Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Blue screen with flickering horizontal lines
Turned on my tv and have a blue screen with flickering horizontal lines.  Thought it was the lamp but it still has the flickering lines.  The green LED light is solid.  What would it be?
  • sandnsurf Jan 03, 2009
    I have the same problem. I could use that pdf file. If anyone has the link to it, that would be greatly appreciated. Thanks.
    Sandnsurf
I had a similar problem - got worse as the TV warmed up more. Looked real bad when
the scene was dark.
I opened up the unit and replaced capacitors. I have instructions on how to do it but do
not know how to add this file (pdf of 1.8mb) to this posting.
I am glad to share my information, just do not know how.
Posted on Dec 31, 2008
  • 58 Answers
Yeah, caps fail on this tv. about 16 electrolytics and about 80 surface mount caps. The boards in the chassis that need this rebuild are the Power, FMT, DM, and Terminal 2. The boards are labeled in the corner.
Posted on Dec 30, 2008
  • Mitsubishi Master
  • 8,617 Answers
Sounds like the 1000uf capacitors on the FMT board need replacing. This is a common symptom with that chassis. There are three 1000uf caps that fail on that PC Board
Posted on May 23, 2008
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
Toshiba 50H13 blurry picture with white line on right side
replace all the surface mounted electrolytic capacitors on the hyper module. also called the scan converter module. this is a common trouble. what a nasty job. good luck.
Jun 23, 2009 | Toshiba 50H13 50" Rear Projection...
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Compaq presario v2000 monitor is having horizontal purple lines that flicker.
Try reloading the drivers, delete the device in device manager and reboot. It should then pick up the drivers and reload them, if that does not work I would suspect the screen is on its way out (flickering normally means the screen or its connection is bad)
Jan 26, 2008 | HP Compaq Presario V2000 Notebook
Red & green lamps shutting off leaving a blue screen
Could you show a picture of the distended cover you mentioned?
Were the light blue lines you were referring to, diagonal, or truly horizontal?
Oct 15, 2007 | Sony KP-57WS500 57" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
574 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
