Question about Amptron CT-520D (Beige) 15 in. Flat Panel LCD Monitor
Amptron Model E15FP Power supply
Help... I've misplaced the power cable for my monitor and can't seem to find one to replace it ANYWHERE. It's not your typical chord (of course), and Radio Shack, Best Buy and Staples cannot help me. It is model E15FP, with DC Input 12V DC - 3A, and the serial # is AAY42C00870 (I think that's the serial #, its the number on the top with the bar code). There's also another number and bar code on the bottom back, AE15FP0430157.
Thanks for any help!
4 Suggested Answers
  • 61 Answers
SOURCE: amptron monitor driver
I don't think this monitor needs a driver for WinXp.
Check out:
All I see is a cd with a user guide.
Posted on Mar 17, 2009
  • 110 Answers
SOURCE: hello i lost my power cord for my amv monitor
u can use the compatible power cord and other monitor cord also
Posted on Oct 29, 2009
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
Hi, I have a Polyview V293 LCD Monitor with a power supply output of 19v 3.42A. The power supply has failed. Most i have found being offered as direct replacement for this monitor have an output of 19v...
If the power adapter is a separate from the monitor then check the monitor's label on the back of the screen for the power rating.If the rating on the label is greater than 3.16A then I would not purchase this adapter.
I suggest you purchase an adapter with a current rating greater than what is stated on the monitor's label.
Check out this WEB site for power adapters - a 19Volt 90 watt = 4.7A power supply is suitable.
Apr 01, 2011 | Amptron POLYVIEW 19" Monitor
The amptron monitor will flick on for a split-second (long enough for me to momentarily see the desktop) with the center power (green light) lit...for a split-second. then its off for a few (3-5) seconds....
90% of the failed LCD monitors are due to bad capacitors (bulging top/seal, or leaking) in the power supply, or bad solder joints, etc.. You can look for them first. Please see the pictures here to see what to look for:
Please post back so we can guide you further and it will help other people also.
Apr 06, 2010 | Amptron amv MW9BBK Monitor
Amptron monitor driver
Check out:
Mar 17, 2009 | Amptron amv MW9BBK Monitor
Help please
Do you get a beep on the system unit(CPU)?
Sep 19, 2008 | Amptron PM-9100A Motherboard
Acer al1916b high pitched noise when on standby.
Sounds like you could have an open ground? Also might check the wiring to see if you have a faulty connection in VGA cable or power supply cable
Jul 24, 2008 | Acer AL1916B 19" LCD Monitor
Please help for Cable and Power supply for KOGI monitor L7EH-TA ???
the power cable is as the simple attach to run the pc..
the vga cable u have to buy it from computer/monitor shop..
ask them for cable by telling them the model and spec. of your monitor.
dont forget to rate it
Jun 14, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
My monitor remains black
well your screens broken mate the only thing you can do is get a new one
Sep 30, 2006 | Amptron CMV-922D 19" Monitor
Amptron CT-520D (Beige) 15 in. Flat Panel LCD Monitor Logo
234 people viewed this question
Top Amptron Computers & Internet Experts
David Payne
David Payne
Are you an Amptron Computer and Internet Expert? Answer questions, earn points and help others
