Question about Kicker Solo-Baric L5 Car Subwoofer
Installing my woofers
How do i connect the wires to the my 15'' solobaric kickers L5 since they have 2 reds and 2 blacks
  • xvrh Jun 15, 2008
    i want to know how many ohms i need to get the best out of my ten inch solobaric L5.i ma powering it with a 1000 watt sony explode amp two channel.
    Problem Solver:
  • 7 Answers
Hi there james. What you can do is connect the cables as normal. 2 to the left, 2 to the right. Then at the cable's end you need to mix the red left cable with the right red cable, and so on with the blacks. and its done. Now instead of 4 cables you have two. If you need further explanation please ask
Posted on May 24, 2008
I have a jl audio 1000/1 v1 amp pushing 2 15"
add more batteries to the truck and up grade the alternator and fuse
Jun 06, 2013 | Car Audio & Video
Would a 10ZX750.1 amp be alright on a Single Solobaric L5 10" inch in a ported box???
yes, the 10ZX750.1 is capable of running two L5's at two ohms in either a ported or sealed box. Just be sure to wire it up to suit your needs correctly (if you need to know how i can help) and make sure that your box dimensions match what kicker specify. the L5 is actually one of the subs that kicker reccommend for that amp.
Hope I helped , and please dont forget to rate.
cheers
Jan 15, 2011 | Kicker Car Audio & Video
What wires do i need to hook up 2 kicker solobaric s15l7 to a car
You will need the amp wires. Red Positive to battery, Black negative from amp ground to unpainted car body surface, and the blue remote wire that goes from amp to remote wire on back of cd deck.
Then you will need the rca cables from rear output of cd player to the amp.
Then just the positive and negative wire from speaker to amp. Use Speaker Positive wire to Amp Right Channel Positive
And speaker negative wire to amp Left Channel Legative wire.
That is it.
Nov 17, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I wanna know if a 1500.1 amp good for 2 15'' kicker L7 solobarics
yes but you might get better results from it if you wire it for use on 2ohms
Oct 13, 2009 | Car Audio & Video
I have 3 Kicker solobarics Hooked to 1 ohm, But
It likely has a blown voicecoil - or the voicecoil is damaged in a certain spot - so when you play a certain frequency it cuts out.
Aso check the integrity of the tinsel wires - if they are loose or hitting the basket, it would stop playing.
BTW - it is impossible to wire a 1 ohm load with (3) single or 4ohm voicecoils.
Be sure your wiring is correct - or the amplifier will be the next thing to go.
Thanks for using FixYa - Rating this FREE answer is appreciated.
Jul 05, 2009 | Kicker Solo-Baric L7 10'' Car Speaker
Kicker zx1000.1 green light flckers and the turns red and then does the same thing over and over
seems like a protection feature kicks in and out
check your fuses and possible but a bigger size in and also check your wires make sure your ground is tight
May 17, 2009 | Kicker ZX10001 Car Audio Amplifier
How to wire up my kicker 12inch solobaric l5 2ohm to my zx500 2ohm mono amp. should it be ran in parallel or series? what is the best suggestion
Well first of all all solobarics are dual voice coil so you have 2 2ohm voice coils so if you wire them in parallel the sub will be pulling a 1ohm load wich would in time blow out your amp. So you want to wire both voice coils in series to produce a 4ohm load.
Oct 25, 2008 | Kicker Car Audio & Video
Wiring
1st--on 1 sub put a wire connecting one red with white dot to the blk with white dot
2nd--do the same thing to the other sub !!do not wire a red/white to an all black
3rd--wire the full blk negetives to the amp, then same thing to the positive
Sep 21, 2008 | Kicker Car Audio & Video
Solobaric subs l7 15-inch
this should help you
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Jan 23, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker solobaric l5 12''
how to wire a kicker solo baric l5 12'' 4ohm down 2 and 1 ohm
Sep 25, 2007 | Car Audio & Video
Kicker Solo-Baric L5 Car Subwoofer Logo
144 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
