Question about Refrigerators
Ariston fridge freezer
Fridge compartment A.I.S  fan appears to have stopped causing uneven temp control in fridge. is fan meant to go while door is open? can one test to see if fan is ok?
  • geoff3x May 23, 2008
    thanks thats helpful, I have checked the door and you are correct, the switch does activate the fan.
    The bulge in the door that activates the switch only barely is in the correct position, being somewhat higher on the door than the switch position.
    I am thinking that maybe the switch sometimes slips past the activating bulge and therefore may not be turning on everytime, hence the warm/cold cyclical nature of the problem.
    will keep an eye on this for further developments, maybe I can lower the door position slightly.
  • 828 Answers
The fan may shut off when the door is open. Check for a switch on the door frame, push it in and the light should go off and the fan should come on.
Posted on May 23, 2008
Refridgerator door shutting causes freezer door to open
Check for a draft connecting main body to freezer body, theory is air compression transfer from main compartment to the (smaller) freezer compartment. also a quick fix would be to add more magnet strip or bare the metal that makes contact to the magnet strip that seals the door, if its a latch, Inspect the surface area that locks the latch to mount. Draft checking is achieved by blowing a fan into the smaller compartment, vice versa and having strands of string hanging around in the opposite compartment, if the string nudge indicates an air passage point. Also, check the level of the fridge, if the fridge is uneven (assuming the front is tilted downward) the momentum of the door closing will push the fridge backwards and whip it forward effectively opening the freezer door.
Oct 14, 2011 | Refrigerators
Whenever I open the door the beeper starts beeping and continues for 19 beeps regardless of whether I leave the door open or close it again. The beeps are at approx 1 second intervels
Whenever the fridge is open it gives 19 beeps actually.In your case even when it is closed it is giving 19 beeps.This is the problem with control board.The control receives the signal when closing the door and stops the sound.Check the wiring connection to and fro the control board to the door.Control board costs high.This is small problem you can just unplug the wiring connection to the door to the board instead of spending more.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Feb 01, 2011 | Refrigerators
Princess series model FN66011S The refrigerator does not change temp.it remains warm...freezer does freeze. Is this a fixable problem?
HI!!
The little fan inside the freezer is the one in charge of blowing cold air into the fridge area, the freezer control (thermostat), regulates how cold it should get, and the Refrigerator control regulates how much of this cold air goes to the fridge compartment. It is important to keep the door gasket clean at all times in order to have a good thight seal.
Check:
1.- That the freezer and fridge controls are set correctly, acording to manufacturers specs. (a common problem arises when by accident, the temp. controls are moved out of preset adjusment.
2.- That the fan is working and sounds strong, (If you keep the freezer door open for a couple of minutes, you should hear and see the motor kiking in.)
3.- Find the vent(s) in the fridge compartment and feel if cold air is coming thru when fan is working. If fan is working and blows no air, Take the freezer's back panel off, (4 hexhead screws) just enough to see inside and check if the evaporator (radiator looking component) is covered with ice, blocking the flow of air towards the fridge compartment, if it is, your defrost thermostat and-or timer are defective.
Your temp control for the fridge when you first start it, should be a bit higher than the one for the freezer. (the freezer should be in the low-middle range.) This control is nothing but a actuator for a door that controls the flow of air from the freezer. The bigger the number, the wider the door opens, and the colder the fridge gets.
Once the system is stable, let's say the next day, you can re-adjust your controls, (don't expect an inmediate change right away, change one digit a the time and check again next day) If you set your fridge too high and the freezer too low, the freezer may loose coldness and the problem would invert.
Good Luck!!!
Mar 20, 2010 | Refrigerators
Freezer gets cold refrigerator doesn't
check the damper door located between the freezer and refrigerator compartments(this lets in the cold air from the freezer) and make sure it opens and closes with your temp adjustment in the refrigerator compartment,sometimes they ice-up and are frozen in one position then take a hair dryer and defrost the door
Mar 13, 2010 | Maytag MTF2156GEW Top Freezer Refrigerator
I have a GSS25KGMD fridge. I opened the Fridge compartment top part was very warm and the bottom was cooler. Upon investigating more I noticed that the fridge bulb was very hot. So I pushed the fridge...
Your refrig light switch does control the freezer fan and the refrig light bulb . Replace the refrig light switch .
Open the refrig door , freezer fan goes off and the refrig light comes on .
Nov 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My refrigerator won't cool (freezer still working)
The temp sensor is the most likely cause of this problem. However, you have other possible options that you can test and check:
likely the problem with your fridge is a bad dumper control. This is a part which operates with the air flow from the freezer into the fresh food compartment.
The dumper control is located in the in the upper left corner in the fresh food compartment.
Sep 21, 2009 | Maytag MFD2561HE Bottom Freezer French...
Maytag fridge which freezes food in fridge compartment
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 21, 2009 | Maytag MFI2569VE Bottom Freezer French...
Our 4 year old GE side by side frig suddenly warmed to 64 degrees. Freezer stopped freezing and is at 43. Motor is running.
Really need to know what motor(s) are running (compressor, evap fan inside freezer compartment, condenser fan under fridge)?? Of course, check your temperature (thermostat) settings. Side-by-sides usually have 2 of them. They should be labled for refridgerator and freezer. The freezer control usually only opens a baffle from the freezer compartment to the refridge compartment. The refrigerator temp control is the one that controls the compressor on-off cycles and the temp of refrig compartment (this keeps the refrig compartment from freezing the milk and cokes) If the freezer control/baffle is set too far open, this will cause the refrig temp control to shut off too soon for the freezer temp to get low enough. These controls can get bumped out of the correct setting accidently from time to time.
To check the following, the fridge has to be running, or in a condition where it "should be" running: If compressor is running (condenser fan should be too), check if evaporator fan (inside freezer) is running. Open (freezer) door and hold door light switch in when you check evaporator fan operation (some fans stop when door is open) If it is not running you may have a bad evaporator fan motor. It could also be a bad defrost timer, causing the evaporator (also inside back of freezer) to ice-up. This blocks the air flow over evap. Also, there is a defrost terminator switch on the evaporator coil that stops the defrost cycle when coil is clear of ice/frost (but timer hasn't ended defrost cycle). If it is defective, that could also keep the fridge from going into the defrost cycle, or taking it out too soon. If it is the timer, change the defrost terminator as well. Depending on how handy you are, you may be able to check/change any of these parts yourself. If you don't know much about elecrical stuff, you should leave it to a repair tech. Hope this helps.
Jun 25, 2009 | GE Refrigerators
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
117 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
