Subwoofer amplifier hum on high bass boost.
I got a Dell Altec Lansing sattelite 2.1 speaker setup (ACS340) that I've been using for years. I like to listen to techno from time to time, and I turn the bass up all the way for it. With no signal, I get some pretty annoying hum. I was wondering if there was a way to mod it with some better filtering. There's no ground, so loops is out of the question.
Try attaching a crossover caps of 0.22mf over the inline resistor(out put). This will filter the humming sound created when no sound is played.
Roshan.
Posted on Sep 29, 2008
Power supply out put rating ? lost the original power adaptor that came with system acs340. trying to use a substitute
what is an acs340 ?
Is it a Altec Lansing subwoofer speaker for a computer
google search a4432 altec
13V 4A DC
If you decide to buy one check the input AC voltage matches your power outlet supply voltage 120Volt AC 60 hZ or
is it 240V 50
Hz - get it wrong and smoke may escape from the power adapter after the big blue flash occurs.
https://www.ebay.com/p/Genuine-OEM-Altec-Lansing-A4432-ACS340-Subwoofer-Power-Supply-13v-4a-AC-Adapter/664023647
Feb 11, 2018 | Power Computers & Internet
Wiring diagram for altec lansing acs340 sub woofer
This is not something that you will get access to from here. Try asking a repair shop if they can get the schematics for this speaker. You could also contact A-L directly.
Not likely to happen.
Altec Lansing ACS340 Specs CNET
Furthermore these are inexpesive 2.1 speakers that can be replaced for 30-40 dollars. Not worth the effort.
Mar 09, 2015 | Altec Lansing Audio Players & Recorders
My speakers only the bass when i hook them up i hear the bass but not the sound please help
It sounds like you have subwoofer system that requires satellite speakers for the high frequencies. If you have these satellite speakers, but are getting no sound, either you have connected them incorrectly, or there is a problem with the amplifier that drives the satellites.
Oct 06, 2010 | Altec Lansing 121i Computer Speakers
Need advice on Altec Lansing x5021
Altec Lansing is the best company to buy speakers if you watch movies or listen to music. it hits both deep and a strong bass. These are the best speakers to buy.
Feb 25, 2010 | Altec Lansing MX5021 System
Connecting an Altec Lansing ADA995 subwoofer system to a stereo
I have this exact Altec Lansing speaker system and I'm currently just using it with my Dell computer. But, I know you don't have to install these speakers to any high powered receiver for good sound quality. The subwoofer has two separate 200 watt RMS combined amplifiers built in for it's single knob controlled dual 6.5" bass drivers and 2-way magnetically shielded satellites, which are amplified together by any source that has an analog or digital volume control. The speakers act as a preamp receiver to any volume or frequency tone level controlled audio source. These input sources can also equalize the speakers receiving input signal for bass, treble or mid-range adjustments. You only need to obtain the proper adapter to hook up all the speakers to your desired component or device. Besides a computer, for example a TV with a variable audio out function or a mp3 player will work. The adapter that i am referring to is similar to what is included with certain 5.1 Logitech brand computer and multimedia speakers specifying gaming console and TV connecting. It has all three color coded 1/8" connector inputs on one end and RCA jack outputs on the other. This can be purchased more easily online then offline at stores such as Ebay for a fairly inexpensive price. However this adapter will not decode true 5.1 surround, but instead give a 5 channel stereo effect. I guess if one was looking for an inexpensive alternative solution to purchasing traditional high end home entertainment audio equipment, the ADA 995s are one of few computer speaker models in my book that can do a decent job.
Jun 19, 2009 | Altec Lansing ADA995 Speaker
Subwoofer making load humming noise
The reason for the hum in the Altec Lansing VS4121 speaker system is the stray field of the power supply transformer. This stray field is strong enough to affect the amplifier. All other reasons given by numerous reports on the web do not apply. If you are handy and have got the time you may mitigate the problem by physically moving the amp away from the power supply or turning it 90 degrees. I managed to lift up the amp in my subwoofer by about 50 mm, which was difficult to achieve and did not cure the problem perfectly. I don't see any other way to solve this problem except you feed DC in from the outside and do not use the internal power supply. That would be really odd indeed
Gerhard Weber.
Jan 29, 2009 | Altec Lansing VS4121 Speaker
Crackling Sound From Subwoofer
Check any wiring coming or going to the subwoofer. It sounds like it could be a loose connection.  Is there a LFE or bass boost knob on your subwoofer? Does turning that up/down cause the crackling (if it exists). If so, you could use some tuner cleaner to clean the contacts on the potentiometer knob.
If the crackling is on the subwoofer only, it might be damaged from bottoming out.  See if you can remove the baffle or grille covering the woofer and inspect for visual problems. You can also try to lighly push in and out on the subwoofer to hear if it makes any scraping sounds. If so, it is definitely damaged and the driver will have to be replaced.
Mike
Jan 21, 2007 | Altec Lansing 221 Computer Speakers
1,002 people viewed this question
 Grubhead
Grubhead
