Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Did you get your flash fixed on your SD500?
I have the same problem you had with my SD500 - I dropped it and it will take a picture w/o flash, but the lightning bolt just blinks and won't take a picture when the flash is on. Wondering if you were able to get it repaired and how much it cost?
  • msudilligaf Jun 22, 2008
    My flash stopped working also with no apparent reason (didn't drop it, etc.). The flash indicator only blinks
  • Anonymous Aug 18, 2008
    I have the same problem and i was hoping that i could fix it, or some local place could. My flash (lightning bolt) just blinks, but if i turn the flash off i can take a picture. I talked to Canon and they charge like 159.00 just to fix it. Please help........
  • Canon Master
  • 4,738 Answers
Your flash may either be burned out/damaged, or the flash safety circuit thinks that the camera is open. If the flash is burned out, then professional repair is required, as a flash change-out is not trivial (Call 1-800-OK-CANON).
However, it's more likely to be only a break in the safety circuit. Many Canon cameras use some of the screws in the camera case to serve as a means of detecting if the case is open (and thus disables the flash to prevent shock). Examine all the screws around the perimeter of your case. Are they all there and tight? If not, tighten loose screws and try moving and replacing any missing screws with one of the others that are still there.
Posted on May 28, 2008
Hi there, I was taking photos with a 3 years old canon ixus 70 and suddenly the screen became black!! from then taking picture was impossible it comes out black too. All the menu buttons work properly,...
First verify that your camera is actually an SD500 (takes SD cards) and not an S500 (takes CF cards). If your camera is actually an S500, this would probably be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Now if your camera is indeed an SD500, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Feb 27, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
We have two. They both just got blank viewfinder & no picture at same time
The symptoms you're describing are very unusual for an SD500, but not at all for an S500. Please confirm your camera. If an S500, Canon will fix for free.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
But if your camera is indeed an SD500, A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Feb 14, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
My flash does not work anymore. i can take a
Hi Dear,
This issue is due to some electrical circuit failure in your camera which is responsible for the flash to work.
Please show it to the nearest service center. And please do not try to fix it on your own as problem might become complex.
If you need more information on this please do write to us again.
Have a nice day.
Nov 09, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
My camera is showing blurred pictures when taking pictures help
Try reseting all menus to default, then try again to test.
Make sure the lens is clean.
Do the menus appear clear?
Has the camera ever been dropped or had any other damage? This could get the lens out of focus, and would need repair.
Does blurring happen when zooming or when taking a picture of any kind?
Sep 09, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
I dropped my camera and now it won't take a picture if the flash is turned on
Typically yes, it should be repairable, but not by most individuals or even camera shops. It should go to Canon, or their authorized service facility in your area. Camera manufacturers won't sell "parts" (as opposed to accessories) because many people try to install them themselves, damage the part and the camera, then blame the part and want a refund. Send it to Canon, get an estimate, then decide if it's worth the cost.
May 24, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Flash lights fail
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2008/05/simple-fixes-for-cameras-that-wont-take.html
Jun 03, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon powershot sd300 e18 error
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 16, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Dropped Canon PowerShot SD500
See Canon SD 600 posts referring to Lens Error, restart camera. I just fixed mine today.
Feb 24, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Focusing wont work after dropping
probably the lens inside is damaged or the mechanism which moves the lens is damaged. Focus works with a moving mechanism which moves the lens back and forth.
Oct 07, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Won't take picture
If the lightning bolt continues flashing and never stops there is a failure in the flash sub-system. Try selecting the no-flash setting, if the camera fires normally at this point then your problem is definitely in the flash system. It is hard to say what the failure is beyond that. The problem is the camera will not take the picture until the flash is charged and ready to fire - the flashing lightning bolt indicates that it is charging the flash. The fact that it just keeps flashing indicates that the flash is never becoming ready. This repair could cost $68 to $125 plus parts to fix, although an evaluation would be necessary to identify the problem.
Jun 05, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
101 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
