Question about Honeywell Heating & Cooling
My Honeywell L4103 Aquastat & High Limit Controller for my oil-fired hot water tank won't set the temperature no matter which direction the setpoint scale is turned. Instead it cuts off via the high limit controller at around 140ºF which is too hot. I would like to set it to 120ºF. Can this be repaired or do I have to replace the entire controller? rjs@goodread.com
refritech08
  • 149 Answers
SOURCE: I want to adjust the
To enter the adjustment mode, press the UP, DOWN, and I buttons simultaneously for three seconds. Press the I button until the feature requiring adjustment is displayed:
• HL —High Limit.
• LL— Low Limit.
• Ldf —Low Limit differential.
Then press the UP and/or DOWN buttons to move the set point to
the desired value. After 60 seconds without any button inputs, the
control will automatically return to the READ mode.
(copied from honeywell's instructions)
to clarify the differential is cut in minus the cut out.
Hope i can be some help to you.
Posted on Apr 21, 2008
  • 15 Answers
SOURCE: have an oil fired boiler
These boilers usually have multiple controls. The control that would take it out of the circuit at 210 degrees is a safety.
You should definitely have a professional take a look at this unit before you continue using it.
Posted on Sep 18, 2008
  • 234 Answers
SOURCE: what would the correct high and lo and diff
I would say high if you need cooling. If the tempature is cool enough for you then set it to low.If you are hot and need more cooling then high.
Posted on Apr 07, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: what is the recomented settings for high and low
180 with a differential of 15 or 20. So 180 high and 160-165 on low.
Posted on Nov 03, 2009
Testimonial: "Thanks"
  • 949 Answers
SOURCE: HI IAM A ELECTRICIAN WORKING
I would suspect a water circulation problem, most likely air in the system, if the water can't flow it will overheat.
If the problem persists after bleeding check to make sure the pump is running
Posted on May 06, 2010
Is it possible to lower the top temperature on the thermostate. I can change the lower temp but not the max which I wish to set below the 180 level. Thanks
there is a high and a low limit on these units, the two control knobs are actually the reverse of what you are trying to accomblish,first lower the bottom or low cut off temp first then the high temp ,it must cycle a couple times for it to adjust
Jun 06, 2011 | Honeywell L4103A1019 combination aquastat....
My L4103 aquastat is set too hot, it does not clearly stat temps on set dial which way do i turn it to lesson temp
phl4103-3.jpg on the left side of the dial will be a little metal arrow that will not move when the dial moves, this is the set point. set the temp. you want at this point.
Dec 17, 2010 | Honeywell Heating & Cooling
My john wood hot water tank over flows through the relief valve every 3 - 6 months. The hot water is too hot and I can't seem to adjust the Aquastat L4103 on the hot water heater to a good temperature....
There should be plate on the front of the hot water heater tank.. Pop that off..
There might be some insilation to move and you should see a set screw for adjusting the temp..
If there are no indications for hotter or cooler - then do a 1/8 turn to a 1/4 turn counter clockwise..
Hope this helps !I
rate me good ;o)
Jul 14, 2009 | Honeywell Heat/Cool Thermostat
What would the correct high and lo and diff settings for the Honeywell L8124A Aquastat I have a wood fired boiler with the oil fired boiler side by sides,
Apr 05, 2009 | Honeywell Heating & Cooling
I want to adjust the hi and low water temp limits for my oil hot water boiler; I have a Honeywell L7224 aquastat but I cannot find any temperature indicators; how can I do this?
• HL —High Limit.
• LL— Low Limit.
Apr 21, 2008 | Heating & Cooling
Heating & Cooling Logo
603 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
