Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Everything has a green tint when upgraded to HD 1080.
I have a 5 year old Mitsubishi WS-55411 Projection TV. The color is fine with standard 480i input w/component cable. When I switch to 1080i and add my RGB cable and red&white audio from my HD Satelite reciever to the DTV plugs on the back panel, everything looks green. Is there an adjustment or am I connecting to the wrong jacks?
    Sergeant:
  • 154 Answers
I think you are connecting to wrong jacks
Posted on May 23, 2008
Mitsubishi WS-A65 1080 HD Series Won't Switch from 480i to 1080i
Its main digital board has to be replaced. It is a skilled work. If you wish to get more details about this work, check the site linked below and pull up older posts there.
Apr 22, 2013 | Televison & Video
I bought a used mitsubishi ws 55513 and when i turn the tv on is says 480i stretch. How do i use the 1080?
U don't get to chose modes.480,720 and 1080 it chose by the tv show itself.Want more 1080 must have HD package from cable or satalite compannies.
Jan 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 wont go from 480i t0 1080
Tries CBS or NBC channels have HD if displayed 1080i than ur box is working.The shows must say HD or Display 1080i to work HD programming.
Jan 15, 2010 | Mitsubishi VS-60111 60" Rear Projection...
Mitsubishi WS-65907 rear projection TV HD goes blue.
I would look at the source for the Hd signal as being the problem--if you are using some kind of cable or sat box it will deliver the signal to the DTV input on the back of the set--this is the HD input for this set.
It is possible to have a problem like you describe be one in the set--but very unlikely----have you looked on that green signal board for any signs of Glycol?
Anything that will produce a 1080 signal to the DTV input should tell you if the problem is the set or the source of the HD signal that is causing the problem.
If you have questions or need advice let me know--I am here to help people.
if this information has helped you rate this solution as i do this here for free.
SD TECH
Dec 05, 2009 | Mitsubishi WS-65907 65" Rear Projection...
Hdtv
hi! might be best to call Uverse so that they could guide you thru setting the right aspect ratio for your TV. hope this helps!!! goodluck!!!
Mar 28, 2009 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Feb 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi 55 inch Rear Projection w/ Green tint
C.V.G ADJ AND SERVICE MODE ? GREEN C.V.G BAR ADJ POPARLY?
YES , SO POPARLY NOT SAVE 50HZ & 60HZ
NO, SO CVG I.C DEF, ITHER PRT LANCE LOOSE
Jun 13, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Upgrading my 480 component input to 1080
Get an upconverting DVDP that puts out 1080i on component. They were made several years ago, and today it can't be done without HDMI, which your set is too old for.
Momitsu, Bravo, Lite0n made them, with the Samsung 841 hackable for that purpose. Try to find one used, and be sure to ask whether they upconvert SD - standard - DVDs from 480i->1080i before you buy. Then take that 1080i in via component, which is stellar in its performance and has none of the anomalies that are plaguing HDMI on many brands of CRT units.
Mr Bob
Feb 04, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
219 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
