Question about Goldstar DH504EL Dehumidifier
Dehumidifier problems I have a Goldstar Dehumidifier it was working then all of a sudden it started icing up in the back and will not drain any water.
    Brigadier General:
  • 6,966 Answers
Might it be that the unit simply needs a full thorough cleaning including the tiny spaces between fins? Dust can gather and block air passage on many of the components of a dehumidifier not only on the filter. in some extreme cases, the unit could be undercharged (insufficient) coolant. A service shop engaged in the business of cleaning and repairing air conditioners should also be able to work on your unit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 04, 2008
GOLDSTAR DEHUMIDIFIER SUDDENLY NOT LEAVING ME MUCH WATER IN CATCH...FREEZING UP IN BACK?
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
May 19, 2011 | LG DH30 GoldStar Dehumidifier
Dehumidifier freezes up
heatman101
May 26, 2010 | Goldstar DH5010B Dehumidifier
My Goldstar dehumidifier is still draining water, but is forming snow/ice out the top of it. I've had a couple of years and has worked beautifully. Any suggestions?
Your unit has a sealed system leak. The sealed system is warrantied for five years. Find your receipt and call an authorized LG dealer to initiate an exchange.
Sep 30, 2009 | Goldstar DH504EL Dehumidifier
Ice forming on back of dehumidifier
water is not draining properly. make sure unit is balanced upright and there are no clogs preventing the water from draining
Aug 26, 2009 | Goldstar DH4010B Dehumidifier
Why did my dehumidifier start draining into the bucket when I put the drain hoze? Previous to putting on the hoze it was draing out the back.
Check for crub which may be blocking the drain hose. Blow the hose out by connecting it to your outside garden hose and turning on the water full force. Then reattach it to your dehumidifier.
Jun 25, 2009 | Goldstar DH304 Dehumidifier
Icing on back of coils on dehumidifier
could be dirt coils or low freon either way needs to be checked
Mar 27, 2009 | Goldstar DH3010B Dehumidifier
Icing on back of dehumidifier
heatman101
Mar 25, 2009 | Goldstar DH3010B Dehumidifier
The hose connector does not drain the bucket, it drains the condensate before it enters the bucket. Tube passes through back of dehumidifier by the cord wrap area. (you may have to remove a small cover)
Aug 25, 2008 | Goldstar DH504EL Dehumidifier
Two possibilities:
1. Continuous running and there is water coming out of the unit to the floor drain; the unit is just doing its job. It is probably just that there is that much humidity in the room;
2. the sensors are faulty or were bypassed during the repair - the sensor would be testing the water coming out, if there is water, the unit continues to work, if none, then it shuts off. Most would also have an overfill float switch, again which could be bypassed, that likewise control whether the unit will continue to run or stop.
Jun 03, 2008 | Goldstar DH504EL Dehumidifier
Goldstar DH504EL Dehumidifier Logo
90 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
