Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
HCN4226W convergence board
Hello Sir,
have the same problem,as others do, with the convergence board. Do you sell this board (BP95-00142E) and can I get the alignment manual file?
Thanks in advance,
  • BuckeyeFan08 May 28, 2008
    TV still displays, but red, blue and green are totally separate. I see three images. This set was new in May of 2003, and is out of warranty. Perfect Focus does not correct problem, and manually adjusting convergence does not work. If I need a new board, what should it cost to have one installed? Thanks!
  • kellyw3 May 29, 2008
    I have the same problem. Three seperate images, green, red, blue. I had it at a repair shop and they said it was a CRT problem. After 3 weeks, he decided he wouldn't give me an estimate or repair the TV. We're getting it back today and we don't know if we should just give up on it or try to get it fixed.
    Novelist:
  • 132 Answers
SAMSUNG Convergence Board
I don't recommend working on the TV unless you have some experience and knowledge relating to the safety issues and electronic repair. Many rookies will not successfully complete the repair and probably do more harm than good.
Open the back of the TV. The board is in front of you, a small separate board with small plugs attached. If you think you are competent enough to remove it and replace it without damage to yourself or the TV, go for it.
Website below gives some description of costs with in home repair of convergence problems.
http://calgaryconvergencerepair.weebly.com/convergence-explanation.html
If you live around Calgary, Alberta try me.
Or try to the find the repairperson part of this website (on the Homepage) and search postal code. Maybe you will be lucky and someone from your area is listed for Projection TV repair.
Most rookies doing this job will cause damage and not be successful. They will pay double for someone to fix their mess or end up scrapping the TV. It is not a simple task. It is more difficult than batteries on a remote.
Good Luck
Easyab
Posted on Jun 27, 2008
THe picture is either yellowish green or yellowish orange. And has squiggly lines thru the picture. What needs replaced?
Tv have a problems known as a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.Try website like Tvrepairworld.com to buy a whole rebuild convergence board for the replacement.The Samsung/Akai tvs using the same convergence board.
Nov 06, 2010 | Samsung HCN4226W 42" Rear Projection...
I recently bought a samsung hcn4226w at a yard sale for $50. Thought it was a good deal, but when i got home I saw the picture had a double image and the picture doesn't seem bright. After some tinkering...
This tv have convergence problems.Ur tv convergence board the 2 STK convergence ICS are defective,and some or all it resistor are dead.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.Spend about $100 dollars more this tv can be save.
May 14, 2010 | Samsung HCN4226W 42" Rear Projection...
Coloring is off and there is a ghosting effect
Part # BP95-00142E is the correct convergence amp board for a model # HCN4226W. Part # BP94-00155A is listed as a "CG Amp assembly board" also, but is not correct for a model # HCN4226W. They are both basically convergence amp boards. Here's a link to order the original Samsung covergence amp board for this model (HCN4226W) from a major parts distributor:
Samsung HCN4226W Replacement Part Convergence Amp Board
Jan 30, 2009 | Televison & Video
Samsung HCN4226W Rear Projection TV
You can get the convergence board by clicking here.
The service manual you might buy it from the same place.
May 23, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226w green color problem
The green that you see is the DMD board (digital mirror display) going bad. Very common for this model.
Mar 24, 2008 | Televison & Video
Samsung HCN4226W blue color outlines
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
This convergence board works with the following Samsung television models: HCM4215W, HCN529WX, HCN559WX/XAA, PCN5425R, HCN4226WX, HCN529WX/XA
Mar 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Convergence issues?
most likely the convergence board.
Ordered complete convergence board, ask samsung for part number Convergence AMP PCB $108.44, from www.samsungparts.com
or could send it in to ptscorp.com for repair.
Dec 23, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W Service Menu?? For convergence issue????
The resistors on the new module are not 100% Identical in resistance to the originals on your board, to access the svc menu you will want a service manual and will require some patience. It can be tricky I would personally call a repairman with convergence in mind. Or order a manual and read the conv section several times. http://www.eserviceinfo.com/index.php?what=search2 Is one site, might have to purchase one.
Jul 06, 2007 | Samsung HCN4226W 42" Rear Projection...
Convergence problem?
That board, P/N Bp94-00155a should fix the problem and be fairly easy to replace. Make sure you unplug the TV before starting the repair though. Duh!
Mar 11, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
478 people viewed this question
Jerry Greenberg
Jerry Greenberg
