Question about Epson Stylus CX4800 All-In-One InkJet Printer
Black smear of ink at end of lines
I am getting black only smears of ink at the end of each printing line all down the page. I have replaced in the ink cartridges, cleaned the heads, and wasted a lot of ink to try and resolve.
  • 2 more comments
  • zippydedodah Jun 07, 2008
    I have the same problem so I contacted Epson support and their first suggestion did not work. The second solution from them was to return it if it is still under warranty period (it isn't) or take it in for service. But they also advised that the cost may be more than a new printer so ............. I have just replaced the ink tanks and am not going to take their answer just yet. The ink has cost me far too much. If I have to buy another printer it will NOT be Epson. This should have lasted longer than two years with average use.
  • treglen Oct 17, 2008
    I've had the same problem, but I was using a thicker paper (Exhibition Fiber Paper by Epson). According to the User Guide, in the print dialog box, click "Maintenance," then "Printer and Option Information," then put a check in the box that says "thick paper." If you're not using thick paper and are having this problem, I don't have anything new to add to what has already been suggested.
  • Lavol Oct 09, 2009
    Epson Stylus Photo R1800
    Hello! Wonder if there are adjustment programs or resetting tools for Epson Stylus Photo R1800 - for Mac users? And if someone knows if problem with smeary prints or overfilled waste ink pads can lead to problems with paper jams? The thing is - yesterday my printer started to mess up my prints with black stains and smear. and now it cant feed paper. The printer just tear the paper apart or just dont get the grip of it. I got the Epson Service Manual but I cant find out what to do? I would like to fix the jam problem and then find out a way to clean the waste pads.
  • Anonymous Mar 28, 2014
    black ink is only printing half the line, also black is grey. I have cleaned heads 6 times .
    Scholar:
  • 94 Answers
Please load the printer with at least 10 sheets of plain paper then press the start button. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains, streaks or smudges are still present, the printer may need service.
Posted on Jun 10, 2008
Finally fixed black smear problem!
My prints had the black marks mostly near the edges of the paper.
I found that the printer "head", had a wad of ink soaked (cat) hair stuck to it on the right hand bottom edge, being dragged back and forth over the paper.
I got the head to stay in place by turning off the power at my power strip
when the head was in a good spot. I used needle-nosed pliers to reach in to remove the hair. Hope this helps.
Posted on Oct 19, 2011
Hi
I had similar problem printing a 5.75 x 4.375" envelope on epson 1800. After a day of frustration, researched on similar problem on the internet, I finally RESOLVED the problem !!!!!
here is what you need to do:
1.make sure to do "custom" size on page setup > to make sure you have the right size you need.
2.(I am using in design), then on your printer menu, pick define by printer.
3. then go to printer > extension setting > CLICK on THICK
done ! I am overjoyed now.. i finally can print my own wedding envelope !!
Posted on Feb 26, 2010
I have a black line printing down the middle of the page that smears when touched
U didnt write what model of machine you hawe,but probably,I thinh the fixing roller or film on your's machine heater is damaged
Oct 10, 2014 | Canon Office Equipment & Supplies
Ink smear on back of print job canon pro 9000
control panel - printers- highlight printer but dont select - top right printer preferences - maintance- clean printer heads etc clean with all options available. should fix the problem.
Feb 10, 2013 | Canon PIXMA Pro9000 Printer
Printed pages are smeared with black
Sounds like a bad toner, or possibly the scanner is dirty. If you look where it pulls the paper through it can have a small speck, but since its on the scanner tself it will put black lines all the way down the paper.
If its larger and smeared the Toner itself is probably bad and you need a new Toner Kit, should come with new rollers and a new cartridge as well.
Mar 01, 2011 | Dell 5110cn Laser Printer
Ink from smearing all over my papers
Using original cartridges won happen like this.
May 30, 2010 | Canon Pixma MP450 All-In-One InkJet...
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
All ink cartridges leak onto to copies
I think you need to change the tranfer belt assm.
If all the colors are smearing .
Or all of your toners are bad and leaking,
Hope this helps
Mar 28, 2009 | HP LaserJet 4650 Color Printer
Smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Nov 16, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Black line on back of page
It sounds like you have a black ink leak and it is smearing onto the paper when you print. I don't know any reasons for this except if you topped the black ink up yourself, and didn't re-block the hole you made. Then I guess the ink would gravity drip onto the paper tray while you weren't printing. Otherwise I would suggest changing the print head, but this might be expensive.
Dec 28, 2007 | Canon Pixma MP500 All-In-One InkJet...
Dell A940 smeared printing
Our Dell AIO A940 stopped printing black ink (it went throught the motions but he paper came out blank). Finally got it to print by selecting:
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
Maybe it will work for you! Good luck!
Dec 11, 2007 | Dell A940 All-In-One InkJet Printer
Epson Stylus CX4800 All-In-One InkJet Printer Logo
1,863 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
