Question about GE WBVH6240F Front Load Washer
Ge wbvh620f will not run
Washing machine will not start cycle load of clothing in barrel only lights that come on are door locked signal
  • 3 more comments
  • Anonymous Jul 05, 2008
    the door locked light stays on and the machine will not start a cycle. Tried unplugging, resetting, start button hit twice. Nothing is working.
  • Anonymous Jul 10, 2008
    Same problem...first the washer wouldn't drain right, now it is stuck on "door locked" other lights at all. Have tried unplugging and replugging, but can't get it to do anything.
  • randyjr_1782 Jul 26, 2008
    We have had the same problem for 1 yr of the 1.5 yrs we have own this piece of junnk
  • tegarc4150 Aug 18, 2008
    same, washer stops in or right before drain cycle.
  • kurt Jan 03, 2012
    Does anyone know the solution ?! same thing happened to ours. replacing the door latch assembly is the option, but nobody said it has worked !
What is the solution? i have the same issue
Posted on Aug 18, 2008
  • 3,587 Answers
This is a good candidate for a premium solution, me thinks..
Posted on May 23, 2008
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service
Jan 28, 2016 | GE Washing Machines
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
How to operate the washing machines front load washer brandt bf850
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    Nov 04, 2010 | Brandt WFH1176 Front Load Washer
    I overstuffed my GE front load washer and now the door won't unlock. How do I manually override the door lock feature? Thanks!!
    Let it run through its cycle. At the end take 1/4 of the clothing out put it aside in a hamper. re run load with some of the clothes taken out. Then washer the other clothes afterwards.
    Mar 05, 2010 | GE WSXH208A Front Load Washer
    GE Adora Frontload Washer shredding clothes
    We were having the same problems with ripped clothing and longer cycles. Our rubber seal by the door has ripped twice now causing massive amounts of water to run out. I learned through other threads that many people are having these problems and was told that zipping up zippers and turning jackets and clothing with big heavy stuff on them in side out to protect from ripping the clothing and the rubber seal. I removed the panel on the front bottom of the machince and there is a small gray cover that housed the coin trap. Mine was clogged and once I cleared that out, my cycle times got better. I hope this was somewhat helpful. We definitely won't be purchasing another GE front loader!!
    Mar 29, 2009 | GE WSXH208A Front Load Washer
    Control Lock is on my front loader.
    ok, you are in the model selection part of the service mode. for 6240 I believe the model code is 3 select this and press start. normally to release control lock press and hold small I button by start button.
    if model selection in incorrect it can still be corrected. only difference in models is cycles matching the labels. you can tell by the time indication for each cycle if it doesnt look right then check book inside top cover
    Mar 29, 2009 | GE WBVH6240F Front Load Washer
    Door wont lock
    I solved my own problem...
    The machine stopped due to either a heavy load or clogged drain. I cleaned the drain (by taking pannel off the front of the machine). Then, the machine wouldn't cycle and it said "door locked" but the door wasn't locked. Basically, you have to let the machine finish a complete cycle (whether or not it actually does anything). Every time the start/pause button flashes, push it to have the machine try to start. This will eat away at the time. Eventually it will finish the cycle and say 0:00. Now it should run. This can take up to 2 hours so be patient!
    Mar 28, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
    GE Energy Star WBVH5200 Front Load Washer
    My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
    Jul 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
    GE Energy Star WCVH6260F Front Load Washer: door locking problem
    Had the same problem, this fixed it!
    Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
    GE WBVH6240F Front Load Washer Logo
    167 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
