Question about RCA 36V430T 36" TV
Problem with screen
There is a line with no picture. Could you tell me the problem I may have with it.
  • Bronz May 24, 2008
    Wich one of these IC's would be closer to the IC number you have given me(LM324N, LF347N). If I could email you a picture of where I have gotten the IC numbers from, then you would know more or less what to tell me to do next.
  • 4,234 Answers
There is a problem with the vertical circuit. If you are comfortable with soldering, you should be able to fix this yourself. Look for a small flat IC attached to a heatsink. It will be marked LA7837 or something similar. This is the vertical IC. Try resoldering the pins on the IC. If that fails to resolve the problem, replace it. Report back here if there are other issues.
Dan
Posted on May 23, 2008
Wd62628 black lines across screen lamp light stays on
Hello, it sounds like the chip on the dm board is going bad, but a picture of the screen would tell me a lot more....tks
Jan 11, 2015 | Mitsubishi Televison & Video
Toshiba 46xf355db upon start up there is a fuzy picture and lines
I believe that tv is about 10 years old. The best solution and probably most cost effective is to replace it.
May 17, 2017 | Televison & Video
Philips l01.2a red screen with flyback lines and no picture
A model and confirm actual brand.
A general answer: If red screen with trace (retrace it is called) lines the issue is either with a picture tube or the Video output circuit for that color.
The more you explain and tell me the better I can assist you.
Mar 20, 2012 | Televison & Video
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Picture has lines going across
No picture tube is cheap to replace. Especially a Sony tube. And besides the cost of the tube there's the labor cost to install it and some tedious adjusting needs to be done to set up the replacement. When a picture tube fails it's time to replace the set.
Now having said all that, there are different kinds of lines that can show on the screen. Some are because the tube is bad, but others can come from less expensive parts on the circuit board in the set. Without seeing the lines for myself I can't tell you about yours. If you are wanting to keep the set, I would suggest having a qualified shop check it. The can tell you for sure if it's the tube or not, and give you an estimate for the cost of repair.
Apr 18, 2009 | Zenith C27A24T 27" TV
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
Toshiba 32AF42 Poor picture quality
TRY ADJUSTING THE SCREEN CONTROL ADJUSTMENT AT THE BOTTOM OF THE FLYBACK TRANSFORMER.THIS SHOULD REMOVE THE RETRACE LINES AND ANJUST THE HASY LOOK TO THE PICTURE IF NOT YOU HAVE A BAD CAP IN THE SCREEN CIRCUIT .LOOK FOR A 10MFD/250V CAP IF FEEDS THE NECK BOARD ATTACHED TO THE PICTURE TUBE 200V DC.
Jun 22, 2007 | Toshiba 32AF42 32" TV
SONY KP-46S25
A "Gray Scale" adjustment may solve you problem. If one of the picture tubes is set too high it will cause these RETRACE lines. Then too a weak picture tube might cause this. If the horizontal lines are one color: red, green,or blue then whichever color that is shown would tell you which tube is set too high. Your set has 3 screen controls that control the brightness of each tube. One may need to be turned down a little. Stargazer
Mar 11, 2007 | Sony KP-46S25 TV
RCA 36V430T 36" TV Logo
57 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
