Question about EZQuest Boa CD-RW Burner
External drive won't spin to burn CD but....
It does allow me to listen to a CD in drive, an image of a CD does appear on my desktop, my system profiler does show the disc burner but doesn't show anything on Firewire. Let me know what other information you might need. I just unplugged and restarted my computer and the external drive, and that made no difference.
  • Gregoetz May 24, 2008
    It actually seems like my burner won't work if I try to use the UDF format. Everything else works as well as it did before. I guess I hadn't done quite enough trial and error.
  • Chris Braid May 11, 2010
    I take it this is a Firewire drive and is only connected to the computer by the firewire port/cable... If you have a USB cable connected then the Firewire would not register... disconnect the USB cable and restart the drive. The external drive runs because it is external and the computer is not in total control over the drive. It's just there to read the data and needs to have one path to do this... Two cables misdirect where the data will travel and confuse you as you wonder why.
The confusion over cables... I wondered if you had a Dual Interface Drive ( USB+Firewire ) and had both leads connected, Some people make the mistake of leaving one lead plugged in while adding another, This can cause malfunction but is not your case....
sometimes when I have the external USB drive plugged in I have to look for it in disk utility before I can Write to or format the Disc, This may be due to the fact that X likes internal drives and your default setting does not display your Disc on the Desktop.
The programs tend to seek the drive out hence have no trouble reading from them even if they are not on the Desktop.
USB has no problem with many multiple Devices plugged in, it was just the possibility of two leads two protocols to one Physical drive that I was questioning. Sorry for the confusion.
Posted on May 28, 2008
It is possible that the Burner in the Optical Laser has failed too.
As time goes by and dirt interferes with the  readability of the Optical Reader/writer and the device requires more of the available voltage until it can no longer provide the higher function(Burning) at this point the Drive will do the basic functions it was designed for i.e. Read DVD and CD discs, but not write to them as this takes more energy and the Laser can no longer provide it. So Yeah the Drive has probably finished it's service life as a Writer Drive.
Time to look for a Good replacment and remember to clean it every 100-200 Burns...
Posted on May 25, 2008
  • 31 Answers
The mac doesn't like writing to external drives under the earlier versions of X unless there are no internal burners.I had an external USB2/Firewire Drive case that my Macbook Pro could recognise and read from but only if one cable was used. You couldn't use both cables and read the drive twice... once as USB and once as Firewire because X is smarter than that.
I just wrote a CD in my imation External DVD using Disk Utility to control the Drive... Under Leopard I can write to an external USB Drive as if it was internal. The Drive wrote what it was asked to.
If you mount the Disk you can copy stuff to it then Burn a CD or DVD copy easy enough.
Posted on May 23, 2008
Thank you for the feedback. This issue seemed to start after I upgraded to Mac OS 10.4. Previously, I was running on OS 10.28 and had used the drive plugged in the same way for over two years.
Are you asking if I have a USB cable connected to my Firewire device or if I simply have other USB cables connected to my computer? Are you suggesting that I disconnect other USB devices? Your comment on "two cables" leads me to believe that.
The confusing part of this for me is that I can read a CD from the external drive and the CD does show up on my desktop.
Before I posted the first time last night, I turned off the drive, disconnected the Firewire cable from both it and my CPU, and reversed the process.
Could this just be a drive that has crapped itself out?
Buffalo ministation hd-pct500u2 won't allow me access to it
Go Here
And you will have to download the CD image and then burn it on to a disk. This would possibly be why you can't see it in your device manager because it doesn't know what it's looking for and how to run it. by downloading, burning it, and then installing it. The computer will then know exactly what the peripheral is and how to recognize it and run it as a hard drive. I sure hope this has helped.
Thanks, Cody
Sep 13, 2012 | Buffalo Jeans Buffalo MiniStation...
Tip
Ways to burn Discs with Finder and Disk Utility in Mac (versions OS X 10.4 -...
Without purchasing new disc burning software, there are actually 3 ways to burn CDs & DVDs in your Mac OS X system (Mac OS X 10.3-10.6)
There are methods using Finder and Disk Utility.
Both are easy to do and when set up to use will have you burning music, video, data, and image files (ISO) to CDs or DVDs in no time at all.
BURNING DISKS WITH FINDER
1.) Create a Burn folder and burn a CD/DVD
* The easiest way to burn a disc with Finder is to create a Burn folder with Finder. Here's how you do that:
* Click on any blank space on your desktop and in an instant, Finder will appear on the Apple menu bar next to the Apple menu icon.
• Click on File and select from the drop down menu
* This distinctive folder will now appear on your Desktop
* Now insert a blank CD or DVD and in moments, you will see this window pop up:
• Just click the OK button.
* In a few more moments
on your desktop, you will see this Untitled DVD (or "CD: for CD-ROM Disks) icon:
• Now you can either drag and drop files into the folder, or just double-click the folder and also drag and drop files into the open Burn Folder window
* If you notice, each file you drag (or copy and paste) into the Burn Folder window will have a small curved arrow at the bottom left corner of the file.
That is merely a designation that the file is a image of the actual file and ready to be burned to the CD or DVD you use.
* Notice the Burn button (highlighted in the red box). This is the button you will press, to commence the burn (or copying) of the data you have placed in the burn folder to be copied to disk.
• Click the Burn button, name your disk and that is all it takes. When the process is complete, you will now see a formerly Untitled Disk icon on your desktop replaced with a "Your_new_disc_name" DVD.
(Additional Note: If you wish, you can also simply bypass creating a Burn folder, insert a blank CD or DVD and simply drag and drop or copy and paste files into the open window of the Untitled CD as well.)
BURNING A DISC WITH DISK UTILITY
There are actually two ways to burn data to an DVD or CD with Disk Utility:
1.) Burn a disk in Disk Utility
* Simply open Disk Utility by either clicking anywhere on a blank space on your Desktop window and Finder will appear near your Apple menu, select Go >Utilities and that will take you to the Utilities Folder which is the default location of the Disk Utility application.
* Or you can click the Finder icon on your Dock, open a new Finder window, click on "Applications" listed in the side window and select the Utilities folder
* Either way, you will land here.
• Insert your CD or DVD.
* Once you open Disk Utility, you will see this main window
* Now all you need to do is click the "Burn" button located on the Disk Utility toolbar.
* For an example, I am striving to burn a copy of my Quicken .dmg file to CD.
* Once I have selected the file, then I click the Burn button located at the bottom right corner of the Finder window.
* Follow the onscreen instructions to start the burn process.
2. Creating a multi-session disk using Disk Utility:
Now it is known, that one cannot burn more than once with a single CD-R disc, but it can be done as provide from the knowledge base of Apple support:
  • In the Finder, create a folder for the session and drag the items you want to burn into the folder.
  • In Disk Utility, choose File > New > "Disk Image fromFolder." Then select the folder you created in the dialog and clickOpen.
  • Type a name for the image, choose a disk format, and click Save. Mac OS Extended allows burning the disc more than once. Formats such as ISO allow burning the disc only once.
  • When the disk image is complete, select it in the Disk Utility list and choose images > Burn or click Burn in the toolbar.
  • Insert a blank CD in the optical drive.
  • Select the "Leave disc appendable" checkbox. If you don't see this option, click the triangle in the top-right corner.
  • Click Burn.
What is really nice about this CD/DVD burn feature of DIsk Utility, is that now you can come back later and add more files to the same CD without having to waste all the space on a new CD-R.
This especially useful, if the image file you are need to burn is small in capacity. Just pop the previously burned CD in your drive and add that file or files until that CD is filled to capacity- that is all it takes.
So there you have it, a quick tip on how to use Finder and Disk Utility to burn any data to your CD and DVDs.
Thanks for viewing my Mac OS X tip from FixYa Support. Stay tuned for more tips for how to make the most of your Mac OS X systems!
Regards,
-Mactechtrainer
on Feb 23, 2010 | Computers & Internet
Tip
Tiny Core Linux Guide for survival (Live Linux) CD USB flash
Tiny Core Linux is a live linux distribution,
less than 10 MB runs completely in memory
and can be booted from a CD-ROM or a USB flash drive.
(This minimal desktop can be extended
by installing additional applications from online repositories)
1) How to put Tiny Core Linux on the CD
1.a) Download Tiny Core Linux
http://distro.ibiblio.org/pub/linux/distributions/tinycorelinux/2.x/release/tinycore-current.iso
1.b) Tiny Core Linux is distributed as an ISO image.
It is necessary to burn it to CD
using the option of your program to burn CDs
Burn CD ISO image (Windows - Nero / Burn Image to Disc, for example)
1.c) Then you need to restart your computer.
1.d) Depending on the options your motherboard,
it is necessary when starting
your computer keyboard press:
F8 or F12 or Esc, etc..
Thus you will appear a menu where you choose your CD drive.
After
Tiny Core Linux menu comes before you.
2) How to put Tiny Core Linux on a USB flash drive
2.a) Download Tiny Core Linux
2.b) Format the USB flash drive in the FAT32 filesystem. (Windows)
(MyComputer, right click on your USB flash drive, Format, File System = FAT32, start)
2.c) Download and run UNetbootin for Windows
to create a bootable Tiny Core Linux USB Flash Drive
http://unetbootin.sourceforge.net/unetbootin-windows-latest.exe
2.d) Then you need to restart your computer
Depending on the options your motherboard, it is necessary when starting
your computer keyboard press: F8 or F12 or Esc, etc..
Thus you will appear a menu where you choose your USB flash drive.
After
Tiny Core menu comes before you.
3.) You can start using your Tiny Core Linux easily
on Jan 24, 2010 | Computers & Internet
My acard technology pro burns dvds but the target dvds end up all scratchy like quality the pixels move and everything
is resolutions pixel problem only on the dvd disks you burn?
you might have to save the dvd to a file first then burn it to a dvd
are you copyning from another dvd or from a saved file ??
you might be burning it as data
this might be a problem with the quality of the dvd disks you are using or might be the software you are using there are lots of free burning sofrware programs on the internet
this might be because you have not selected the option to burn an audio or data dvd or your burning software does not support dvd burning
there are plenty of free burning software programs on the internet
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
http://download.cnet.com/magicdisc/3000-7970_4-10383679.html
MagicDisc Virtual CD/DVD-ROM is a utility designed for creating and managing virtual CD drives and CD/DVD discs. MagicDisc Virtual CD/DVD-ROM emulates audio, data, and game CDs and DVDs with ISO image, CD and DVD images. MagicDisc Virtual CD/DVD-ROM offers 200x speed and noiseless CD/DVD access without a physical drive. It supports creating up to 15 virtual drivers. You can run games, software, see movies (VCD, SVCD, DVD), and hear music directly from your hard disk without inserting and swapping CDs and DVDs. MagicDisc allows you to use almost all CD/DVD image without burning them onto CD or DVD in order to easily access your favorite games, music, or software programs. It works like a real CD/DVD-ROM: You can run programs, play games, or listen to music from your virtual CD-ROM. It can compress ISO CUE MDS NRG CCD image; can encrypt ISO CUE MDS NRG CCD image; can make ISO image from CD/DVD; It can mount UDF only CD/DVD image and multi-session MDS/MDF and CCD/IMG image.
hope some of this helps you
Sep 10, 2011 | Acard Technology (ARS-2030LD) DVD±RW...
Unmountable boot disk error on blue screen
first, recover your files. You will need to use some data recovery program like asoftech data recovery. you can download it from
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Asoftech-Data-Recovery.shtml
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Sep 07, 2011 | Gateway Computers & Internet
System error
I'd recommend that you use some data recovery program
Sep 06, 2011 | Computers & Internet
I have a Dell Inspiron 2200 Notebook computer. I
This might be as a result of CDROM Drive speed.
Generally the spin speed of CDROM Drives are always different, and there are some desktop CDROM drives that have Spin Speed as High as 60X...yes, because I have used one before. What in this case, I would suggest you do this, : Provided the Notebook CDROM Drive can read other disks, then just try and use your desktop to burn the CD disk onto another CD Disk, then try the newly burnt disk on your laptop.
And if you have an external drive, you can just copy the CD contents using a NERO burner software or any other CD Burning software, and transfer it to your laptop.
Hope this help you out.
Jul 10, 2009 | Computers & Internet
What does deactivate virual drive and emulation software mean.thankyou roy
You must have a virtual drive program installed, something like daemon tools or ulltra iso, What these programs do is allow you to open a cd/dvd image on your hard drive without burning it to a disc.
If you deactivate the virtual drive then you will just nedd to reactivate it if you want to mount an image to it.
All it is doing is creating a dummy drive and emulating a real cd drive on your system. Windows and the software you mount to these virtual drives can not tell the difference between virtual and physical drives
Aug 25, 2008 | Computers & Internet
Nx6110 boot issues
Try using an external CD drive. Some machines will allow you to boot from an external and some won't. If yours does and the external will boot from the CD, then your CD drive is bad. Usually it's the optical eye that goes out on these, unfortunately you have to replace the whole thing.
Jul 02, 2008 | HP Compaq nx6110 PC Laptop
EZQuest Boa CD-RW Burner Logo
437 people viewed this question
Top EZQuest Computers & Internet Experts
David Payne
David Payne
Are you an EZQuest Computer and Internet Expert? Answer questions, earn points and help others
