Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Samsung HCN4226W Rear Projection TV
Hello everyone,
I have the same problem,as others do, with the convergence board on the Samsung HCN4226W. Where can I get the convergence board (BP95-00142E) and can I get the alignment manual file from you?
Thanks in advance,
We have a Samsung HCN4226W it seems like the color is almost making us see a double picture, can you tell me what may be the problem and how we can fix it ?
Posted on Jun 03, 2008
  • Samsung Master
  • 8,617 Answers
You can get the convergence board here atwww.partsstore.com
And you can get the full service manual for your model emailed to you at the following link. Its listed in the samsung catagory.
http://servicemanuals.vstore.ca/
Posted on May 23, 2008
  • 2,326 Answers
You can get the convergence board by clicking here.
The service manual you might buy it from the same place.
Coloring is off and there is a ghosting effect
Part # BP95-00142E is the correct convergence amp board for a model # HCN4226W. Part # BP94-00155A is listed as a "CG Amp assembly board" also, but is not correct for a model # HCN4226W. They are both basically convergence amp boards. Here's a link to order the original Samsung covergence amp board for this model (HCN4226W) from a major parts distributor:
Samsung HCN4226W Replacement Part Convergence Amp Board
Jan 30, 2009 | Televison & Video
HCN4226W convergence board
SAMSUNG Convergence Board
I don't recommend working on the TV unless you have some experience and knowledge relating to the safety issues and electronic repair. Many rookies will not successfully complete the repair and probably do more harm than good.
Open the back of the TV. The board is in front of you, a small separate board with small plugs attached. If you think you are competent enough to remove it and replace it without damage to yourself or the TV, go for it.
Website below gives some description of costs with in home repair of convergence problems.
http://calgaryconvergencerepair.weebly.com/convergence-explanation.html
If you live around Calgary, Alberta try me.
Or try to the find the repairperson part of this website (on the Homepage) and search postal code. Maybe you will be lucky and someone from your area is listed for Projection TV repair.
Most rookies doing this job will cause damage and not be successful. They will pay double for someone to fix their mess or end up scrapping the TV. It is not a simple task. It is more difficult than batteries on a remote.
Good Luck
Easyab
May 23, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226w green color problem
The green that you see is the DMD board (digital mirror display) going bad. Very common for this model.
Mar 24, 2008 | Televison & Video
Samsung HCN4226W blue color outlines
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
This convergence board works with the following Samsung television models: HCM4215W, HCN529WX, HCN559WX/XAA, PCN5425R, HCN4226WX, HCN529WX/XA
Mar 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Dark shadow on right side of screen
replace the pcb convergence board,, It costs $96 and takes 10 minutes to replace you will have to manually line up your convergence afterward as the settings go to factory default. Everyone that owns this set has or will have to replace this part within 3 years
http://www.samsungparts.com/search/search.asp
Or Vance baldwin online
Part number bp94-00155a
Dec 29, 2007 | Samsung HCN4226W 42" Rear Projection...
Convergence issues?
most likely the convergence board.
Ordered complete convergence board, ask samsung for part number Convergence AMP PCB $108.44, from www.samsungparts.com
or could send it in to ptscorp.com for repair.
Dec 23, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W Service Menu?? For convergence issue????
The resistors on the new module are not 100% Identical in resistance to the originals on your board, to access the svc menu you will want a service manual and will require some patience. It can be tricky I would personally call a repairman with convergence in mind. Or order a manual and read the conv section several times. http://www.eserviceinfo.com/index.php?what=search2 Is one site, might have to purchase one.
Jul 06, 2007 | Samsung HCN4226W 42" Rear Projection...
Bowing and ghosting
Dec 30, 2006 | Samsung HCN4226W 42" Rear Projection...
SOUND BUT NO PICTURE
Dec 24, 2006 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
164 people viewed this question
Henry  Thomas
Henry Thomas
