Question about RCA HD52W59 HDTV Projection Television
Convergence can not get covergence thru my menu any more what can I do?
    Genius:
  • 1,030 Answers
Oki this is an itc 222 or rca hd 52.... if your convergence option is not availvble in your menu and you have a bowed multicolored 3 d ish picture then this points to a special fuse fl231 if you can get this fuse and can solder then it should cost you about 5 bucks and 30 minutes to fix...ill give you more intstruction on how to do this repair. whats your model of your tv]
Posted on May 23, 2008
2 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Convergence board replace, still cannot manually adjust covergence
Do you have everything pluged in?
did you get a new board or repaired board. I think it's defective if everything checks out
Posted on Jan 18, 2008
Auto covergence will not converge
Try this with tv turned off press and hold at same time the vol- and ch- wait untill TV comes on then release Buttons,TV will either start auto convergence or you will be in the service menu to adjust convergence.
Jun 26, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
We can not locate the convergence on our RCA HDTV remote?
what is the model 0f television. customer covergence options are in the setup menu. how does the piture look? under customer option setu menu do you have the covergence option? tell me and i will see if i can help
Oct 09, 2010 | RCA Televison & Video
Tv just looks like i folded picture need help on configurance set
The tv have a problems known as a convergence problems,it dead.U have tools,soldering iron,solders.U know how to do solders?Try Ebay.com to buy a convergence Fuse(FL231).The big block of plastic call the FBT.Resolder the FBT.The 3 three fuses caps on (FL231) beside it.The covergence fuse cap in middle is dead,replaced the covergence fuse cap in the middle will solved ur convergence problems.
Jul 17, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi 43fwx20b.replaced both covergence chips how do you align colors
Convergence chips replacement should correct colors alignment itself if alignment was not changed in service menu.
Please make sure both convergence chips are getting supplies that is approx +18 volts and -18 volts.
Let me know if you have additional question.
Thanks.
Apr 25, 2010 | Televison & Video
Sony tv covergence
I think that if you go to the menu and under setup there will be a convergence option, or at least with my sony 48" thats what it is.
Nov 16, 2008 | Sony KP-51HW40 51" Rear Projection...
Covergence problem
your set has indications of several problems. red green and blue. indcate convegence issue. the fact that the picture is concave is a indication of totall loss of covergence power supply. the convegence menu missing idicate loss of some voltages from what know as the flyback.AND SHUTDOWN. indicate further problems. generally when convergence fails ..not always the set wont shut down. it could be a simple issue but further trobleshooting would have to occur to narrow it down.
Feb 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
Zenith R56W36 covergence problem
you will need to replace conv ic's then auto converge..
Oct 19, 2007 | Zenith R56W36 56" Rear Projection...
Covergence Problem
What exactly are you seeing on the screen? If one of the colors is only slightly off, you should be able to correct it with the standard menu. If one or more of the colors has suddenly taken a dramatic shift, and is curved inward at a side, it means that one of your convergence output IC's has burned out. You should not attempt to realign the convergence if this happens because you will only be messing up all the settings, and when the new IC is installed, the picture will still be out of alignment.
Aug 26, 2007 | Samsung HC-P4752W 47" Rear Projection...
How to axces convergence mode.
covergence is a very common problem with big screens and the longest to work on and adjust back to a nice picture. its really an art to converge, that takes years of practice. accessing the convergence mode is usually found on the menu button on the remote or on the set. use the remote so you can stand back too see everything. good luck
Aug 16, 2007 | Samsung HCN4226W 42" Rear Projection...
Apr 14, 2007 | Samsung HCN529W 52" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
