Question about Refrigerators
Ge profile refrigerator won't run
I moved my frige to the garage and now it won't run. It ran fine before.The light comes on and the thermostat is set at the initial setting. It clicks but nothing happens. Is there a fuse that might be blown or a reset button somewhere I can push?
  • 5 more comments
  • Anonymous Jun 01, 2008
    moved my refrigerator up stairs to garage from basement now it wont start !! What can be wrong ?? Thanks !!!
  • rcm1121 Jul 19, 2008
    The refrigerator was operating normally then I notice that neigher the compressor or the fan were working. The interiro light functions. I unplugged the applicance for about 2 hours to see if it might reset itself. No luck. Any suggestions ?
  • bhljoe Jul 30, 2008
    When I plug in my GE fridge, the lights turn on, clicks are heard, panel lights dim momentarily, but there is no compressor sound, no cooling. Any ideas?
  • GEJOJO Sep 28, 2008
    IT STARTED WITH THE ICE/WATER DISPENSER MALFUNCTIONING, NOW IT CLICKS, UNTIL I PRESS THE ICE LEVER. IT STOPS CLICKING FOR A FEW SECONDS THEN RESUMES.
  • mommadotoo Nov 03, 2008
    GE Profile fridge doesn't work. I went away for the weekend. My friends who were housesitting noticed that the icemaker wasn't working. So they "fixed" it. When we came home, we noticed that the freezer was at 36 degrees. A few hours later we noticed the fridge headed toward 60. We made sure the temps were set to 0 and 36, but nothing is happening. We did wait 30 minutes (actually now more like 3 hours) to see if it was in defrost mode.
    The manual says something about showroom mode.
    What's that?
    Could that be the problem?
  • ws3030 Jan 16, 2009
    I have a GE GDS20KBSBCC bottom freezer-refrigerator. Last night it started clicking {relay on the motherboard in the rear of the fridge}, but the thing never kicked on,I uncovered the panel to see if anything fried on the board but nothing to the eye was wrong. The fridge is 18 monthes old. Bad chip? Bad relay? Any feedback for a solution would be great. Thanks Walter
  • finnstree Mar 08, 2009
    my fridge fairly new one day the fridge side stopped getting cold while the freezer was working fine. there is a little flap in between the fridge and freezer letting in cold air from freezer. when tis stared happening we woul defrost freezer and all was good for a few days then this would happen again. repeated several times. the last time we un pluged it would not turn on at all. lights work. any aswers would be great. GE serial #sd229676
  • 828 Answers
Where is the click sound coming from. There is no fuse in the unit. If light comes on you have power. If it is a frost free refrigerator it will not come on if the defrost timer is in the defrost position. There is no reset button. Did you wait about 20 minutes to see if it would come on by its self?
Posted on May 23, 2008
Is there a reset boton on my GE fridge
Posted on Mar 06, 2010
Ge profile 26 pfss6pkx Light comes on but won't get cold, no fan running
It doesn't cool
  1. Condenser coils
Make sure you dust off the condenser coils to prevent dust build up and overheating due to it overworking. Simply unplug and use a long coil cleaning brush to get rid of debris.
  1. Check seals
If your refrigerator door seal is broken, warm air is pushing its way inside the unit, thus causing it to not cool properly. Prevent this from happening by replacing your seal and keeping the cool air inside.
  1. Temperature controls
Ensure that your thermostat is set correctly, usually 38-40 degrees Fahrenheit.
  1. Defective condenser fan
When this fan is defective, cold air is prevented from flowing through the vents. It may require replacement.
  1. Compressor issues
Check if there are clicking sounds coming from the compressor as it tries to start. If there is a clicking, it is one of only two options, either the start capacitor or a bad compressor. A start capacitor is fairly inexpensive whereas a sealed system repair on the compressor is very expensive and often not cost effective. Refrigerator Repair Help Troubleshooting and Parts
Aug 15, 2014 | GE Profile PFSS6SMXSS 26 French Door...
Ge tfg27pfxa profile with cooling problem
Remove the back panel in the freezer to see if the defrost heater is running continually.
Nov 06, 2012 | GE Refrigerators
GE Profile Side by Side Model TFX22PRXDBB not working
IT MAY BE IN THE DEFROST CYCLE RIGHT NOW GIVE A HOUR TO SEE IF IT COMES ON
Nov 01, 2012 | GE Refrigerators
MY GE PROFILE MODEL PSS26LSRE SIDE BY SIDE FRIGE CRISPER IS FREEZING UP
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE Profile PSS26NGS Side by Side...
My Ge side by side freezer was thawing now it
Might just be a freezer thermostat gone bad by sticking in an open position. If that's the case you will be out of control in temp settings. Hope this has helped!!BB
Dec 15, 2009 | GE Profile PSS26NGS Side by Side...
Frige not cooling
The GE Profile is a complex but efficient refrigerator. We will need to check a few things like the evaporator, defrost element, defrost thermostat and the mother board. Let me know if you want me to go through this with you, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsandtechnicalservices.blogspot.com/
Jun 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GFI outlet is tripping because of refrigerator in the garage.
Hi: Yes, replace the GFI outlet. A refrigerator should not be plugged into one for what you are experiencing and food loss. This was an easy answer for me, but unfortunately not for you The owners manual covers this, but us men don't read them (Well I had to as I worked with them for 30 years). Good luck, Jeff
Jun 01, 2009 | Whirlpool ES5FHAXS Side by Side...
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
4,965 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
