Question about Dishwashers
Model RUD1000KB3 Serial FU51051535 need a diagram to show how to connect the dishwasher step by step
  • 868 Answers
To install it?
Posted on May 23, 2008
How do you change a drain pump on this machine?
Hello Jim;
My name is Peter. I am a retired field service appliance technician.
You need to post a model number so I can see what you have. The model number is located either on the side of the dishwasher door or the face of the dishwasher when you open the door.
The most common problem with dishwashers draining is that you are plugged up. You need to disassemble the dishwasher internal components first. Then, disconnect the drain hose from the dishwasher to the garbage disposal. Clean this until you can see light through it. If you can not see light after cleaning, replace the hose.
With a tooth brush, clean the inside of the drain hose connection on the garbage disposal.
Go into the following website. Put in your model number and you will get diagrams and part numbers of your dishwasher.
The drain pump may be plugged up?
On some dishwashers you can access the pump from the lower bottom panel. On others you have to pull the whole dishwasher out.
Get back to me and lets take this one step at a time. Water Filters Lawn Garden Appliance Parts
Mar 05, 2016 | Dishwashers
What do i do it says its stop in drain how can I fix that need aswer thx?
Sounds like your drain pump is clogged. Call Miele service support 800-999-1360 they will provide free step by step instructions to open and clear the drain from inside the bottom of the dishwasher tub. Have the model and serial number ready because they keep a record of everything.
Dec 28, 2014 | Miele 24 in. G638 Plus Free-standing...
Old dishwasher, lock on light blinks all time
Is this a Kenmore? If so here is Searspartsdirect. User and installation manuals, parts diagrams and parts lists and repair help.
KENMORE Dishwasher Parts Model 66515817990
Oct 26, 2014 | Kenmore Dishwashers
MODEL duiioixtpq3 ser. # fs0201257 will not run, no lights on anywhere. how old is this dishwasher?
The model number is actually "DU1101XTPQ3". If the model number you listed this question under is correct, there is a thermal fuse located inside the control panel of the dishwasher. The part number for the thermal fuse replacement is 8193762.
If you type in your model number you can utilize the exploded view parts diagrams at pcappliancerepair.com, appliancepartspros.com or searspartdirect.com to assist you in locating the part. The fuse is listed as item 6 under the "Control Panel Parts" section.
To replace the fuse, follow these steps:
1. Make sure the dishwasher is unplugged or the breaker is turned off.
2. Open the door and remove only the top screws directly behind the control panel.
3. Remove the protective cover from back of the control panel to expose the main control board.
The thermal fuse should be mounted to the control board. If you remove it and take a resistance check, it should read close to 0 ohms, if good. If bad, replace as necessary. Make sure you follow the installation instructions on the replacement fuse.
The age of the appliance is determined by the SERIAL NUMBER. The following link explains how this is determined on Whirlpool manufactured appliances:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
The SECOND DIGIT in the serial number determines the YEAR it was manufactured. The first TWO NUMBERS following that digit, represents the WEEK (52 weeks in a year) that it was manufactured. So...if I'm reading your serial number correctly, this dishwasher was manufactured January 2005.
If you have any questions about this repair, or require additional assistance, please let me know. I hope this helps you
Jul 27, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Model FDB750RCS1 Serial No TH53096343 How old is this dishwasher, Need Manual
Here complete documentation.
Complete Owner's Guide: English Español Français
Part manual: English.
Wiring Diagram: English
Installation Instructions English
May 25, 2010 | Frigidaire Dishwashers
Need a diagram of front panel and parts
Hello, If you provide me with your model number (and serial number or approximate age) I have quite a bit of Asko literature & illustrations at home on my pc ( I'm on my iphone presently but will be home in an hour or so ) and I could potentially have one for your model. I'll watch for your reply. Macmarkus :)
Apr 05, 2010 | Asko D1716 Built-in Dishwasher
Dishwasher will not turn on
Bruce, It would be great to know the model number of your your Kenmore Ultra wash dishwasher, please look on the right hand side of the door for a model/serial number if possible.
First steps: With no power, please check how the dishwasher gets power. If it is plugged in to an outlet under the sink, please confirm that it is plugged in fully. If that does not fix the problem and if it is plugged in, remove the dishwasher plug and plug in any lamp or small appliance and make sure it turns on.
If no power at the outlet, check the house circuit box for a tripped breaker/blown fuse. Also, check if any of the outlets have GFI (Ground Fault Interupt) circuit protection. Reset that outlet (even if it is not not the same outlet as the dishwasher is plugged in to.
Next steps: If the dishwasher is connected to a live circuit but still does not work, a component in the dishwasher has probably failed and a service call is in order. Or replacement of the dishwasher, depending on its age.
Please accept this solution soon after walking through the steps - or add a comment with an update and I will try to help more.
Mar 28, 2009 | Dishwashers
Diagram
Go to searspartsdirect.com and type in your model number as "587.712403". This omits the space you had between the last 6 numbers. There are helpful exploded view parts illustrations available for every section of your dishwasher, including the lower pump and motor assemblies. In addition, if you require replacement parts, the part numbers are also provided. I hope this helps you.
Sep 04, 2008 | Dishwashers
Dishwashers Logo
19 people viewed this question
Top Dishwashers Experts
