Directed 9"Model OHD901: Power comes on, lights work, screen shows AV1 and AV2, dvd will not play at all
  • 8,596 Answers
Preliminaries: (call Directed if these fail at 1-800-274-0200)
Make sure the disc format is supported - not HD, not Blu-Ray, and not an unfinalized burned disc
Make sure the lock switches are firmly in place
POWER—Power On/Off button, Source Select button. Hold for 3-seconds to turn power off.
Each press of this button cycles through sources DVD, AV1, or AV2.
or
SOURCE (MODE)
Press the (SOURCE) button on the remote or momentarily press the POWER button on the left
side of the LCD screen to select the input signal AV1, AV2 or DVD.
Manuf. reccomended troubleshooting:
DISC does NOT Play
Parental code is set lower than than allowed by the DVD mounted.
Ensure the disk is mounted in the player with the correct orientation (shiny side up).
The disk is warped.
The player cannot play certain formats (see the beginning of this manual).
The region code on the DVD does not match the player.
Moisture condensation has occurred within the player. Leave the unit on and the disc access cover
open and try again after about 30 minutes.
The disc has not been properly finalized (formatted) when recorded. Refer to your manual that came
with your disc authoring equipment.
Posted on May 23, 2008
2 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: Directed 9" Model OHD901 Power
or
SOURCE (MODE)
DISC does NOT Play
The disk is warped.
I moved my vhs dvd combo and it does not show on tv altho it says play
make sure that you have selected the right input from aerial to dvd
AV1, AV2 AV3 etc
Oct 24, 2015 | Televison & Video
Hi there, I am getting some problem in connecting my DVD player to LCD TV on AV2 port. If I connect the same to AV1 port,it works fine but that port is already in use for my set top box so if I want to...
I expect if you look at the menu you will find that AV2 is set up as S-Video or Component etc. etc. Set it up as composite or RGB. The same as AV1.
Jan 20, 2011 | Televison & Video
Problem of Audio in Philips TV, Model - 21RF VardanSL
check option bites find it on crt or back cover to enter serv mode coll following comands
062596 menu or display the data will appear select options and set by vol and ch keys
Jul 10, 2009 | Philips 32PW6506 32" TV
Need code for Directv remote for 26LG Flat Screen TV
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Jan 14, 2009 | Directv RC23 Remote Control
Blue screen
At least a couple of possibilities, check the yellow video cable that runs from the VCR to the TV, is it plugged into the side of the combo unit that says vcr?
Is your TV on the right source? You could have plugged the audio into say AV2 and the video into AV1, causing a mismatch. Make sure the yellow, red, and white are all plugged into one input section on the TV (AV1, AV2, Video 1, Video 2, etc).
Dec 09, 2008 | Philips MRV700VR DVD Recorder/VCR
Directed 9" Model OHD901 Power comes on, lights will come on, screen shows AV1 & AV2, but will not switch to DVD screen, and will not play dvd.
or
SOURCE (MODE)
DISC does NOT Play
The disk is warped.
May 23, 2008 | Televison & Video
Sharp tv 2004 model
Program TV Code
1. Turn on the TV.
Satellite - 0
TV - 1
VCR/DVD - 2
Verifying the Codes
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.\
Jan 26, 2008 | Audio Players & Recorders
My Screen Said "Are You Sure" and "Please Wait" and now, instead of "AV", i have "AV1" and "AV2" and my tv wont show picture from the dvd player OR vcr
You will need to go back into the menu and see what ia available in the video input mode. You may have switched the type of input you can use such as default or componts ect. If you have an isntruction manual, look in there or call the manufacturer, should also be in the instruction or user manual. Good Luck
Mar 28, 2007 | Spectra KT2114 Television
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
