Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore model 16039/665.16039403 will not start...does not appear to have power
My Kenmore model 16039/665.16039403 is just outside of warranty and will not start...it does not appear to to be getting power because the lights on the console will not light at all. I have confirmed that power is getting to the unit though. Does this mean the control panel is dead? Thanks in advance for your time and assistance.
  • rsavage Jul 28, 2008
    I have a Kenmore dishwasher model 665 (black, approx 4-5 years old) that acts like it is not getting power as pushing the buttons does nothing. It has not been "acting up" rather it just acts as though it has been unplugged. I have removed the front bottom panel and confirmed that power, and water, are getting to the unit. Any idea's?
  • Anonymous Mar 18, 2014
    My Kenmore 16039 dishwasher won't latch. It appears the latch is broken. How do I replace it?
  • 413 Answers
There is a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the housing.
Posted on Jun 02, 2008
How to remove oven door on Kenmore Model 66504493392
The exploded parts view of this oven appears to show that you can access the upper and lower door hinge tabs by removing the outside cover.
Jun 26, 2016 | Kenmore Microwave Ovens
What is the size of my kenmore 253.77879506 top freezer fridge
This appears to have been sourced from A. B. Electrolux (Frigidaire) but Sears does not supply a capacity. The outside dimensions can help determine the capacity as most 18 cu. ft. units will be approx. 66" high while 21 cu. ft. models will be 68" high (or higher.)
Oct 22, 2014 | Kenmore Refrigerators
Kenmore heavy duty solid state dryer, mdl 1108609420 (???) Starts and all functions work as long as the Start Lever is held up. As soon as you let go of it, the dryer stops. Unable to locate...
repairs should be performed by a authorized repair person.if there is not enough voltage to the relay start switch from the electronic control replace the control. if there is enough voltage to the relay start switch replace the switch.
Jun 04, 2017 | Dryers
I have a kenmore dryer series 80 model#110.66812690 it is blowing cold air. Does any one have an idea what could be wrong?
Is it gas or electric? If it's electric, it will have a large, gray 220 volt power cord. If it's not under warranty, you'll have to call a local repairman. It's probably the heating element. Easy things to check. Make sure your lint filter is not clogged. Check the vent cap outside and make sure the flap is not stuck and is easy to open. Using a flashlight, make sure it's not clogged inside the vent either. The back opening of your dryer may be clogged as well, but it may not be easy to check. Hope that helps.
May 14, 2010 | Kenmore 63942 Dryer
I have a digital set top box model teac dv-b800.this unit now has a flashing c-100 code has soon has you power same up and nothing else.Can you tell me the problem.
appears to be a known issue with your model of set top box and teac is aware of the issue, but will only repair for free if you are within your 12 month warranty period, if you are outside warranty, consider repairs as they are approx 60.00 and the fix appears to resolve the issue.
Cheers!
Feb 14, 2010 | Audio Players & Recorders
Kenmore gas dryer model 75291. The gas dodes not start
first, check to make sure gas present to unit, and power to the ignitor. if no power, replace timer, if power, check the ignitor for continuity, if open, replace. If ok, check to make sure none of the thermostats are open, if they are, replace. If ok, check gas valve solonoids, they should not appear melted or stuck, if so replace. If still no function, replace gas valve.
Jun 30, 2009 | Dryers
My kenmore Elite Dryer model he3 starts but there is no heat, what is up with that and what can I do to fix it since my warranty is over.
Most dryers stop heating due to a clogged vent or duct. Check your duct hose inside the house for lint/water clogs. You will have to remove it to do this. Then check the outside vent for lint clogs and make sure that its opening properly (louvered vents). If thats not the case, call up Sears and use your warranty.
Jun 05, 2009 | Dryers
Kenmore elite top loader
Call or email the consumer feedback or make a complaint to Sears. I had a similar prob. Sears ending up replacing rhe washer and paying for rental. Took up to 3-6 months, calling and writing complaint letters.
Jun 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Refrigertor cycle rapidly
2109, start with the overload and relay on the compressor, see if it's contained in a white box. Take it off and shake it, see if it rattles. If so, that's probably the problem. If you find the overload and relay good, the compressor may be bad, the good news is that is covered by warranty for 5 years, parts and labor. The overload and relay will not be covered under warranty, could be expensive if an outside service does the job. Part number for the relay/overload, 4387938. Catriver..post back.
Apr 11, 2007 | Kenmore 62083 Top Freezer Refrigerator
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
381 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
