Q ,if only one of them is shorted set will not come on these ics will kill the high voltage, there for keeping set off.
May 18, 2008 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Sony kv-32fs120
The 6 blinks mean no horizontal. Check the horizontal circuitry. I'll look up your specific model later and post more details.
Dan
May 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony FD Trinitron Wega(Model # KV-36FV26) that has a blinking standby light that blinks intermitenly. Does that mean that trouble is soon to come?
THE TUBE COULD BE GETTING WEAK . IF YOU GIVE
ME THE BLINKING I COULD TELL YOU BETTER, IT ALSO COULD BE A SIGN POWER SUPPLY IS GOING .BOTH PROBLEMS CAN BE FIXED I WOULD WAIT FOR TV TO GO OUT BEFORE FIXING INTERMITTING PROBLEMS ARE HARD TO FIX ESTIMATE ON REPAIR IS AROUND 160,00 DOLLARS
THANKS DOCTOR VIDEO
Apr 25, 2008 | Televison & Video
Flashing/sparking of image
no doubt. replace LOT and horizontal output transformer with new one
Jan 26, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Power
yes you have defective horizontal output! that is from the power section near at the flyback!
Oct 21, 2007 | Sony KV-36FV26 TV
Sony KV-36FV26 TV Logo
80 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
