Question about Kenmore Elite 45986 Front Load Washer
Message on washer display
I had a "sud" message. What is it and what does it mean?
  • 5,911 Answers
The "SUD" error is either an indication of too much detergent, improper detergent, or a drain pump problem.
If you are not using HE detergent, you need to be. These washers are designed to use HE detergent which is formulated for wash tubs that use 5 to 7 gallons of water. If you use regular detergent, you are, in affect, placing a more concentrated detergent in the washer that is formulated for wash tubs that have a 35 gallon capacity. The manufacturer should have a disclaimer in the owner's manual explaining this. In most cases this will also void your warranty.
If you are using the correct detergent, double check the label to make it is not double or triple concentrated. You could still be placing too much soap in your wash.
If you do not have a detergent issue, double check the drain pump and drain lines to ensure they are not obstructed in any way. Click on the following link for step-by-step instructions:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
All of these issues can attribute to air getting trapped in the drain pump and cause the error code. If you need further advice, please let me know. I hope this helps you.
Posted on May 23, 2008
Washer stops running and displays code SUD. The water doesn't drain until It's put on the rinse/spin cycle.
Make sure you are using HE (High Efficiency)detergent. The codes could mean your washer is telling you it has used a built in "SUD" routine during final rinse
Jul 18, 2015 | Whirlpool Duet GHW9150P Front Load Washer
What does it mean when SD is showing on the display
The Sd (5d) error code is displayed on this washer when the machine control board detects a suds-lock condition by analyzing the drag on the washer basket. It will be displayed while the control runs a mini-clean out cycle. If this clean out cycle is unable to remove the excessive suds and correct the condition, then the cycle will end and Sd will flash in the display.
Make sure that you are using HE (High Efficiency) detergent in the appropriate quantity in your washer. If you detect excessive suds in the washer, this likely caused your problem.
Another cause could be a toy or other item under the washer that would cause friction on the drive mechanism. If you do not see excessive suds, check for this type of problem under the washer.
Jan 19, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
I have showing 5d does not spin what does it mean
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Jan 04, 2015 | Kenmore Washing Machines
On the last load, there was a message on the screen the read Sud what did that mean?
to much detergent,sud is for suds.try running the washer with nothing but water,after 5 minutes drain out the water to get the suds out.are you using H.E. detergent and if so it should only be like 1/4 of a cup,any more can damage the machine,the extra detergent can damage the spider gear in the washer.
Apr 09, 2011 | Washing Machines
My maytag clothes washer Bravo quiet series 300, keeps flashing a Sd error code. Or it may be 5d
What does the Sd code mean?
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Is the drain hose kinked or clogged?
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Dec 27, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Error code HF
Washer displaying code message and tone sounds S "HF" 0Nater Inlet Problem--no water or insufficient water supply) Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service. "F02" (Drain Problem) Select PAUSE/CANCEL twice to cancel the cycle, Unplug washer or disconnect power. Cl_eck the following: Is the drain hose kinked? ts the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96 in. (2.4 m) above the floor? = "SUD" (Suds Routine) When excessive suds are detected, a suds routine
Sep 23, 2010 | Kenmore Elite 45986 Front Load Washer
My washer is displaying an "F02" message. What does this mean?
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayedfc2323f.jpg3830f06.jpg 600f261.jpg
Your tech sheet? GHW9150PW0 Tech Sheet # 8182277 Rev #
Duet service manual and codes
Rate it or hate it:
Sep 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does the "sud" message mean?
hello fo2 means if the drain time exceeds 8 minutes the water valves are turned off and f/02 flashes. things to check / check the drain hose for any kinks and blockages check the electrical connection to the pump make sure the pump is running / check the drain pump filter make sure its not block if these do not sort the problem replace the pump. to clear the display press pause and cancel to clear good luck
shaun
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Suds on display screen
run washer with no load or detergent to be sure no suds remain use HE detergent only..if you are suds is not an issue remove lower panel and clean pump ..turn white knob counter clockwise ..electronics can get confused sometimes too
Jul 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Display panel reads SUDS
The SUDS message relates to overdose of detergent detected during the Wash Cycle. This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds. If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent. Check the drain hose and make sure it is not plugged or kinked. Good luck!
Oct 28, 2006 | Whirlpool Duet 3.8 cu. ft. Front Load...
Kenmore Elite 45986 Front Load Washer Logo
54 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
