Question about Jeep JX-CHR Boombox
Jeep boombox MODEL # WPSS-1A by tela mania, made in China. The unit is 15/20years old and never used. I puged it in and the volume is real low and dose not change with the turning of the knob. It has a unique potntiometer, which has six pins at a right angle that solder to the board. Do you have any idea where I could find a replacement??? Thank You.
  • 2 more comments
  • acolone Feb 17, 2009
    Jeep radio Model WPSS-1A. I bought it new and maybe used it a couple of times. I haven't used it in about three years. Plugged it in and turned it on and radio volume is really low. So low you can barely hear it. Volume knob will not change it. Help
  • lopeka Apr 20, 2011
    That was a long time ago, 2008, but as I remember I went Through KNG America and purchased a new sound board for $28.00. U will have to have a solder gun and remove the old board and solder in the new one. It totaly fixed mine works great. Here is a link, as I recall I asked to talk to tech support, give the make model # ect of the radio, explain the prob, and ask for a replacement sound or tunner board( I can not remember what they called the part) http://www.manta.com/c/mm7jbzb/kng-ameri...
    In the event the link dose not work there phone # is (631) 389-5642.
    PS. kng stands for Kash N Gold Ltd, if u need to do some searching.
    Good luck, Hope I was of some help.
  • John Port Jan 22, 2016
    You might also try electronic component suppliers such as Digi-Key Corporation. The Panasonic EVJ-Y series of potentiometers may contain a direct replacement.
  • John Port Jan 27, 2016
    To follow up on my earlier comment, Digi-Key Corporation has a suitable replacement still available, Digi-Key Part# P2K5503-ND. It is electrically compatible, and will work like the original, but requires mechanical alterations to fit. You will need to shorten the shaft and reduce its diameter to fit the JEEP knob adapter. Lead spacing is also different and requires some careful bending. If you are a reasonably handy DIY type, its an inexpensive solution to the problem.
Iam looking for parts for my Jeep JX-CHR Boombox
Posted on Jun 20, 2009
    lopeka4 minutes ago
    That was a long time ago, 2008, but as I remember I went Through KNG America and purchased a new sound board for $28.00. U will have to have a solder gun and remove the old board and solder in the new one. It totaly fixed mine works great. Here is a link, as I recall I asked to talk to tech support, give the make model # ect of the radio, explain the prob, and ask for a replacement sound or tunner board( I can not remember what they called the part)http://www.manta.com/c/mm7jbzb/kng-ameri... In the event the link dose not work there phone # is (631) 389-5642. PS. kng stands for Kash N Gold Ltd, if u need to do some searching. Good luck, Hope I was of some help.
    New Friend:
It probably has a dual section potentiometer, one shaft drives both sections, one for each amplifier channel, very common part., look up digikey.com, try spraying internals of pot with contact cleaner before replacing. Does anyone have a users manual?
Posted on Oct 07, 2016
I have the exact same problem, let me know if you find a solution.
Thanks.
Posted on Apr 20, 2011
    lopeka4 minutes ago
Minimum volume way to high
There may be a low/high switch which lowers or raises the base sound level before the volume control has any effect.
Mar 11, 2015 | Coby CX-CD248 Radio/Cassette/CD Boombox
Will not start
why would you do that?
any DMM or VOM will test a fuse with 100% accuracy on low ohms scale.
did you use real fuses, Buss or little fuse or China clone fuses.... junk?
no year strated
no model jeep
no engine options,
strike 3 , i give up.
Jan 27, 2014 | Jeep Cars & Trucks
Jeep boombox the volume wont go up and stays low I can here it.
First obvious question...did you check the batteries? If not put in fresh ones. Next, plug in the house connector to bypass the batteries. Does it work that way? If not, opening the case is a must. Go to the back of the volume knob and with a small alligator jumper put it between the pins to bypass the volume sweep. If it works that way, the switch needs to be replaced. Beyond that you can search for shorted wires going to the speakers.
Sep 19, 2012 | Audio Players & Recorders
When you try to turn the volume up the knob works however sound is so low you can barely hear it.
Don't have a solution but have the same problem. Did you get any help on this site?
Vickie
May 15, 2011 | Jeep JXBLK Cassette/CD Boombox
. Plugged it in and
  • lopeka
  • 4 minutes ago
That was a long time ago, 2008, but as I remember I went Through KNG America and purchased a new sound board for $28.00. U will have to have a solder gun and remove the old board and solder in the new one. It totaly fixed mine works great. Here is a link, as I recall I asked to talk to tech support, give the make model # ect of the radio, explain the prob, and ask for a replacement sound or tunner board( I can not remember what they called the part) http://www.manta.com/c/mm7jbzb/kng-america In the event the link dose not work there phone # is (631) 389-5642. PS. kng stands for Kash N Gold Ltd, if u need to do some searching. Good luck, Hope I was of some help.
Apr 03, 2011 | Jeep JX-CHR Boombox
When i type *#3646633# this code in my china mobile they will be switch off and not stars what i do pls say me
itype *#36466633 and goto misc>highspeed sim>on the mobile was switch off my phone is china mobile
Dec 17, 2010 | Cell Phones
Max volume is way too low
what causes that issue is that your treble and bass are probably turned all the way down. just adjust those up to max and your unit will be alot louder.
Jul 18, 2009 | Bosch PB10-CD Radio/CD Boombox
Volume buttons not working
if you have a cuetip and alcohol clean around the volume control it might just be stuck. Because liquid or something got on the buttons and make them stick down or stay up.
Mar 30, 2009 | Sony CFD-S200 Cassette/CD Boombox
Need replacemet antenna
Most boomboxes use Screw on antennas (either the antenna itself is threaded or has one screw in a plate at the base). You can buy a replacement at Radioshack for about $5.
Aug 04, 2008 | Jeep JXCMP Cassette/CD Boombox
Power cord
You can go to radio shack and but a COBY universal AC-DC Adaptor Model CA-44 which one of the adapters will fit.
May 19, 2008 | Jeep JX-CHR Boombox
Jeep JX-CHR Boombox Logo
2,094 people viewed this question
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
