Question about Maytag Washing Machines
Maytag mfw9600sq front load stops 2 min before cycle is complete? code F stops early on other cycles also???
5 Suggested Answers
  • 209 Answers
SOURCE: maytag neptune front loading washer
purely based on the vague information you have given, this could sound like the drum bearings and the fact that it has been neglected for so long has resulted in serious damage to your machine, note to all, never continue to use machines making noises, it can only get worse and do mare costly damage, after all the problem could have been a very inexpensive fix problems on this and any other site, to be fixed by messages (without actually seeing the machine) can only be fixed - or advice can only be given based on the details that are given if you say my machine just stopped then you will not get an answer will you? engineers can help sort out lots of problems without seeing the machine if we are given the right DETAILED information, no matter how silly it sounds, so before you shout and complain at others, have a thought about what you are going to write sorry its bad news but i hope i have helped
Posted on Oct 02, 2007
  • 3 Answers
SOURCE: Maytag front loading washing machine
This worked for me for the E3 error code: Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
Posted on Jun 20, 2008
SOURCE: kenmore front load washer 417-44082400
My kenmore front load did that just a few months after I bought it. Unfortunately it was the the electronic board {brains of cycles} that had to be replaced. Had to replace it 3 times!! Warranty did cover it. Look into your warranty--at that time the boards were $200-$250 each!!
Posted on Jul 04, 2008
  • 50 Answers
SOURCE: how to fix the LO error code on Maytag Neptune front load washer
Not really bad news. The unit requires a door lock assembly.
Posted on Feb 23, 2009
  • 52 Answers
SOURCE: maytag neptune stops in mid cycle
It sounds like your drain pump is going. Neptunes are suppose to neqarly dry the clothes with how fast it spins. A poor drain pump/motor, could cause this to be less effective. There could also be something in the drain lines. I would check that before you pay money on a pump though.
Posted on Feb 28, 2009
My Maytag Neptune FAV6800AW top load washer only runs for the first few minutes of the cycle, it will not spin..it just stops..we've tried two cycles, the quick wash...it starts at 33 mins and then stops...
I'm and owner and will try to help. Are you handy and do you want to try a DIY fix?
From the wash times is sounds like the washer is agitating the wash load (tumblers are rotating the wash basket load) is that correct?
If so see if the machine will complete a Spin Only cycle with no clothes in the wash basket. Set the Spin setting to Spin/Hang dry seting and start the cycle. It should take about 10 min complete. Does the Spin Only cycle complete with no clothes in the wash basket?
Some handy links if you are going to DIY.........Service Manual for reference.
Sep 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Hi I have a Maytag model fav6800aww stopped in mid wash cycle,now if you try any cycle it makes a whirling noise for a few seconds then goes to the light flashing pause mode.Thanks.
No erro codes to the console correct?
Sep 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.
Good deal your machine is a Series 11.
“”Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.””
I believe this is the start of a Spin Cycle of that Wash Cycle which Wash Cycle did you have selected?
Are there any error codes to the LED display like dC or uC?
If you stop that wash cycle with the wet load and do a Spin Only cycle will it complete with no error code?
Does the wash tub bang around in Spin Only cycle with the wet clothes load?
Standing by for some feedback and I will try to help.
Here is the Service Manual and parts look up. Can you let me know if you want to try to DIY the fix?
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Rich
Apr 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
F9 Code
Pump is most likely clogged .... take front panel off and pump is right there ......
Jul 22, 2009 | Kenmore Elite 45986 Front Load Washer
Maytag performance series washer model mhwe500vp stops mid cycle
having the same problem found in side a small black hose with a small hole in it but have no idea what this hose is for. may be it is connected to some water sensor.
Jun 27, 2009 | Maytag Performa PAV2200
Maytag neptune error? message
Unplug for 10 min to reboot the curcuit board. This will reset the system. Sometimes selecting numerous cycles or pushing buttons a lot in a short period of time can overwelm the little brain in the curcuit. This action will clear the memory of any unwanted comands in the curcuit.
Apr 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore elite HE 3 displays F 06 code
F 06 cose for faulty motor controller. reomove lower acess panel adn ck for good wire connections (board is in rt front corner) check wiring harness to lower control board,. sometimes a glitch( it is a computer after all). try unplugging unit fro 2 min . if not replace motor control board
Mar 04, 2008 | Kenmore Elite 45986 Front Load Washer
Front Load washer won't start
according to site an f-01 relates to a CCU issue, remove power for 2 min and try to reset, if not check wiring to CCU(central control uint) all in tact?? replace CCU
Mar 03, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
90 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
