Question about Lexmark X4270 All-In-One InkJet Printer
Printer cuts off top 1 inch of PDF document
The top content on all my PDF documents gets cut off while printing.
The top and bottom margins in my PDF documents are roughly 0.75 - 1 inches; yet the X4270 printer cuts off about 2 inches off the top of the PDF while printing, thereby causing me to lose about 1 inch off the top of the print area.
FOr example, if the PDF document layout is as follows:
PDF document start--------
| 1 inch blank margin
| 1 inch header
| Content
| 1 inch blank margin
PDF document end--------
Then the printer prints it as follows:
Paper start--------
| 1 inch blank margin
| Content
| 2 inch blank margin
Paper end--------
As you can see, the 1 inch header is cut off.
Please help.
TIA.
JohnC
  • Anonymous Mar 22, 2014
    I have had this problem ever since we purchased our printer (HP Deskjet Ink Advantage 2060 K110). When I type a document, with a page full of texts, most especially if I insert a footer in the document, a portion of the document is not printed or is cut. It didn't bother me before, since I just adjusted the margins so that all the text in the documents I made will be printed. But now, since the document I am working on has required margins, I cannot adjust the margins as I please. How can the document be printed without me worrying about adjusting the margins and the bottom portion of my document being cut? Please, I need immediate help since I'lll be passing this document next week!
  • Anonymous Mar 26, 2014
    how to print an exact reduction from pdf file
    Problem Solver:
  • 19 Answers
Go to the printer properties and try setting it up with border less printing.
Cheers
Posted on Aug 30, 2008
My Kyocera fs-1118MFP is cutting off top margin of all documentscopy or print. How do I fix, plz help.
I don't know that machine but generically, the description suggests a faulty drum or fuser unit...
How many prints or copies since either or both were changed, please?
Sep 02, 2016 | Kyocera FS-1118MFP Laser Printer
Pt 65 margins
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Brother Printer Support
Apr 20, 2014 | Brother PT-1000 Thermal Label Printer
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Check Your Margins
Select New Margins
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
My Canon ImageRUNNER 3225 does not print correctly aligned when sent through the feeder? When feeding paper, I have tried Landscape and the resulting copy is cut off from the top and bottom and the left...
Is it ok when you just put the document on the glass? If so, the Document feeder needs a whole set of rollers.
Otherwise the document scanner may be bad. This needs to be changed out by a technician.
Whit
Item, Inc
Sep 15, 2010 | Canon imageRUNNER 3225 Black and White...
Is there anything I can do to print closer to the top of the page? Even when I have my top margin set to zero it starts printing an inch from the top. I have it set to center on the page. In print...
if you print web pages, click File, then click Page Setup, from there, adjust the top margin. Do the same on the application you are using for the document or file you are working on.
Aug 29, 2010 | Office Equipment & Supplies
Last print line of any doc printed with HP J6480 is cut off
I had been experiencing this problem intermittently for some time, so I finally got a hold of HP support and with the second support technician, I did get a solution that worked for the document I was printing at the time. When Printing, click Printing Preferences, click the Advanced tab, under the Printer Features section, set Minimize margins to On. Per the technician, 'The printable area of the product increases (bottom margin 12 mm to 3 mm), so that printing closer to the edge of the paper.'
Also, he recommended using the printer's Print Preview option under same the Printer Preferences window. When I did, I did in fact see the document's bottom paper being 'cutoff' with the old settings (i.e., Minimize margins Off), with it On, it look okay.
Hope this helps. Let me know if this works for you.
Jul 19, 2009 | HP Office Equipment & Supplies
Top of words are cut off
Often times, some documents might have their margins or header/footers set to high for the printer to handle. Try opening the document and checking the margins, one inch all around is usually the default margin settings.
Jun 26, 2009 | Konica Minolta PagePro 1400 Laser Printer
Printer not printing margins correctly
Set the margin unit of measurement to whatever you find most useful: inches, centimeters, millimeters, points, or picas.
  1. Choose File > Options > Advanced.
  2. Under Display, in the Show measurements in units of box, select the unit you want.
Mar 24, 2017 | HP Office Equipment & Supplies
Lexmark X4270 All-In-One InkJet Printer Logo
855 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
