Question about KitchenAid Superba KSCS23IN Side by Side Refrigerator
Kitchenaid KSCS23 Icemaker not working.
Chris,
My Ice maker stopped working after my filter was spent (coincidence?). However, the in-door water never stopped working. I tried someone suggestion and added water to the dry metal tray to see if a sensor would kick in or something but the water just froze and the ice maker never started.
I just took the ice maker out and defrosted the tray and placed the icemaker back in the freezer to see if that would restart the icemaker (by miracle). The tray is not filling with water. It seems that I have at least two issues: the sensor to provide stopped working or the line is frozen and the ice maker module is not working for some reason.
So how do I fix it? Do I have to thaw out my freezer to defrost the icemaker water line? Should I purchase a new module even though it looks brand new?
Any help would be appreciated,
Joe
joejmello@aol.com
SOURCE: whirlpool fridge model WF-NL300 ice
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Posted on Feb 29, 2008
SOURCE: No water dispensing to the icemaker. Water does dispense through the door dispenser. KitchenAid ksbs25fkbl00
Unplug your refrigerator and leave the freezer door open for 2 hours (The food in the freezer will only partially thaw).
The line supplying the water to the ice maker has frozen...this will un-thaw it.
Posted on Jul 01, 2008
SOURCE: kitchenaid superba icemaker leaking/freezing in freezer section
Thank you, I am going to go check right now
Posted on Nov 09, 2008
  • 218 Answers
SOURCE: Kitchenaid Icemaker does nothing. Ref. Mod.kscs25Inssoo
The prime suspect would be the solenoid valve. Check it for continuity with an ohmeter (after unplugging the fridge and disconnecting the coil, of course). If that's okay, then you might have a bad switch in the icemaker itself, or the supply line might be frozen. I'm betting on the solenoid. Good luck with the fix!
Posted on Jan 27, 2009
ginko
  • 19396 Answers
SOURCE: Kitchenaid Icemaker leaking in big drips on front of freezer bins
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
Kitchenaid french door refrigerator not making ice
Water valve has 2 solenoids. One for water in door and one for water to ice maker. Most likely water valve is the problem b
Sep 16, 2017 | KitchenAid / Architect Series II...
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KBFA25ERSS01 I replaced the water
if its computerized make sure someone didnt turn icemaker off check to make sure its in all the way
Oct 27, 2013 | KitchenAid KBFS25EVMS Stainless Steel...
Ice maker quit
if ice maker is cycleing then it is either water frozen at the tube where water comes in. if it is then shut off refrig. remove icemaker and thaw tube out with a hair dryer. makeing sure not to melt plastic in the back panel of freezer. if it is plastic. if it is not plugged then it is either a bad water valve or the watervalve switch in the icemaker.
May 26, 2012 | KitchenAid Refrigerators
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
Icemaker is not making ice.
check water valve /filter it maybe the ice maker
Apr 02, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Kitchenaid ice maker not making ice
first check the tube running to the ice maker where the water flows in see if it is frozen if not take the cover off the ice maker front and see if the little tabs in the middle of the gear is broken there are two one might be broken off
Mar 30, 2009 | Refrigerators
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
362 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
